Topic: Arbitrary precision (big number) library port for Arduino (Read 53270 times) previous topic - next topic
Isaac12
This is really cool I was surprised at how fast it did it. Those are some pretty big numbers.
urbantigerau
Hi.
I am writing an emulation program for an old computer  - An Olivetti Programma 101, the first computer I ever encountered  when I was in high school and which really sparked my interest and probably changed my life. The 101 had quite a few unique and very clever features and used a system of 22 digit registers. I had started writing some code to do the same functions as the 101 supported in serial BCD representation covering add, subtract, multiply, divide (including remainder) and square root. I had the add and subtract routines working when I came across this post. With just a couple of extra things this library will do nicely. I need to know the length of the whole part of the number and the length of the fractional part.
The number.c and corresponding number.h seem best suited despite the more arcane calling process although using the BigNumber functionality certainly makes the process easy and logical. Good work all round.   If I have read the code correctly the information I want is the  n_len and n_scale of the target number.
Now I have to admit my C++ is pretty flaky and I don't tend to write libraries or use the macro capability of C much. I recognise the power of it but am not very familiar.  But I thought I had it by studying what was there and doing something similar. First I added a routine bc_size_whole_fraction to number.c as follows:
void
bc_size_whole_fraction (num, size_whole, size_fraction)
      bc_num num;
      int *size_whole;
      int *size_fraction;
   size_whole = num->n_len;
   size_fraction = num->n_scale;
I thought this would take the number in question and return the size of the whole part and the faction part. Next I changed number.h as follows:
_PROTOTYPE(void bc_out_num, (bc_num num, int o_base, void (* out_char)(int),
     int leading_zero));
/* new line below*/
_PROTOTYPE(void bc_size_whole_fraction, (bc_num num, int *size_whole, int *size_fraction));
#endif
Finally I took a fragment of one of the test programs with just the multiply part so I could play around with it:
#include "number.h"  // this is the modified file as is number.c
static int DIGITS=1;
void print_bignum (bc_num x)
  char *s=bc_num2str(x);
  Serial.print (s);
  free(s);
void setup ()
  Serial.begin (9600);  // I am using a  Mega 1280 at 9600 baud.
  Serial.println ();
  Serial.println ();
  bc_init_numbers ();  // initialize library
  int sizew,sizef;
  // some big numbers
  bc_num a=NULL, b = NULL, c = NULL;
  Serial.println ("--- multiply ---");
  // test multiplication
  bc_str2num(&a, "42.345",DIGITS);
  bc_str2num(&b, "18254546", DIGITS);
  bc_multiply(a,b,&c,DIGITS);
  // get results as string
  bc_size_whole_fraction(a,&sizew,&sizef); // read the sizes I am seeking for number a
  Serial.print("int ="); Serial.print(sizew); Serial.print("  "); Serial.print(sizef); Serial.print("  ");
  print_bignum (a); Serial.println();
  print_bignum (b); Serial.println();
  print_bignum (c); Serial.println();
  bc_free_num (&b);
  bc_free_num (&c);
}  // end of setup
void loop () { }
Now when complied i receive quite a series of errors:
sketch_jul06a.cpp.o: In function `print_bignum(bc_struct*)':
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:11: undefined reference to `bc_num2str(bc_struct*)'
sketch_jul06a.cpp.o: In function `setup':
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:21: undefined reference to `bc_init_numbers()'
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:31: undefined reference to `bc_str2num(bc_struct**, char const*, int)'
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:32: undefined reference to `bc_str2num(bc_struct**, char const*, int)'
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:33: undefined reference to `bc_multiply(bc_struct*, bc_struct*, bc_struct**, int)'
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:37: undefined reference to `bc_size_whole_fraction(bc_struct*, int*, int*)'
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:43: undefined reference to `bc_free_num(bc_struct**)'
C:\DOCUME~1\Fred\LOCALS~1\Temp\build325333058827944339.tmp/sketch_jul06a.cpp:44: undefined reference to `bc_free_num(bc_struct**)'
I am thinking this is an error which is readily fixed and caused by something I missed and can't see. Any suggestions?
Regards, Fred.
nickgammon
It's something to do with your setup. If I omit the line with your added function (bc_size_whole_fraction) and then compile I get your errors. But if I add:
#include "BigNumber.h"
instead of your include, it compiles OK. The IDE doesn't know where number.h is but it does know where BigNumber.h is (because it is in a directory of the same name inside the libraries folder).
urbantigerau
Thanks Nick. It certainly compiles now but returns rubbish. The numbers coming back regarding the length of the fractional and whole parts look random to me. More study needed. I'll make it work yet. Regards, Fred.
ghlawrence2000
This is awesome!
"New Arduino DUE(not delivered yet) looking for new home since this library appears capable of significantly higher precision than 'mere' DOUBLE floats..."
OOps!!
  :smiley-roll: =( :smiley-roll-blue:  :0
Second thoughts, I like the look of the speed advantages a DUE will offer over a MEGA!!  XD
Maybe some sticky or some reference to this library should be placed in the 'Reference' section to save other newbies making a similar mistake..
Excellent work Nick!
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
ghlawrence2000
OK, update since my last post....
I have done a fair bit of 'playing' with this library now, and also my DUE arrived  :D :smiley-red:. Sure enough this library can easily exceed the accuracy of DOUBLEs no problem, and on a DUE, it is almost 'rude' not to use it!! The speed is awesome!
However I have a question, once i have done all of my calculations and got the result I want, I have my BigNumber such as north = 449098.003294241285794.... and I would like the INT portion.... floor and ceil dont seem to work? Could you please tell me how to get int north or unsigned long north for example?
Just like to say thanks again Nick!
As a point of reference for other ''newbs' , the results achieved by this library are identical between a MEGA2560 and a DUE, the only difference is time taken to do the calculations...
nickgammon
If you know in advance how much precision you want you can use setScale. Otherwise:
void setup ()
 Serial.begin (115200);
 Serial.println ();
 BigNumber::begin ();  // initialize library
 BigNumber a, b = 2, c;
 BigNumber::setScale (2);
 a = BigNumber (1) / BigNumber (3);
 c = b.sqrt ();
 Serial.print ("1/3 = ");
 Serial.println (a);
 Serial.print ("sqrt(2) = ");
 Serial.println (c);
 BigNumber::setScale (20);
 c = b.sqrt ();
 Serial.println (a);
 Serial.println (c);
 long x = a;
 long y = b;
 Serial.println (x);
 Serial.println (y);
}  // end of setup
void loop () { }
Output:
1/3 = 0.33
sqrt(2) = 1.41
1/3 = 0.33333333333333333333
sqrt(2) = 1.41421356237309504880
1/3 = 0
sqrt(2) = 2
By assigning to a long I have discarded the decimal places. You could convert that back to a BigNumber and subtract to get the decimal places alone.
ghlawrence2000
:smiley-roll-blue: Sorry Nick! I did not pick up on that point earlier...
Yes, it works fine! Many thanks...
G
nickgammon
Can you repost with code tags please rather than "copy for forum"? Things like subscripts don't work properly.
ghlawrence2000
Dont know how to do that, so I deleted the post, is that ok?
Sorry G.
nickgammon
Here:
The code was interesting, can you re-post it please?
Just copy the code directly from the sketch, (select all, copy), don't use the "Copy for Forum" "feature".
ghlawrence2000
#56
Aug 08, 2013, 04:10 pm Last Edit: Aug 12, 2013, 08:46 pm by ghlawrence2000 Reason: 1
If anyone else is as stupid as me?? this might help if you are trying to figure out cos and tan!
BigNumber cose (const BigNumber x, BigNumber precision)
 const BigNumber pi
   ("3.1415926535897932384626433832795028841971693993751058209749445923078164062862");
 BigNumber pidiv2 (pi / BigNumber(2));
 return (sine((x+pidiv2) , precision ));
} // end of function cose
BigNumber tane (const BigNumber x, BigNumber precision)
 BigNumber tan (((sine((x),precision) / cose((x),precision))));
 return tan;
That was how I implemented them anyway.
Also, I had a bit of a nightmare trying to implement LLtoNE in BigNumber format... If anyone else wants this, it is in the attachment.
Example output :-
Lat 53.121838, Lon -1.265120
Should give :- east 449174, north 358582
Lat 53.124981, Lon -1.298874
Should give :- east 446911, north 358909
Lat 53.144543, Lon -1.265869
Should give :- east 449098, north 361107
Over to you! Send Lat/Long pairs like this : 53.121838,-1.265120
            Send required Bignumber precision like this : #20
BigNumber precision changed to 8 digits
east 449174, north 358581
Time taken 582456 microseconds
BigNumber precision changed to 15 digits
Time taken 1652496 microseconds
BigNumber precision changed to 25 digits
Time taken 4398332 microseconds
That would be the bulk of the work required to implement Lat/Long to OSGB conversion for anyone that might be interested, WITHOUT needing to buy an Arduino DUE!!
However, just in case you need to justify to the missus, why you NEED a DUE, try this :-  :smiley-eek: ;)
Time taken 41125 microseconds
Time taken 103574 microseconds
Time taken 270292 microseconds
Ok so through experimentation 9 digits of precision is the minimum to achieve correct results, here are the performance figures for this function :-
Digits precisionMEGA2560DUE
90.689s0.048s
100.825s0.055s
151.652s0.104s
254.398s0.270s
:smiley-eek-blue: =(
I haven't understood how the "Arbitrary Precision" library works, is there any documentation about ?
Also, is there a real usage of this library ?
Yes!! This is one example! XD
I have also attached the natural 'DOUBLE' version of the same function. Depending on whether you have a DUE or not will reveal the weaknesses of single precision floats, particularly if you enter the same lat/long pairs used in the examples!
Cheers, G ;) :smiley-roll:
robtillaart
#57
Aug 09, 2013, 09:12 am Last Edit: Aug 09, 2013, 09:41 am by robtillaart Reason: 1
 const BigNumber pi
 return tan;
From performance point of view one could check for the Taylor series of the TAN(x), especially if you need it as much as in "GEO-math"
update:
- http://www.haverford.edu/physics/MathAppendices/Taylor_Series.pdf - note that tan(x)  has 2 series !
- http://mathworld.wolfram.com/MaclaurinSeries.html - includes formulas
Rob Tillaart
ghlawrence2000
#58
Aug 11, 2013, 09:06 pm Last Edit: Aug 11, 2013, 09:16 pm by ghlawrence2000 Reason: 1
Hello Rob,
Perhaps you over estimated how recently I had to consider maths of that level.... I have heard of Taylor series of course, but it is more years ago than I would like to recall!!  :smiley-roll-sweat: :smiley-eek-blue:
I will certainly look into implementing it when I get a bit of time.
Regards,
Graham
ghlawrence2000
#59
Aug 15, 2013, 08:49 pm Last Edit: Aug 16, 2013, 06:48 pm by ghlawrence2000 Reason: 1
Well, one could, and one did look into it, mmmm I think it is fine just the way it is (sin/cos).  :smiley-roll:
But thanks for the suggestion  :D
Regards,
Graham
Edit: I realised I am being a little slow on the uptake here..... But the implementation of SINE included in BigNumber library already IS Taylor series, thus figures that Sin(x)/Sin(x+90) is only slightly slower than 'native' Taylor Tan implementation? Not to mention I almost lost the plot trying to implement it... My 'native' Taylor series TAN implementation was massively slower than my original suggestion, so Rob, if you could post your solution, I would be interested to see it! Many thanks.
