Topic: Is it possible to use a different pin for MISO? (Read 1 time) previous topic - next topic
TheClam
Hi, all.
I'm trying to use an Arduino Nano as an ArduinoISP so that I can burn a plain ATmega168 chip. The only hitch is that pin 12 is fried on my nano...
It seems unlikely but is it possible to use a different pin for MISO? I can't find any reference to relocating any SPI pins other than SS.
Thanks,
Foeh
retrolefty
No, the SPI signals are "hardwired" to internal hardware that performs the SPI functions. However I guess someone proficient enough could write a software SPI functions using different pins and then rewrite the ArduinoISP sketch to utilize that software SPI function. Sounds like a lot of work, better to find a way to buy a new Arduino board. A 'clone' arduino board can often be found on E-bay for around $20 if money is tight.
Lefty
magagna
I agree with retrolefty on replacing your board, but if you want to try it in software here's some code from someone who's done it:
http://little-scale.blogspot.com/2007/07/spi-by-hand.html
Good luck,
Chris
http://en.wiktionary.org/wiki/magagna <-- My last name.  Pretty apt.
TheClam
Thanks, both - really helpful info.
It's just typical that the one pin I blew happens to have a key purpose!
Foeh
retrolefty
It comes under the same law of physics that states a dropped peice of toast will always fall buttered side down. ;)
Most the I/O pins on a Arduino have secondary functions, so it's never nice to have a non-functional I/O pin.
Lefty
Constantin
Another option is to unsolder the fried CPU and solder on a new one. Not too expensive when ordered from Digikey, et al and it'll teach you drag soldering in the process! It's something I'll be doing with my mini-pro after applying a bit of too much voltage to one of the analog pins...
jwatte
I think the Ruggeduino sounds like a good idea, given the experiences you describe.
http://ruggedcircuits.com/html/ruggeduino.html
Constantin
Yeah, the Ruggeduino is one fantastic little unit that is a terrific value. All the benefits of a Uno plus voltage protection with minimal additional cost.
robtillaart
FWIW For "moving" pins this shield is sometimes an option - http://mayhewlabs.com/products/go-between-shield -
Rob Tillaart
