Topic: RGB leds and resistors (Read 1 time) previous topic - next topic
Zeratus
Jan 06, 2012, 04:00 pm Last Edit: Jan 06, 2012, 04:14 pm by Zeratus Reason: 1
I was wondering: what happens if I put the resistor on the cathode instead of using 3 resistors for each color anode?
1 Resistor:
3 Resistors:
I'm asking this because it's a pain to place one resistor for each anode. Is this the only solution?
Also, I'm intrigued by the fact that a lot of tutorials about LEDs talk about using a 220 ohm resistor. Why? Even for a red LED consuming 25 mA, the required resistor for running it on a 5V line(that's what Arduino provides, right?) is only 120 Ohms.
So what should we do today?
487376
You don´t calculate good. For all colours must be used individual resistor. And a resistor value can´t be less than 200 ohms! ;)
Grumpy_Mike
#2
Jan 06, 2012, 07:55 pm Last Edit: Jan 06, 2012, 07:58 pm by Grumpy_Mike Reason: 1
Quote
Then it won't work. Once you put the red LED on then the others won't come on because the red LED clamps the voltage at a lower value than is needed to turn on the other colours.
Quote
Most LEDs work at 20mA not 25mA. Yes you can use a lower resistor but most LEDs are good enough at between 10 to 15mA
Zeratus
Quote
Quote
Well, that makes sense. Thanks for the response. It's a pain to work with so many resistors :(.
Quote
That's quite some news to me, I always calculated resistors for the 20mA-30mA range. Isn't 10 mA too low though? Won't the LED be too dim?
Grumpy_Mike
Quote
No, the eye's response is logarithmic so it is much less than half as bright.
Most LEDs are only speced at 20mA so I think you are over driving them.
