Topic: Teensy++ 2.0 and SD Card (Read 2456 times) previous topic - next topic
cottontail
I have a Teensy++ 2.0 and a MicroSD card slot purchased from PJRC, but I cannot seem to get the Teensy to see the SD card slot.  The test code I am using is as follows...
#include <SD.h>
  //Pause for 1 second
  //Needs to be set for the SD library to function
  pinMode(10, OUTPUT);
  //Check to make sure SD card is functioning, if not set red LED
  if (!SD.begin(20)) {
    analogWrite(16, 1023);
I have tried multiple variations, but all I get is the red LED (pin 16).  Pins 20, 21, 22 and 23 are hooked to SS, SCLK, MOSI and MISO in that order and GND and 5v are also attached to the SD card reader.  When testing voltages for the pins at the SD card reader and the Teensy I get...
SS - 5
SCLK - .02
MOSI - 5
MISO - 3.3
5v - 5
Any thoughts would be greatly appreciated... thanks!
cottontail
Monitoring the 4 pins on the Teensy through analogRead, here is what I get...
SS - 1020
SCLK - 1007
MOSI - 1020
MISO - 1023
SS - 1020
SCLK - 1012
MOSI - 1016
MISO - 1021
SS - 1021
SCLK - 1016
MOSI - 1016
MISO - 1019
SS - 1021
SCLK - 1018
MOSI - 1015
MISO - 1014
SS - 1023
SCLK - 1020
MOSI - 1016
MISO - 1013
SS - 1022
SCLK - 1021
MOSI - 1018
MISO - 1015
SS - 1020
SCLK - 1021
MOSI - 1020
MISO - 1018
SS - 1019
SCLK - 1020
MOSI - 1020
MISO - 1020
SS - 1018
SCLK - 1019
MOSI - 1021
MISO - 1
SS - 1018
SCLK - 1017
MOSI - 1020
MISO - 1
SS - 1018
SCLK - 1017
MOSI - 1019
MISO - 0
SS - 1020
SCLK - 1018
MOSI - 1018
MISO - 1022
SS - 1021
SCLK - 1019
MOSI - 1018
MISO - 1020
SS - 1022
SCLK - 1020
MOSI - 1017
MISO - 1015
SS - 0
SCLK - 1023
MOSI - 1019
MISO - 1015
SS - 1023
SCLK - 1023
MOSI - 1020
MISO - 1016
SS - 1022
SCLK - 1023
MOSI - 1022
MISO - 1019
SS - 1021
SCLK - 1022
MOSI - 1022
MISO - 1021
SS - 1020
SCLK - 1021
MOSI - 1023
MISO - 1
SS - 1018
SCLK - 1019
MOSI - 1022
MISO - 2
SS - 1019
SCLK - 1018
MOSI - 1020
MISO - 0
SS - 1021
SCLK - 1019
MOSI - 1019
MISO - 1022
SS - 1022
SCLK - 1020
MOSI - 1019
MISO - 1020
SS - 1022
SCLK - 1021
MOSI - 1018
MISO - 1016
SS - 0
SCLK - 0
MOSI - 1021
MISO - 1016
SS - 1023
SCLK - 0
MOSI - 1022
MISO - 1017
SS - 1023
SCLK - 1023
MOSI - 1022
MISO - 1018
SS - 1022
SCLK - 1022
MOSI - 1023
MISO - 1021
SS - 1021
SCLK - 1022
MOSI - 1023
MISO - 0
SS - 1020
SCLK - 1020
MOSI - 1023
MISO - 2
SS - 1019
SCLK - 1019
MOSI - 1022
MISO - 2
SS - 1020
SCLK - 1019
MOSI - 1021
MISO - 0
SS - 1021
SCLK - 1020
MOSI - 1020
MISO - 1021
SS - 1022
SCLK - 1021
MOSI - 1020
MISO - 1019
SS - 1023
SCLK - 1022
MOSI - 1019
MISO - 1016
SS - 1
SCLK - 0
MOSI - 1022
MISO - 1017
SS - 1023
SCLK - 1023
MOSI - 1022
MISO - 1018
SS - 1022
SCLK - 1023
MOSI - 1023
MISO - 1020
SS - 1021
SCLK - 1022
MOSI - 1023
MISO - 1022
SS - 1020
SCLK - 1021
MOSI - 0
MISO - 1
SS - 1019
SCLK - 1019
MOSI - 1022
MISO - 2
SS - 1020
SCLK - 1019
MOSI - 1021
MISO - 0
PaulS
Code: [Select]
Set pin 10 as output and then tell the SD card that the chip select pin is 20. Well, I don't think I'd expect that to work too well. And, apparently, it doesn't.
cottontail
Code: [Select]
Every post I have read on the topic says that pin 10 needs to be set as output for the SD library to work even if there is nothing on pin 10.  And pin 20 is the chip select pin on a Teensy++ 2.0 according to what I have read.  I have seen several examples of what claim to be working code with the same hardware that use exactly the code I am using here.
My programming background is not in Arduino, so if you or anyone else have any helpful suggestions to this problem I would love to hear them.
fat16lib
You don't need
Code: [Select]
with SD.h or SdFat on any board.
SD.h is a wrapper for an old version of SdFat. I wrote SdFat and it sets the correct mode for all pins that it uses.
Examples on the AdaFruit site have this incorrect code and it has now become a magic incantation that appears in many sketches.
At best it will do no harm but it is better to not set OUTPUT mode for pin 10.
You could try running the QuickStart example in SdFat.  SdFat has code for teensy++ 2 but I have not checked it lately.  SdFat is here http://code.google.com/p/sdfatlib/downloads/list.
If QuickStart runs on teensy++ it will give more information.
cottontail
I get the following output...
"errorCode: 0x1, errorData: 0xff"
It seems like a wiring issue but as you can see above I have checked the wiring and as far as I can tell it should be all set.
fat16lib
Error code 0X1 means the SD card does not respond to the first command that SdFat sends.  This is almost certainly a hardware problem.
Hope you are not connecting 5V, SCK, SS, and MOSI directly to the card.  The card runs at 3.3 V and these signals are too high so you need a level shifter.  You can connect MISO directly to the card.
stevemarple
#7
Dec 31, 2011, 09:43 pm Last Edit: Jan 01, 2012, 01:53 am by stevemarple Reason: 1
Only if there are no 5V devices on the SPI bus. Why doesn't anyone consider the problem of mixing 3.3V and 5V devices on the SPI bus?
cottontail
According to the product page (http://pjrc.com/store/sd_adaptor.html), the SD board contains "a 3.3 volt regulator and 5 to 3.3 volt buffer chip protects the SD card, and allows interfacing to 5 volt processors."  So yes, it is connected directly to the card.  I figured it was a hardware issue, but when I measured the inputs on the SS, SCLK, MOSI and MISO on the Teensy through analogRead they all showed that they were receiving input.  I have tested it with different MicroSDHC cards and tested the cards in other devices.  I am somewhat at a loss here... any suggestions on other ways to check and correct potential hardware issues?
fat16lib
I have used that Micro SD card adapter with a teensy successfully so it should work with the teensy++ if you have it connected correctly.
It has the proper regulator and level shifters so that is not a problem.
Measuring the voltage levels is not much of a test and analogRead is meaningless since SS is high in most of your readings so the SD is not selected.
There is nothing you can do with software tests when you get error code 0X1 since no data is received from the card.  It is acting like nothing is connected to the SPI bus.
cottontail
Okay, sounds like I am pretty much out of luck then... time to pitch the whole thing and start over.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
