Topic: 28BYJ-48 5-Volt Stepper (Read 197425 times) previous topic - next topic
d00m
Hello Sbright33
I also trying to use your code.
I have copied it from https://gist.github.com/sbright33/4178431 and paste to Arduino IDE
compiled and nothing happens..
I have tried uncomment two lines in loop
void loop(){
calloften(); delay(500);
off();while(1); //halt
but in not helps..
I have arduino nano + 28BYJ-48 + uln2003 driver board - all connected in proper way to 4,5,6,7 pin on arduino..
all other examples for stepper motor are working ok..
please advise.
lowres
Hello,
I am trying to run 2-28BYJ-48 steppers using the Accelstepper library by Mike McCauley on an Uno R3.  If I run the base multistepper example, stepper one does not reverse and stepper two will turn and stop.  I found Celem's modification "accellstepper 28BYJ-48" for a single stepper, which I tried to adapt and I can get stepper 2 to reverse, but stepper 1 continues in the same clockwise direction.  Any advice would be helpful.
Thanks
// MultiStepper.pde
// -*- mode: C++ -*-
// Shows how to multiple simultaneous steppers
// Runs one stepper forwards and backwards, accelerating and decelerating
// at the limits. Runs other steppers at the same time
// Copyright (C) 2009 Mike McCauley
// $Id: MultiStepper.pde,v 1.1 2011/01/05 01:51:01 mikem Exp mikem $
#include <AccelStepper.h>
// Define some steppers and the pins the will use
AccelStepper stepper1; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
AccelStepper stepper2(AccelStepper::FULL4WIRE, 6, 7, 8, 9);
    stepper1.setMaxSpeed(1000.0);
  stepper1.setAcceleration(50.0);
  stepper1.setSpeed(200);
  stepper1.moveTo(2048);
    stepper2.setMaxSpeed(1000.0);
  stepper2.setAcceleration(50.0);
  stepper2.setSpeed(200);
  stepper2.moveTo(2048);
    // Change direction at the limits
    if (stepper1.distanceToGo() == 0)
stepper1.moveTo(-stepper1.currentPosition());
    if (stepper2.distanceToGo() == 0)
stepper2.moveTo(-stepper2.currentPosition());
    stepper1.run();
    stepper2.run();
lowres
actually, this is the code that will reverse stepper 2, but stepper one continues without reversing
// accellsteppertest.ino
// at the limits. Derived from example code by Mike McCauley
// Set for 28BYJ-48 stepper
#define FULLSTEP 4
#define HALFSTEP 8
//declare variables for the motor pins
int motorPin1 = 6; // Blue   - 28BYJ48 pin 1
int motorPin2 = 7; // Pink   - 28BYJ48 pin 2
int motorPin3 = 8; // Yellow - 28BYJ48 pin 3
int motorPin4 = 9; // Orange - 28BYJ48 pin 4
                        // Red    - 28BYJ48 pin 5 (VCC)
// The sequence 1-3-2-4 required for proper sequencing of 28BYJ48
AccelStepper stepper2(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
  //Change direction at the limits
  stepper1.run();
  stepper2.run();
lowres
OK, got it.  probably had to do with the pin definition
// Runs two steppers forwards and backwards, accelerating and decelerating
// modified by Celem for single stepper
// Set for two 28BYJ-48 stepper motors
#define FULLSTEP 4
#define HALFSTEP 8
int motorPin1 = 4; // Blue   - 28BYJ48 pin 1
int motorPin2 = 5; // Pink   - 28BYJ48 pin 2
int motorPin3 = 6; // Yellow - 28BYJ48 pin 3
int motorPin4 = 7; // Orange - 28BYJ48 pin 4
int motorPin5 = 8; // Blue   - 28BYJ48 pin 1
int motorPin6 = 9; // Pink   - 28BYJ48 pin 2
int motorPin7 = 10; // Yellow - 28BYJ48 pin 3
int motorPin8 = 11; // Orange - 28BYJ48 pin 4
AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
AccelStepper stepper2(HALFSTEP, motorPin5, motorPin7, motorPin6, motorPin8);
  stepper1.run();
  stepper2.run();
sharonf
I'm a fresh beginner.
Could someone post pictures of the built circuit so I can learn how to read the diagram ?
Thanks!
d00m
sharonf
pls check the first page of this thread.
sharonf
Doom, I mean a "real" picture of the arduino and the wires, not the circuit sketch
celem
Sharonf, you can see a video of a "real" functioning  28BYJ-48 5-Volt Stepper circuit on YouTube - at http://youtu.be/z3AO8XRncAc
If you pause the video you'll be able to see the wiring. It is using an Arduino NANO
sharonf
Thanks,
What is the additional board at the end of the prototype bread board?
celem
A breadboard power supply. The stepper draws too much current to run from the USB port. The power supply was purchased over eBay and is similar to these:
http://tinyurl.com/a6nj256
harriscreekcentral
Is there Anybody out there... there... there...
Yes, I am out here, and I am a newbie reading every little bit of information like a new born puppie having its first drink of milk from its mommies nipple.  That is about the best way I have of describing my experience with Arduino.
I have the Arduino Uno, the 2003 driver board and the 28BYJ-48-5 motor.  I have played with the Uno board and have suceeded in getting the "Blink" command to work.   I have tried a previous set up to  get the motor to do its thing but so far a "Fail"..
I have just received a second new motor and 2003 board, and I am about to go to my basement work area and start a new fresh approach to the problem.
My aim to have the Uno control a stepper motor to drive a dividing head for my Unimat lathe.  I would like to direct you to a "YouTube" video by Chuck Fellows : http://www.youtube.com/watch?v=XwX0YjClgQE.......This is what I am aiming to do.
I will be back.  I just wanted you to know I was taking in all the good information.
Harvey,
in Kelowna, BC.
Harvey
in Kelowna, BC
sharonf
Maybe you could upload a picture of the wiring you did for the stepper + arduino, and the code you used?
I got it to work with some effort
harriscreekcentral
I had Chuck look at the wiring. He thought I had one set of wires backwards.  I have taken that set up apart and I am starting all over. I'll see how far I get tonight.
Harvey
in Kelowna, BC
harriscreekcentral
Note  reference to: "Celem" December 31, 2011, 11:46:27 AM »
I have copied and pasted the code from your messgae.  Thanks very much.  Now, I am new, new, new,to Arduino and the "codes" ..I am using the 28BYJ-48-5VDC Gear Stepper Motor with ULN2003 Driver Board. So just to let you know why I put in three new's my first project was to download the "BLINK" code, and completed that succesfully.  Now I have set up the Arduino Uno, with this little motor and driver, downloaded the code from your posting, and woopy it also works. So now Grampa has two attempts that have worked.
I sort of understand the concept of the clockwise and the C/clockwise, but I have no clue as to where to go into the code to edit it.  My motor is turning at just under 1 rpm.  Where  do I go to adjust the speed, and direction. Thanks for your help.
Harvey
in Kelowna BC.
Harvey
in Kelowna, BC
celem
If you are using the code in my December 31, 2011 post the variable "motorSpeed" controls the speed since it is used for the "delay" value between steps.
If your goal is to increase speed, remember that this stepper is geared down with a 1:64 ratio - so it will never spin very fast. That said, it can be improved with a different library - see my post of January 17, 2012, 10:14:20 AM - try the AccelStepper library mentioned there. The VIDEO at that post shows the AccelStepper in use - your stepper should turn at least this fast.
The AccelStepper Library has speed() and runSpeedToPosition() functions that may give you what you want. While the AccelStepper Library supports a maximum stepping speed to about 4kHz, the 28YJ-48 supports a maximum no-load step rate of 900pps (less that 1kHz).
The 28BYJ-48 has a step angle of 5.625°/64. Therefore, one full rotation requires 4,096 steps. At 900pps (with simultaneous port writes as mentioned in the post of Reply #19 on: January 14, 2012, 10:17:55 AM) the maximum rotation speed computes to 13rpm (unless my math was wrong) - (900/((360/5.625)*64))*60. However, look back in this thread and you'll see that sbright33 says that he can achieve 35rpm. I don't see how this is possible but that is what he says. Please note, however, that he is running the stepper with 12VDC and he has to de-power it when idle to avoid overheating, so he is driving the stepper very hard.
As to speed, remember that this stepper was designed to move the vents on air conditioners, that are popular in Asia, with a goal of high torque not high speed.
Good luck with your experiments.
