Loading...
Pages: [1]   Go Down
Author Topic: FIXED: Arduino 1.0 Issues with wiring.h RotaryEncoderAcelleration.h  (Read 6229 times)
UK
Offline Offline
Sr. Member
View Profile
I have a project that is nearly finished and is making use of several libraries one of which is RotaryEncoderAcelleration.h (http://arduino.cc/playground/Main/RotaryEncoderAcceleration).  This library calls routines wiring.h, tickspersecond.h.....
Anyway the program will not compile under Arduino 1.0
I get the following error messages:
In file included from M_Computer.cpp:2:
/Users/darren/Documents/Arduino/libraries/RotaryEncoderAcceleration/Button.h:6:20: error: wiring.h: No such file or directory
In file included from M_Computer.cpp:7:
/Users/darren/Documents/Arduino/libraries/LiquidCrystal/LiquidCrystal.h:82: error: conflicting return type specified for 'virtual void LiquidCrystal::write(uint8_t)'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
I'm not really sure where to start but the first error is due to RotaryEncoderAccelerator calling button.h which calls wiring.h
There appears to be an issue with the Liquid Crystal library and Print.h too
Some pointers on what to do would be very helpful if anybody can possibly help
Do I need to replace the liquid crystal library with a newer version?
Many thanks
« Last Edit: January 03, 2012, 01:24:13 pm by cowasaki » Logged
UK
Offline Offline
Sr. Member
View Profile
I've deleted the LiquidCrystal folder from documents::Arduino::libraries and replaced it for the one inside the Arduino 1.0 folder and now the error I get is:
So just one error now, it would appear that the library ROTARYENCODERACCELERATION is not arduino v1.0 compatible yet smiley-sad
« Last Edit: January 02, 2012, 06:10:45 pm by cowasaki » Logged
UK
Offline Offline
Sr. Member
View Profile
OK, this is now sorted smiley
To fix RotaryEncoderAcelleration library so it works with Arduino 1.0 all you need to do is download the library and open each ".h" file then:
replace
  #include <wiring.h>
with
  #include <Arduino.h>
That's it, my package now compiles smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
