Loading...
Pages: [1]   Go Down
Author Topic: Arduino Asterisk Parsing Error  (Read 828 times)
Offline Offline
Newbie
View Profile
Hello. I'm new to the forum, so i hope that i'm posting in the right place.
I'm currently working on an OSC pattern matching (similar to regex) for the Arduino. An important matching symbol is the ASTERISK ( * ). OSC messages are backslash delimited and when put a pattern like this for example:
Code:
OSCMessage.match("/*/?");
Even thought the "/*" is clearly in quotes, i get the error:
Code:
java.lang.RuntimeException: Missing the */ from the end of a /* comment */
at processing.app.Sketch.scrubComments(Sketch.java:1738)
at processing.app.preproc.PdePreprocessor.writePrefix(PdePreprocessor.java:105)
at processing.app.Sketch.preprocess(Sketch.java:1336)
at processing.app.Sketch.preprocess(Sketch.java:1288)
at processing.app.Sketch.build(Sketch.java:1570)
at processing.app.Sketch.build(Sketch.java:1552)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1954)
at java.lang.Thread.run(Thread.java:680)
I've tried alternates to the "/*" like "\u002A", but that also doesn't work. this seems like an IDE bug to me.
any work arounds would be greatly appreciated.
Logged
North Queensland, Australia
Online Online
Edison Member
View Profile
WWW
Not sure if it is error, but try a completely different approach until you work it out.
Code:
char c_In[] = { '/', '*', '/', '?', '\0' };
OSCMessage.match(c_In);
« Last Edit: January 04, 2012, 09:10:02 pm by pYro_65 » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Code:
OSCMessage.match("/" "*/?");
Should also work.
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
I've also found this error when constructing a HTTP 1.1 header
Code:
WiFly.println("Accept: */*");
Did it get reported to those who need to know?
Geoff
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Please check here...
http://code.google.com/p/arduino/issues/list
Logged
Brisbane, Australia
Offline Offline
God Member
View Profile
I didn't find it, so added Issue 817: Comment /* */ parsing should ignore these sequences in string constants,  hopefully it isn't a duplicate but if it is at least it's covered.
Cheers !
Geoff
Logged
Pages: [1]   Go Up
Print
Jump to:
