Topic: [SOLVED] Problem with Arduino 1.0 IDE (Linux) and Blinking (Read 2791 times) previous topic - next topic
vito
Jan 04, 2012, 02:47 pm Last Edit: Jan 06, 2012, 02:41 pm by Vito Reason: 1
I'm using an Arduino UNO board and I've a problem with the Arduino 1.0 IDW (I'm using Slackware Linux).
In particular the Blinking of a Led doesn't work.
The code that I used is here:
Code: [Select]
// Example 01 : Blikning LED
#define LED 13 // LED connected to
             // digital pin 13
 pinMode(LED,OUTPUT); //sets the digital pin
                      //as output
void loop(){
 digitalWrite(LED,HIGH); //turns LED on
 delay(3000);            // wait 3 seconds
 digitalWrite(LED,LOW);  //turns the LED off
 delay(3000);
It worked on Arduino 0021.
Me(Slackware64) and another Arduino Linux user (Slackware) have the same problem.
We're using the Slacky.eu packages (I'm the mantainer of these packages).
I tried to use Slackbuilds.org packages but the problem remains the same.
With the 0022 version the problem can be solved with an:
Code: [Select]
#include "ArduinoTestSuite.h
but in the current version I didn't find this library.
Thanks of all!
madworm
So you're saying "It doesn't work" - whatever that actually means. That is not helpful.
The code you've posted compiles fine.
vito
Sorry, I forgot to explain what I mean with "doesn't work".
The code (as you can see) is correct,but the led doesn't blink!
It remains always HIGH.
madworm
#3
Jan 04, 2012, 04:45 pm Last Edit: Jan 04, 2012, 04:47 pm by madworm Reason: 1
So it hangs inside delay(3000);
The only reason for that would be that 'millis()' doesn't change, and that means that timer0 doesn't run.
Could you test:
Code: [Select]
 Serial.println(millis());
Also I should point out that some versions of avr-gcc seem unusable. I think 4.3.3 and 4.4.3 are good. Personally I have a self-compiled version using the build-script for linux, which can be found on avrfreaks.net
vito
#4
Jan 04, 2012, 05:49 pm Last Edit: Jan 04, 2012, 05:51 pm by Vito Reason: 1
The code works fine!
I can read the output in the serial monitor.
So,Could it be my version of GCC? (4.5.3)
I will try to downgrade it.
vito
same problem with 4.4.3 .
Now I try with 4.3.3 .
stimmer
This sounds like the binutils bug, if so you need to downgrade binutils (which might imply downgrading gcc too). Search the forum, lots of other people have had this problem and there are other ways round it (I think simply including the serial library cures it).
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
vito
Same problem with 4.3.3 .
I try to downgrade also binutils.
vito
With gcc 4.3.3 and binutils 2.20.1 the blinking works fine!
