Topic: Easy way to dim parallel LCD backlight with a photoresitor (Read 6495 times) previous topic - next topic
dtokez
Thanks DC, I don't understand exactly how the function is working but I understand the principles.
Also a bit confused as to what you mean by treating the open & short circuit cases separately?
I think maybe I need to add a case somehow for sensor reading = 0 and sensor reading = 1024?
Could I use an else - if function.. i.e. if reading is 0 = Lcd displays - sensor disconnected, else if reading is 1024 = Lcd displays - short circuit?
Thanks
Dan
dc42
Yes, that's what I had in mind, except that the max value you get from analogRead is 1023 not 1024. I was wrong when I mentioned sensor reading 1024 in my earlier post.
Rather than testing for == 0 and == 1023 you might want to test for <= 1 and >= 1022 or similar, because the ADC doesn't always produce exactly the reading you expect, especially if there is noise on the reference voltage.
dtokez
Thanks again DC!
I am just testing it out at the moment, I have a probe outside and I think its just below 0 right now according to another therm, but the arduino is reporting a solid 0?
How would I set it to display a decimal point ie 0.6c?
Here is what I have so far :)
The circuit:
* LDR connected to analog pin 0.
* LED / transistor connected from digital pin 3 to ground
* LCD RS pin to digital pin 7
* LCD EN pin to digital pin 8
* LCD D4 pin to digital pin 9
* LCD D5 pin to digital pin 10
* LCD D6 pin to digital pin 11
* LCD D7 pin to digital pin 12
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
* LCD LED+ (15) pin transistor
* LCD LED- (16) to ground
* Thermisor divider 1 output to analog pin 1
* Thermisor divider 2 output to analog pin 2
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the lDR is attached to
const int analogOutPin = 3; // Analog output pin that the LED is attached to
const int minLight = 100;        // at or below this light level, use minimum backlight intensity
const int maxLight = 900;       // at or above this light level, use maximum backlight intensity
const int minBacklight = 5;      // lowest backlight intensity to use
const int maxBacklight = 255;  // highest backlight intensity to use
// include the library code:
#include <LiquidCrystal.h>
#include <math.h>
double Thermister(int RawADC) {
  double Temp;
  Temp = log(((10240000/RawADC) - 10000));
  Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
  Temp = Temp - 273.15;            // Convert Kelvin to Celcius
  return Temp;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int sensorValue = 0;        // value read from the LDR
int outputValue = 0;        // value output to the PWM (analog out)
  // initialize serial communications at 9600 bps:
  lcd.begin(16, 2);
  delay(100);
  pinMode(13, OUTPUT);
  // read the analog in value:
  analogRead(analogInPin);
  delay(100);
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(constrain(sensorValue, minLight, maxLight), minLight, maxLight, minBacklight, maxBacklight );
  // change the analog out value:
  analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  // Temperature 1 print
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print ("Out: ");
  lcd.print(int(Thermister(analogRead(1))));
  lcd.print((char)223);
  lcd.print ("c");
  Serial.print ("Temp1=");
  Serial.println(int(Thermister(analogRead(1))));  // display temp
  // Temperature 2 print
  //lcd.setCursor(0,1);
  //lcd.print(int(Thermister(analogRead(2))));
  //lcd.print((char)223);
  //lcd.print ("c");
  //Serial.print ("Temp2=");
  //Serial.println(int(Thermister(analogRead(2))));  // display temp
  // wait 10 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
dtokez
#33
Feb 11, 2012, 02:03 am Last Edit: Feb 11, 2012, 03:04 am by dtokez Reason: 1
Been trying to get a decimal place by using fractions for a few hours, cant get it to compile though :(
The circuit:
* 10K resistor:
unsigned int frac;
#include <math.h>
 double Temp;
 return Temp;
 lcd.begin(16, 2);
 delay(100);
 delay(100);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print (".");
 frac = (Thermister(analogRead(1)) - int (Thermister(analogRead(1)) * 10;
 lcd.print(frac, DEC);
 lcd.print ("c");
 //lcd.print ("c");
dc42
Replace the line "lcd.print(int(Thermister(analogRead(1))));" by "lcd.print(Thermister(analogRead(1)), 1);".
dtokez
Thanks DC!
Is the , 1 instructing to display to 1 decimal place? Or is it still using the fraction bits?
dc42
Yes, when you pass a float or double to print() or println() then the second parameter is the number of decimal places you want printed. See http://arduino.cc/en/Serial/Print.
dtokez
excellent, thank you for the info.
I'm now trying to take an average temperature reading to try and eliminate some of the noise.
I am trying to get this code to compile but can't work out the problem, I might have it completely wrong I'm not sure :(
The circuit:
* 10K resistor:
#undef float
#define NUMSAMPLES 5
int samples[NUMSAMPLES];
#include <math.h>
double average(int RawADC) {
  double Temp;
  return Temp;
  lcd.begin(16, 2);
  delay(100);
  delay(200);
uint8_t i;
  float average;
  // take N samples in a row, with a slight delay
  for (i=0; i< NUMSAMPLES; i++) {
   samples[i] = analogRead(1)), 1);
   delay(10);
  // average all the samples out
  average = 0;
     average += samples[i];
  average /= NUMSAMPLES;
  //Temperature 1 print
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(average(analogRead(1)), 1);
  lcd.print ("c");
  //Serial.print ("Temp1=");
  //Serial.println(int(Thermister(analogRead(1))));  // display temp
  //lcd.print(int(Thermister(analogRead(2, 1))));
  //lcd.print ("c");
