Topic: (ERRORE) EasyVr_AccessControlDemo (Read 2474 times) previous topic - next topic
cgs64
Salve
PREMETTO CHE la scheda EasyVR in questione  si collega regolarmente, ci posso inserire nuovi comandi e riconoscimento vocale, salvando, etc etc, e tutto funziona.
Purtroppo ricevo un errore quando carico un prg Demo fornito (EasyVr_AccessControlDemo) per la scheda EasyVR (riconoscimento vocale), sia con la Ver. 0023 che con la Ver. 1.0 di ARDUINO.
(Nel CODICE ho evidenziato in GRASSETTO BLU la riga dove trova l'errore)
Gli errori sono rispettivamente:
VERSIONE 0023
EasyVR_AccessControlDemo:57: error: no matching function for call to 'EasyVR::EasyVR(NewSoftSerial&)'
F:\- ARDUINO\arduino-0023\libraries\EasyVR/EasyVR.h:185: note: candidates are: EasyVR::EasyVR(Stream&)
F:\- ARDUINO\arduino-0023\libraries\EasyVR/EasyVR.h:33: note:                 EasyVR::EasyVR(const EasyVR&)
VERSIONE 1.0
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:39:24: error: WConstants.h: No such file or directory
In file included from F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:41:
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
F:\- ARDUINO\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp: In member function 'void NewSoftSerial::tx_pin_write(uint8_t)':
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:291: error: 'LOW' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp: In member function 'void NewSoftSerial::setTX(uint8_t)':
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:368: error: 'OUTPUT' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:368: error: 'pinMode' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:369: error: 'HIGH' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:369: error: 'digitalWrite' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:370: error: 'digitalPinToBitMask' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:371: error: 'digitalPinToPort' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:372: error: 'portOutputRegister' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp: In member function 'void NewSoftSerial::setRX(uint8_t)':
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:377: error: 'INPUT' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:377: error: 'pinMode' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:379: error: 'HIGH' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:379: error: 'digitalWrite' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:381: error: 'digitalPinToBitMask' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:382: error: 'digitalPinToPort' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:383: error: 'portInputRegister' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp: In member function 'virtual void NewSoftSerial::write(uint8_t)':
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:472: error: 'HIGH' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:472: error: 'LOW' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:478: error: 'byte' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:478: error: expected `;' before 'mask'
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:478: error: 'mask' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:492: error: 'byte' was not declared in this scope
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:492: error: expected `;' before 'mask'
F:\- ARDUINO\arduino-1.0\libraries\NewSoftSerial\NewSoftSerial.cpp:492: error: 'mask' was not declared in this scope
CODICE
.... omissis ....
#if defined(ARDUINO) && ARDUINO >= 100
 #include "Arduino.h"
 #include "SoftwareSerial.h"
 SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
 #include "WProgram.h"
 #include "NewSoftSerial.h"
 NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
#include <Servo.h>
#define SND_Access_denied            1
#define SND_Access_granted           2
#define SND_Hello                    3
#define SND_Please_repeat            4
#define SND_Please_say_your_password 5
#define SND_Please_talk_louder       6
Servo myservo;
EasyVR easyvr(port);
EasyVRBridge bridge;
uint32_t mask = 0;
int8_t group = 0;
uint8_t train = 0;
char name[32];
.... omissis ....
Pelletta
Io l'ho usato con l'ide 0022 e ha funzionato a dovere.
cgs64
Provo a riscaricare l'IDE 0022 e vediamo
cgs64
Anche con la 0022 ricevo:
EasyVR_AccessControlCGS64.cpp:1:27: error: NewSoftSerial.h: No such file or directory
EasyVR_AccessControlCGS64:1: error: 'NewSoftSerial' does not name a type
EasyVR_AccessControlCGS64:4: error: 'port' was not declared in this scope
EasyVR_AccessControlCGS64.cpp: In function 'void setup()':
EasyVR_AccessControlCGS64:53: error: 'port' was not declared in this scope
Non capisco !
Pelletta
Scusa la domanda, ma hai messo le librerie nell'IDE?
cgs64
#5
Jan 01, 2012, 10:31 pm Last Edit: Jan 01, 2012, 10:42 pm by cgs64 Reason: 1
Si certamente--- ;-)
Comunque ho scoperto l'arcano.
Ho eliminato tutti i files dalla TEMP (sotto C:\Users\Gaetano\Application Data\.............) e tutto FUNZIONA !!!
Cioè, adesso non da' più errore e carica lo Sketch.... pero' ......
con questo codice non accade niente (NON STAMPA neppure nulla sul Serial Monitor dell'IDE !!!
Ci capisci qualcosa ?
#include <NewSoftSerial.h>
#include <EasyVR.h>
//Groups and Commands
enum Groups
 GROUP_0  = 0,
 GROUP_1  = 1,
 GROUP_16 = 16,
enum Group0
 G0_JAMES = 0,
enum Group1
 G1_GAETANO = 0,
 G1_DANIEL = 1,
 G1_ROSSO = 2,
 G1_VERDE = 3,
 G1_GIALLO = 4,
 G1_APRI = 5,
 G1_CHIUDI = 6,
 G1_CHIUDIPORTA = 7,
 G1_APRIPORTA = 8,
 G1_LUCEGIARDINO = 9,
enum Group16
 G16_MRJONES = 0,
int8_t group, idx;
 port.begin(9600);
 Serial.println("STAMPIAMO");
 // bridge mode?
 if (bridge.check())
   cli();
   bridge.loop(0, 1, 12, 13);
 // run normally
 //Serial.begin(9600);
 //port.begin(9600);
 //Serial.println("STAMPIAMO");
 if (!easyvr.detect())
   Serial.println("EasyVR not detected!");
   for (;;);
 easyvr.setPinOutput(EasyVR::IO1, LOW);
 Serial.println("EasyVR detected!");
 easyvr.setTimeout(5);
 easyvr.setLanguage(1);
 group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
 easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
 Serial.print("Say a command in Group ");
 Serial.println(group);
 easyvr.recognizeCommand(group);
 do
   // can do some processing while waiting for a spoken command
 while (!easyvr.hasFinished());
 easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
 idx = easyvr.getWord();
 if (idx >= 0)
   // built-in trigger (ROBOT)
   // group = GROUP_X; <-- jump to another group X
   return;
 idx = easyvr.getCommand();
 if (idx >= 0)
   // print debug message
   uint8_t train = 0;
   char name[32];
   Serial.print("Command: ");
   Serial.print(idx);
   if (easyvr.dumpCommand(group, idx, name, train))
     Serial.print(" = ");
     Serial.println(name);
   easyvr.playSound(0, EasyVR::VOL_FULL);
   // perform some action
   action();
 else // errors or timeout
   if (easyvr.isTimeout())
     Serial.println("Timed out, try again...");
   int16_t err = easyvr.getError();
   if (err >= 0)
     Serial.print("Error ");
     Serial.println(err, HEX);
void action()
   switch (group)
   case GROUP_0:
     switch (idx)
     case G0_JAMES:
       // write your action code here
       // group = GROUP_X; <-- or jump to another group X for composite commands
   case GROUP_1:
     switch (idx)
     case G1_GAETANO:
     case G1_DANIEL:
     case G1_ROSSO:
     case G1_VERDE:
     case G1_GIALLO:
     case G1_APRI:
     case G1_CHIUDI:
     case G1_CHIUDIPORTA:
     case G1_APRIPORTA:
     case G1_LUCEGIARDINO:
   case GROUP_16:
     switch (idx)
     case G16_MRJONES:
Pelletta
Perfetto, ora divertiti con quel modulino ma mi raccomando non usarlo per applicazioni critiche tipo aprire il portone di casa o cose simili.... da quello che ricordo è piuttosto "ingenuo", prova a storpiare le parole chiave e noterai con rammarico che da quasi tutto per buono.
cgs64
TRANQUI !
Lo uso per comandare un po' di cose ma "in casa".
Ho scoperto che con "#include <NewSoftSerial.h>"......
tutti i comandi che usano la seriale alla "vecchia maniera" non sono cagati affatto, ad esempio....
  port.begin(9600);
Hai una vaga idea se si possa stampare (inviare dati) al Serial Monitor in altro modo ?
Pelletta
Non ho più il modulo per fare delle prove però mi pare di ricordare che il modulo usa i pin 0 e 1 di arduino per comunicare, ecco perchè non ti funziona il serial monitor dell'IDE
cgs64
per INFO GENERALE
il problema nasce da fatto che se si usa una IDE > alla 0022 tutto funziona abbastanza MALE !
Usando la 0022 tutto OK
