Topic: Arduino 2 Arduino serial communication problem (Read 911 times) previous topic - next topic
jimmydean
Hello,
I have a Arduino UNO that I am trying to have communicate with an Arduino Diecimila over serial, and I can't figure out what I'm doing wrong.  The Uno is the sending unit, and this is it's sketch:
int ledPin = 13;
int sendingByte = 0;
void setup(){
 pinMode(ledPin, OUTPUT);
 sendingByte = 1;
 Serial.write(sendingByte);
 //Serial.println(sendingByte);
 digitalWrite(ledPin, HIGH);
 delay(2000);
 sendingByte = 2;
// Serial.println(sendingByte);
 digitalWrite(ledPin, LOW);
 delay(2000);
 sendingByte = 0;
The receiving unit is the Diecimila, and it's sketch is this:
int incomingByte = 0;
int ledPin = 13;
 if (Serial.available() > 0) {
   incomingByte = Serial.read();
   if(incomingByte == 1){
   if (incomingByte == 2){
The Uno seems to be transmitting just fine, with the LED on pin 13 lighting up accordingly. I also ran the serial monitor on the Uno and it is sending 1 and 2 alternately.  I see the TX and RX lighting up on the Diecimila when the UNO transmits, but the LED connected with pin 13 just flickers momentarily.  It should be going HIGH or LOW accordingly.  The UNO digital pin 1 is connected to the Diecimila digital pin 0, and vise versa.  There is one line connecting their common GND.
What am I not understanding?   Thanks
PaulS
Try changing the type of variable being sent. The name of the variable should give you a clue as to the correct type.
jimmydean
Thanks PaulS.  Here is my rewritten code for those interested:
Sending unit -
int ledPin = 13;
void setup(){
  Serial.print(1);
  delay(2000);
  Serial.print(2);
  delay(2000);
Receiving unit -
int ledPin = 13;
    //read incoming byte - subtract incoming ASCII value from 0 ASCII value to get char sent
    incomingByte = Serial.read() - '0';
