Loading...
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Arduino as Capacitive Sensor  (Read 6946 times)
0
Offline Offline
Sr. Member
dinosaur cork
View Profile
WWW
Some experiments with the Arduino as a capacitive sensor. All it requires is a 10 M resistor and a piece of wire. I was able to sense a hand about four inches from my 1.5" sq aluminum foil sensor.
Included are some machine code and port manipulation and an easy smoothing filter.
// CapSense.pde
// Paul Badger 2007
// Fun with capacitive sensing and some machine code - for the Arduino (or Wiring Boards).
// Note that the machine code is based on Arduino Board and will probably require some changes for Wiring Board
// This works with a high value (1-10M) resistor between an output pin and an input pin.
// When the output pin changes it changes the state of the input pin in a time constant determined by R * C
// where R is the resistor and C is the capacitance of the pin plus any capacitance present at the sensor.
// It is possible when using this setup to see some variation in capacitance when one's hand is 3 to 4 inches from the sensors
// Try experimenting with larger sensors. Lower values of R will probably yield higher reliability.
// Use 1 M resistor (or less maybe) for absolute touch to activate.
// With a 10 M resistor the sensor will start to respond 1-2 inches away
// Setup
// Connect a 10M resistor between pins 8 and 9 on the Arduino Board
// Connect a small piece of alluminum or copper foil to a short wire and also connect it to pin 9
// When using this in an installation or device it's going to be important to use shielded cable if the wire between the sensor is
// more than a few inches long, or it runs by anything that is not supposed to be sensed.
// Calibration is also probably going to be an issue.
// Instead of "hard wiring" threshold values - store the "non touched" values in a variable on startup - and then compare.
// If your sensed object is many feet from the Arduino Board you're probably going to be better off using the Quantum cap sensors.
// Machine code and Port stuff from a forum post by ARP  http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169088394/0#0
int  i;
unsigned int x, y;
float accum, fout, fval = .07;    // these are variables for a simple low-pass (smoothing) filter - fval of 1 = no filter - .001 = max filter
  DDRB=B101;     // DDR is the pin direction register - governs inputs and outputs- 1's are outputs
  // Arduino pin 8 output, pin 9 input, pin 10 output for "guard pin"
  //  preceding line is equivalent to three lines below
  //  pinMode(8, OUTPUT);     // output pin
  //  pinMode(9, INPUT);      // input pin
  //  pinMode(10, OUTPUT);    // guard pin
  digitalWrite(10, LOW);  //could also be HIGH - don't use this pin for changing output though
  y = 0;        // clear out variables
  x = 0;
  for (i=0; i < 4 ; i++ ){       // do it four times to build up an average - not really neccessary but takes out some jitter
    // LOW-to-HIGH transition
    PORTB = PORTB | 1;                    // Same as line below -  shows programmer chops but doesn't really buy any more speed
    // digitalWrite(8, HIGH);
    // output pin is PortB0 (Arduino smiley-cool, sensor pin is PortB1 (Arduinio 9)
    while ((PINB & B10) != B10 ) {        // while the sense pin is not high
      //  while (digitalRead(9) != 1)     // same as above port manipulation above - only 20 times slower!
      x++;
    delay(1);
    //  HIGH-to-LOW transition
    PORTB = PORTB & 0xFE;                // Same as line below - these shows programmer chops but doesn't really buy any more speed
    //digitalWrite(8, LOW);
    while((PINB & B10) != 0 ){            // while pin is not low  -- same as below only 20 times faster
      // while(digitalRead(9) != 0 )      // same as above port manipulation - only 20 times slower!
      y++;
    delay(1);
  fout =  (fval * (float)x) + ((1-fval) * accum);  // Easy smoothing filter "fval" determines amount of new data in fout
  accum = fout;
  Serial.print((long)x, DEC);    // raw data - Low to High
  Serial.print( "   ");
  Serial.print((long)y, DEC);    // raw data - High to Low
  Serial.print( "   ");
  Serial.println( (long)fout, DEC); // Smoothed Low to High
« Last Edit: February 09, 2007, 10:28:50 pm by paulb » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
hi, I tried to make your code work but no chance  :'(
I am using a 3.3M resistor and I don't have a clue  :-/
Here is a picture:
The white cable has a piece of copper ( 4x3cm ) at the other end.
I am new to arduino so you might find me quite silly. I was planning on using a qt but if your technique works it's better.
Thank you for your time and contribution to arduino.
« Last Edit: September 16, 2007, 12:42:01 pm by TM » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Hi again, I am really confused  :-?
I just changed the cable position. I moved the cable connected to pin9  and the white cable on the line above. Then I linked the 2 lines with the resistor and now It works !!!!!
I put a picture for the newbies like me ( and documentation ) smiley
I am sorry for all this, hope that at least it will help others. It must be really silly the way I have done it in the first place. I really need to learn the basics.
Great code by the way, thanks for that !!!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
I really enjoying your technique !!! It's brilliant !!!  smiley-grin
It's going to work perfectly for our project. If you are in the UK and not far from Brighton at the beginning of November, It would be a pleasure to see you at the private view. Here is a link to the website for more info : http://www.sonicbody.co.uk
Thanks again.
« Last Edit: September 16, 2007, 01:29:07 pm by TM » Logged
0
Offline Offline
Sr. Member
View Profile
If you're curious, the reason it didn't work in your first picture is because you basically bypassed the resistor and your white wire and simply had 8 and 9 connected to each other.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Hi, I've been thinking about what you said. Is it because the two legs of the resistor are on the same line so the two legs are connected together instead of having the two legs separated?
Anyway,Thanks for your previous explanation.
Logged
0
Offline Offline
Sr. Member
View Profile
That is correct.  Good luck with your project  smiley
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi
I've been trying to do this but I can't get it to work.. Wired everything up as on the photo and then ran the program but nothing happened. Can you give a description on how to do this currectly since I apperently do something wrong.
thanx
//Mads
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Hi, did you find what was wrong ?
I am not a expert so I can't really help.
Are you following the second picture?
Maybe your resistor is not the good one, if it's to low it won't do anything.
Maybe your sensor is wrong. Try with copper or aluminium foil ( like in the one in your kitchen ).
Also, I used the commented part of it instead of the 'PORTB' thing.
Here is my code, it's really a quick one just for testing. The 'activation' thing with untouched and store as to be better. I am wondering between the difference between two person or a same person after a different day. It seems that somedays I have more electricity in my body then other days.
I haven't test with the original code again as I am looking into the multiplexer now.
Code:
// CapSense.pde
// Paul Badger 2007
int  i;
unsigned int x, y;
int ledPin = 5;   // select the pin for the LED
float nonTouched, store = 0;
  //DDRB=B101;     // DDR is the pin direction register - governs inputs and outputs- 1's are outputs
  pinMode(5, OUTPUT);
  analogWrite(ledPin,255);
  delay(10);
  analogWrite(ledPin,0);
  x = 0;
    //PORTB = PORTB | 1;                    // Same as line below -  shows programmer chops but doesn't really buy any more speed
    // output pin is PortB0 (Arduino 8), sensor pin is PortB1 (Arduinio 9)
    //while ((PINB & B10) != B10 ) {        // while the sense pin is not high
    while (digitalRead(9) != 1) {    // same as above port manipulation above - only 20 times slower!
      x++;
    delay(1);
    // PORTB = PORTB & 0xFE;                // Same as line below - these shows programmer chops but doesn't really buy any more speed
    //while((PINB & B10) != 0 ){            // while pin is not low  -- same as below only 20 times faster
    while(digitalRead(9) != 0 ) {     // same as above port manipulation - only 20 times slower!
      y++;
    delay(1);
  accum = fout;
  store++;
  if (store<50) {
    nonTouched = fout;
  if (store>50){
    store = 50;
  Serial.print( "   ");
  Serial.print( "   ");
  Serial.print( (long)fout, DEC); // Smoothed Low to High
  Serial.print( "   ");
  Serial.println( (long)nonTouched, DEC); // Smoothed Low to High
  if (fout>nonTouched+3){
  else{
Apart from that can't really help. Good luck
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Looks cool.. :-)
And thanx for the help so far.. But I have one problem and that is that the file is to big to fit on the Arduino board. Why can this be??
I will tell you more about the process of the project later...
Thanx
//Mads
Logged
SF Bay Area (USA)
Online Online
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
The floating point used will presumably add quite a bit of code to a sketch...
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
So what can I do about  that? I'm really newbie to this.. Learning as I go..
Thanx for your time and help
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Strange, maybe you have a older version of the arduino. I looked at mine and I still have plenty of space left after uploading the code. Weird.
It could the float variable like westfw said but that I would find this strange. That would mean you are very very limited then. Try without the two variable I added, so at least you could see something in the Serial Monitor if that's the problem. It's the button next to the Upload one. Upload your code, when done click this button and wait a few second.
Code:
// CapSense.pde
// Paul Badger 2007
int  i;
unsigned int x, y;
  pinMode(5, OUTPUT);
  delay(10);
  x = 0;
      x++;
    delay(1);
      y++;
    delay(1);
  accum = fout;
  Serial.print( "   ");
  Serial.print( "   ");
Good Luck.
« Last Edit: September 27, 2007, 03:24:17 am by TM » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I fixed the problem with size.. Was working in an old version of Arduino - so now it's no prob.
But I don't seem to get any signal, numbers or anything out..
What could be the problem?
Thanx for your time
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
I think you have wired correctly. Do it like on the second picture. On yours, the pin8 and 9pin are not connected as they are on 2 seperated parts. The 2 two parts are not connected. See what I mean?
Logged
Pages: [1] 2 3 ... 5   Go Up
Print
Jump to:
