I took a 3 digit 7 segment display off a bathroom scale. I'll use it for a temperature display:
Here's how it works:
There are 10 pins on it, I call them 1-10 starting on the left. I connected each one to arduino digital pins 1-10 in order.
There are three pins that determine which digit is selected, the first second or third. Those pins are 4,5, and 9. If pin 4 is LOW and the other two are HIGH then the first digit is selected. If pin 5 is LOW, then the middle one is selected, and 9 is the third.
digit 1 digit 2 digit 3
4= LOW 4=HIGH 4=HIGH
5=HIGH 5=LOW 5=HIGH
9=HIGH 9=HIGH 9=LOW
Now there are 7 pins left, one for each of the 7 segments. Turning one HIGH will turn on that segment.
Pin 7
_______
Pin 6 | | Pin 8
|_______|
| 3 |
Pin 2 | | Pin 1
|_______|
10
writing the code:
For my code example you type in a digit for the letterfunction() and it will light up the necessary segments.
For making your own symbols, the general outline is: select a digit by putting 4,5, or 9 LOW, then
After you set all the segments HIGH that you want, put a delay(5); after it. Then turn them LOW and go on to the next one.
int i=0;
int degree=25;
int nothing=100;
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9,OUTPUT);
pinMode(10, OUTPUT);
// Using Serial.begin(9600) makes pin 1 stay HIGH for some reason
//NUMERAL PINS ARE 4, 5, and 9
// 4 LOW = FIRST NUMERAL
// 5 LOW = SECOND NUMERAL
// 9 LOW = THIRD NUMERAL
//FIRST NUMERAL ON THE DISPLAY
digitalWrite(4,LOW);
digitalWrite(5,HIGH);
digitalWrite(9,HIGH);
letterfunction (7); // type 0-9 in the parenthesis or
//type (degree) for the degree symbol
// or type (nothing) for nothing
//NUMERAL 2
digitalWrite(4,HIGH);
digitalWrite(5,LOW);
letterfunction(7);
//NUMERAL 3
digitalWrite(9,LOW);
letterfunction(degree); // the degree symbol
// THIS FUNCTION HAS THE DIFFERENT NUMBERS
// AND THE DEGREE SYMBOL
void letterfunction(unsigned char var){
if (var==1){
digitalWrite(6,HIGH); //pins 6 and 2 are the leftmost vertical lines
digitalWrite(2,HIGH);
delay(5);
for(i=1;i<11;i++){
digitalWrite(i,LOW);
if (var==2){
digitalWrite(7,HIGH);
digitalWrite(8,HIGH);
digitalWrite(3,HIGH);
digitalWrite(10,HIGH);
delay(5);
for(i=1;i<11;i++){
if (var==3){
digitalWrite(1,HIGH);
delay(5);
for(i=1;i<11;i++){
if (var==4){
delay(5);
for(i=1;i<11;i++){
if (var==5){
delay(5);
for(i=1;i<11;i++){
if (var==6){
delay(5);
digitalWrite(6,LOW);
digitalWrite(7,LOW);
digitalWrite(3,LOW);
digitalWrite(2,LOW);
digitalWrite(1,LOW);
digitalWrite(10,LOW);
if (var==7){
delay(5);
for(i=1;i<11;i++){
if (var==8){
delay(5);
for(i=1;i<11;i++){
if (var==9){
delay(5);
for(i=1;i<11;i++){
if (var==0){
delay(5);
for(i=1;i<11;i++){
if (var==degree){ //the degree symbol
delay(5);
for(i=1;i<11;i++){
If you want to hook up a temperature sensor you can connect it to Analog pin 5 and use this code:
// temperature data on Analog 5
// LED display on pins 1-10
int i=0;
int degree=25;
int nothing=100;
float tempC;
float tempF;
float voltage;
int reading;
int num=11;
int digitOne;
int digitTwo;
unsigned long now;
unsigned long then;
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9,OUTPUT);
now=millis();
if (now-then > 30000 || millis()<100){ // take a sample every 30 seconds
reading=analogRead(5);
voltage = reading*(5.0/1024); //convert reading to voltage (in V), for 5V input
tempC = (voltage-0.5)*100; //convert voltage to temperature
tempF = ((tempC*9/5)+32); //convert C temperature to F
num=tempF; // num takes off the decimal point
then=now;
digitOne=num/10; //so, to get digitOne you divide by 10
// a number like 49 magically becomes 4, all decimals disappear
digitTwo=num - (digitOne * 10); //then to get digit2 (9)you multiply digitOne by 10 to get 40
// and subtract it from the original 49 to get 9
letterfunction (digitOne); // type 0-9 in the parenthesis or
//NUMERAL 2
letterfunction(digitTwo);
//NUMERAL 3
if (var==1){
delay(5);
for(i=1;i<11;i++){
else if (var==2){
delay(5);
for(i=1;i<11;i++){
else if (var==3){
delay(5);
for(i=1;i<11;i++){
else if (var==4){
delay(5);
for(i=1;i<11;i++){
else if (var==5){
delay(5);
for(i=1;i<11;i++){
else if (var==6){
delay(5);
else if (var==7){
delay(5);
for(i=1;i<11;i++){
else if (var==8){
delay(5);
for(i=1;i<11;i++){
}else if (var==9){
delay(5);
for(i=1;i<11;i++){
else if (var==0){
delay(5);
for(i=1;i<11;i++){
else if (var==degree){ //the degree symbol
delay(5);
for(i=1;i<11;i++){
