Offline
Full Member
« on: January 06, 2012, 02:54:39 pm » |
Hello,
I'm looking for a service that could manufacture 200+ double sided PCB's and solder the SMD components (both sides) in place.
What's the cheapest?
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #1 on: January 06, 2012, 03:00:57 pm » |
Where are you located? What is the size and complexity of the boards? Do they need to be surface mount? If so, how many and what size components? Do you want solder paste & silkscreen? 1-side, 2 sides? Do you want them electrically tested for continiuty or shorts? All of them? Some percentage of them?
Logged
Offline
Full Member
« Reply #2 on: January 06, 2012, 03:50:18 pm » |
Where are you located? Between the weed and strippers (the netherlands)What is the size and complexity of the boards? 22mmx13mm don't know the complexity, look for yourself:  Do they need to be surface mount? If so, how many and what size components? Component list: -QFN32 SMD IC -MIC5205 -2x 10uF (1206) -4x 0.1uF(0603) (from which 2 are mounted on the bottom) -2x 10K (0603) -1x 330 Ohm (0603) -One of those tiny 16Mhz 3 pad crystals with built in 22pF caps. You might have already guessed it but it's a arduino clone based on the Pro Mini Do you want solder paste & silkscreen? 1-side, 2 sides? Yes. The components are all SMD and most of them are at the top, some at the bottom. Do you want them electrically tested for continiuty or shorts? All of them? Some percentage of them? Yes, at least a couple need to be tested, not a lot.
Logged
Global Moderator
Offline
Brattain Member
« Reply #3 on: January 06, 2012, 04:05:39 pm » |
Will look when I get home, can't open from here...
Logged
Global Moderator
Offline
Brattain Member
« Reply #4 on: January 06, 2012, 04:15:53 pm » |
"Between the weed and strippers" Had to think about that a while  I'm thinking you are referring to Amsterdam.
Logged
Offline
Full Member
« Reply #5 on: January 06, 2012, 04:26:39 pm » |
"Between the weed and strippers" Had to think about that a while  I'm thinking you are referring to Amsterdam. Good guess! Actually meant Holland , not specifically Amsterdam. I can drive to Amsterdam in 30 mins. though.
Logged
Global Moderator
Offline
Brattain Member
« Reply #6 on: January 06, 2012, 04:30:05 pm » |
Yes, but I didn't know how pervasive the 'culture' was. I've only been to one of the coastal towns, in offseason for an electronics convention, and didn't see any of that.
Logged
Offline
Full Member
« Reply #7 on: January 06, 2012, 04:34:49 pm » |
I've also actually never seen the "rode ruiten"(=red windows) in Amsterdam.
Been shopping for electronics parts there though. It sucks Holland doesn't have a lot of stores like Radioshack etc. And when we order something from Mouser shipping is more than $26!
Logged
Offline
Full Member
« Reply #9 on: January 06, 2012, 04:54:03 pm » |
Yes, the components are more expensive then mouser and shipping even worse.
I hate the fact that mouser has a NL domain with components more expensive then the .com while they come from the same warehouse...
Logged
Global Moderator
Offline
Brattain Member
« Reply #10 on: January 07, 2012, 12:47:28 am » |
Well, if you have the gerbers & a PL, I bet you could have a place like iteadstudio.com quote building those for you. It's a good qty, more than I'd want to hand assemble. Probably still get hosed on VAT tax.
Logged
Colorado
Offline
Edison Member
Reviving dead brain cells with Arduinos.
« Reply #11 on: January 07, 2012, 04:28:18 am » |
If you can move all the components on one side of the board, you should be able to do your own skillet reflow soldering. I do it all the time. Last project I did was 350 tiny boards. Took the better part of a week, but it wasn't too hard. Like I said, to make it easy, you want all the parts on the same side of the board.
Not using any specific parts, just general/generic ones, the individual cost if purchased through Digi Key would be around $3.62 $3.85. With PCB service through ITeadStudio, add another 25 cents each. And I would strongly suggest getting stencils made ... $25 for 6-up on a single 8.5 x 11 sheet.
I should note, the pricing I looked at were for bulk purchases of 250, 500, and 1,000 pieces. In some cases it's cheaper to purchase 1,000 of something than it is to buy 800.
Your design doesn't seem to have an ISP header broken out (or if it does, it's not in the standard 2x3 configuration). You're going to need that to put a bootloader on the board (if you're planning to run Arduino on it), or to burn sketches directly to the board. Might also be worth it to break out the FTDI pins if you haven't already.
As CR mentioned, chances are you will get nailed with VAT when you get them. But, if you think you'll be ok, and you want to provide parts (or the money to procure them), I'm happy to cook them for you with the only requirement that you move the parts top-side only.
« Last Edit: January 07, 2012, 04:32:35 am by KirAsh4 »
Logged
Offline
Full Member
« Reply #12 on: January 07, 2012, 02:05:31 pm » |
Since i'm a student and i'm busy with school a lot i can't spend that much time. I am making an arduino based reflow oven controller for the first prototype batch (about 10 boards).
Logged
Offline
Full Member
« Reply #13 on: January 07, 2012, 02:18:37 pm » |
Nope, ISP is not broken out but i'm planning on making a simple board that has all the pins broken out to standard 2.54mm header pins and that adds ISP header. FTDI pins are already broken out though.
Logged
Colorado
Offline
Edison Member
« Reply #14 on: January 07, 2012, 04:55:28 pm » |
If you'd like, and are willing to share your design, I can attempt to re-route them to the top layer. But that's entirely up to you and would of course depend on whether you want to do that and/or want to figure out if it is worth the cost to have them outsourced, or if you want to do them yourself.
Logged
