Topic: Webserver example (Read 757 times) previous topic - next topic
I wanna try to build the webserver example in arduino.
But can I really access this server through internet. as I observed, there is only the the private ip and mac is  coded in the sketch.
so how can i access this from a different network through the Internet..?
And I'm using an ENC28J60 based ethernet shield.
Please help..
Check - http://www.no-ip.com/ - You can register a sub-domain for free e.g.  phantom89.no-ip.com
No-ip.com forwards requests to this to your ip address (router) and a predefined port.
You need to config portforwarding to your arduino's ip in your router.
Your arduino should have a fixed IP to make this work - afaik
Note that anyone knowing the name phantom89.no-ip.com  or your IP/PORT combination can contact your arduino.
hopes thie helps
Rob Tillaart
Thanx robtillaart...
Ill try this as soon as my device is ready..
An hope you will help if i need any further help with this..
btw, Happy New Year...!!!
hey, can use Pachube for this task?
