Offline
Newbie
« on: December 29, 2011, 05:17:23 pm » |
Title says it all. Built a variable PSU with a LM317. Set it to 10v for a breadboard circuit, came back to ATMega board with 1602 LCD I was making - forgot reset it back to 5v. Board no longer functioning. Assuming the answer, having looked at the datasheets, is yes. Ordered both fresh anyway. Plus a panel volt meter for the PSU (and some 5v regulators). Live and learn, huh?
Logged
Colorado
Offline
Edison Member
Reviving dead brain cells with Arduinos.
« Reply #1 on: December 29, 2011, 05:25:05 pm » |
Yeah, a bare Mega has a max VCC of 6V ... This is why I will always have a regulator on any project I make, regardless if what I'm feeding it is already within tolerance ...
Now, any of the actual Arduino Mega boards on the market should be able to handle up to 12V. If that's what you had and you fed it 10V, it should continue to work just fine.
Logged
Offline
Newbie
« Reply #2 on: December 29, 2011, 05:31:53 pm » |
Nope. Wasn't on an Arduino board. It was nude to the 10V. Won't make that mistake again
Logged
Colorado
Offline
Edison Member
« Reply #3 on: December 29, 2011, 06:12:08 pm » |
Blue smoke? If not, then you didn't fry it right.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #4 on: December 29, 2011, 09:50:45 pm » |
Modern CMOS transistors have _stunningly_ thin gate oxide, overvoltage will cause dielectric breakdown for sure.
Logged
Colorado
Offline
Edison Member
« Reply #5 on: December 29, 2011, 09:53:06 pm » |
Aye. Chalk it up to everyone wanting smaller and faster components. I say we go back to vacuum tubes!
Logged
Central MN, USA
Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
« Reply #6 on: December 31, 2011, 02:09:38 am » |
I am too young to use tube technology except for TV. I am fascinated on the other hand. Any book that is good enough for learning the golden age of.tube technology? I want to discuss tubes in my modern physics.
Logged
Colorado
Offline
Edison Member
« Reply #7 on: December 31, 2011, 02:19:52 am » |
Tubes are primarily used in audio applications nowadays. Quiality, expensive amps will have tubes in them. I don't have any book recommendations, but just searching Amazon for 'vacuum tubes' will give you plenty of options.
Logged
Offline
God Member
« Reply #8 on: January 01, 2012, 12:59:08 am » |
I got my introduction into electronics via a 1948 edition of the NRI correspondence course here is a link to the 30's era course set. http://www.renovatedradios.com/nri_1927-30.html
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #9 on: January 01, 2012, 04:21:09 am » |
To this day the majority of ham radio high power amplifiers (500-1500 watt range) still use vacuum tubes. There are some solid state high power ham amplifiers but the tube amps all more common.
Logged
Central MN, USA
Offline
Faraday Member
« Reply #10 on: January 01, 2012, 01:49:07 pm » |
Thanks guys. What I really want is a book that talks about the vacuum tube technology across the boundary of disciplines and applications. There are so many tubes beside audio amplifiers and rectifiers, such as x ray tubes, laser tubes, electron guns, mass spectrometers, etc. All sorts of discoveries are also linked to using vacuum tubes I bet.
Logged
