Topic: Equinox Clock (Read 6832 times) previous topic - next topic
SirPoonga
Cool project, it has given me an idea.
Now you need to combine it with a WWVB receiver so the time is always accurate.
http://www.ntp-time-server.com/wwvb-receiver/wwvb-receiver.htm
Found an arduino project that uses WWVB.
http://www.popsci.com/diy/article/2010-03/build-clock-uses-atomic-timekeeping
Chronoless
Quote
Easy for Chronoless, I assume it will.
Well, easy in the sense that the designing and engineering is done. Though it still is a lot of work. Especially the casing. However it's still a prototype and there is much that can be refined.
Thanks for the tips on the WWVB receiver. I considered using it before. But it would be DFC77 for Europe. However at that time I really wanted to see the final result and figured that a DS1307 RTC would be ok for this first proto.
Over the last few days I've received quite some mails from people interested in buying one. I'm now going to ask around to see what the possibilities are of producing a small series. But it's something I'll have to do next to my normal job :).
mowcius
Quote
Well if you can get the electronics done, I can do you the acrylic for a good price, PM me if you want.
Mowcius
SirPoonga
#33
Sep 09, 2010, 11:10 pm Last Edit: Sep 09, 2010, 11:15 pm by SirPoonga Reason: 1
My idea is to do something similar but the hour hand would light up on the inside of circle so it is more obvious what is minute and what is hour.  Actually, I will probably not do a loop design, but something with frosted glass/plexi.
I would like to add a date and day of week indicators also, I will have to think about how to do that creatively.  Alphanumeric segment LEDs take up a bunch of pins, correct?  any good way of accessing several of those on an arduino?
I might have a bunch of TLC5947s left over from my current project...
mowcius
Quote
Acrylic offer applies to anyone ;)
SirPoonga
Quote
I don't need any more projects delayed because of customs :)
mowcius
Quote
Yeah it can be a bit of a pain  :(
florinc
Chronoless, I don't know if you heard of kickstarter.com, but I think your equinox clock could enjoy unbridled success.
You can count on me as a contributor.
FlorinC
defsdoor
Wonder how much easier a project like this would be to make using SPI controllable LEDs such as these from bliptronics.
http://www.bliptronics.com/item.aspx?ItemID=114
60 of theses would come in at 70-80UKP for the LEDs but require no additional circuitry - just 4 wires.  I've got a bunch of the 20mm ones and they are very nice (christmas lights project which will ultimately become mood lighting for above the bedroom wardrobes).
I'm seriously considering having a go - perhaps a thick MDF backplate routed out with space for enough gap for mounting the LEDs and the "lenses" and a nice black acrylic face plate.
If only I didn't have a job and wife to maintain - I'd be in the garage right now :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
