Pages: [1] 2   Go Down
Author Topic: % Division in USART interrupt code...  (Read 2382 times)
Function store_char() (in HardwareSerial.cpp), called from USART interrupt, use % division, which is mutch slower (208 ticks, as i measure), than & operation. If divider is power of 2, why not use & ?
For example:
#define SERIAL_BUFFER_SIZE  64
int i = (unsigned int)(buffer->head + 1) % SERIAL_BUFFER_SIZE;
are equal to:
int i = (unsigned int)(buffer->head + 1) & (SERIAL_BUFFER_SIZE - 1);
ruggedcircuits.com
The GCC compiler is pretty smart and it should convert the % to & automatically during its optimization phase. Try it: I bet the code generated will be the same size with both approaches (as long as the modulus is a power of 2).
Knowing this, it's always better to write clear(er) code than to prematurely optimize it.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Seattle, WA
Just way less readable and maintainable, in a pretty significant way.  Only worth this kind of optimization in cases where serial performance was the bottleneck.
Seattle, WA
Ah yes, this is right, too.
int main(void)
 SPDR = SPDR % 64;
00000080 <main>:
  80:   8e b5           in      r24, 0x2e       ; 46
  82:   8f 73           andi    r24, 0x3F       ; 63
  84:   8e bd           out     0x2e, r24       ; 46
« Last Edit: January 05, 2012, 04:46:31 pm by maniacbug » Logged
Hm... Very strange.
Yes, your code do not generate any divisions.
But when a compile simple sketch:
void loop() {}
and do (on Windows):
c:\BIN\Arduino\arduino-1.0\hardware\tools\avr\bin\avr-objdump.exe -d test123.cpp.elf
i get:
00000162 <__vector_19>
 162:   1f 92          push   r1
 164:   0f 92          push   r0
 1bc:   01 96          adiw   r24, 0x01   ; 1
 1be:   60 e4          ldi   r22, 0x40   ; 64
 1c0:   70 e0          ldi   r23, 0x00   ; 0
 1c2:   0e 94 34 03    call   0x668   ; 0x668 <__divmodhi4>
Maybe, this code is from another place... I don't know assembler wery well...
I try to do simple audio recorder from the arduino uno (just for fun and training).
I programmed Timer2 for generate interrupts at 16KHz (every 62.5uS) and set ADC prescaler to 64
(so, ADC conversion must take 52uS). But sometymes, ADC don't have to complete previous conversion, when the next interrupt occurs.
I think, it is because other interrupts brings a time jitter to time, when Timer2 interrupt handler raise...
Thank you, for your quick response!
« Last Edit: January 05, 2012, 09:50:35 pm by llevinson » Logged
Dallas
Shannon Member
You know it well enough.  That's a problem.
Dallas
Shannon Member
• Open HardwareSerial.cpp
• At or near line 206, change this...
  tx_buffer.tail = (tx_buffer.tail + 1) % SERIAL_BUFFER_SIZE;
...to this...
  tx_buffer.tail = (unsigned int)(tx_buffer.tail + 1) % SERIAL_BUFFER_SIZE;
• At or near line 230, change this...
  tx_buffer1.tail = (tx_buffer1.tail + 1) % SERIAL_BUFFER_SIZE;
...to this...
  tx_buffer1.tail = (unsigned int)(tx_buffer1.tail + 1) % SERIAL_BUFFER_SIZE;
• At or near line 247, change this...
  tx_buffer2.tail = (tx_buffer2.tail + 1) % SERIAL_BUFFER_SIZE;
...to this...
  tx_buffer2.tail = (unsigned int)(tx_buffer2.tail + 1) % SERIAL_BUFFER_SIZE;
• At or near line 264, change this...
  tx_buffer3.tail = (tx_buffer3.tail + 1) % SERIAL_BUFFER_SIZE;
...to this...
  tx_buffer3.tail = (unsigned int)(tx_buffer3.tail + 1) % SERIAL_BUFFER_SIZE;
• At or near line 385, change this...
  int i = (_tx_buffer->head + 1) % SERIAL_BUFFER_SIZE;
...to this...
  int i = (unsigned int)(_tx_buffer->head + 1) % SERIAL_BUFFER_SIZE;
• Save and close HardwareSerial.cpp
Basically, put "(unsigned int)" in front of every expression that includes "% SERIAL_BUFFER_SIZE".
Dallas
Shannon Member
And, as a nice side-effect, the entire ISR is much smaller.
Seattle, WA
Sounds like someone needs to submit a patch smiley-grin
Dallas
Shannon Member
http://code.google.com/p/arduino/issues/detail?id=776
Seattle, WA
Nice.  Although if you actually attach a patch file, I think it increases the odds of it getting in...
SF Bay Area (USA)
Strongly opinionated, but not official!
patch attached.  I actually had this almost ready based on the discussions over in:
http://arduino.cc/forum/index.php/topic,85207.0.html
Dallas, TX USA
And "while you are in there", why not modify the code to use 8 bit variables
for head and tail? It saves hundreds of bytes of code to do this.
It is one of the first things I change on every single Arduino release.
And if you are worried about somebody making SERIAL_BUFFER_SIZE larger than 256 then
that can also be handled compile time with a #if to change back to using ints.
Example:
struct ring_buffer
  unsigned char buffer[SERIAL_BUFFER_SIZE];
#if SERIAL_BUFFER_SIZE > 256
 volatile int head;
 volatile int tail;
#else
 volatile uint8_t head;
 volatile uint8_t tail;
#endif
But in the bigger picture, larger than 8 bit indexes won't really work anyway because the code that uses
it does not properly deal with atomicity of the 2 byte value when doing things like compares.
So it might as well be an 8 bit value anyway since 16 bit (multi byte) values will have issues when
the value is larger than 255.
--- billl
Interesting, this is just a regression in1.0, I checked my 0022 HardwareSerial and all the buffer size lines are properly cast.
Pages: [1] 2   Go Up
