Topic: linux / cannot change board type (Read 931 times) previous topic - next topic
michael_bb
after a fresh install of arduino-1.0 under Ubuntu 11.10 in principle the sw is working (can compile and upload).
But I cannot change the board type, if I select anything other than the default, the value is always reset to the default board.
thx, michael
SurferTim
#1
Jan 02, 2012, 01:20 pm Last Edit: Jan 02, 2012, 01:45 pm by SurferTim Reason: 1
I just started playing with Arduino V1.0, and I have not seen that problem. I am using Ubuntu V11.10.
I installed Arduino V0022 from the Ubuntu repository first tho.
Add: I had to check my setup. The setup preferences are kept in this directory/file
/home/user/.arduino/preferences.txt
That is a hidden directory in your home directory. You can open it with a text editor to check it.
