Topic: not understanding 7 segment multiplexing (Read 9526 times) previous topic - next topic
magnethead794
Are you putting down discrete pads vs chip symbols? Makes it hard to follow what you are doing.
Pic's are coming thru nice.
not sure exactly what you mean?
and I'm printing to A0 paper PDF as ~4x scale or so then converting to jpg.
KF5RVR
CrossRoads
Here's what I mean.
I layed out 10 LEDs, 2 resistors, a connector.
The board layout looks like it.
Yours just looks like a bunch of holes that are connected, can't tell what it is.
magnethead794
#47
Jan 11, 2012, 07:36 am Last Edit: Jan 11, 2012, 07:57 am by magnethead794 Reason: 1
Here's what I mean.
I'm a beginner so you have to bear with me learning my way through eagle.
so if I go per http://arduino.cc/en/Tutorial/ArduinoToBreadboard minimalist approach and don't use a resonator/crystal, it will function at 1 MHz, right?
so 9600bps serial in code will actually be 9600/16 = 600bps?
If board space gets tight, I may need that extra little bit of space in leu of resonator. Didn't realize how hard it was going to be to fit all this stuff on a 2" square board. I'm gonna see how far I can get.
KF5RVR
CrossRoads
I am not sure, I have not operated at other than 16 MHz in my designs.
magnethead794
I tallied it up. I can buy SF's small indicator cheaper than I can build it, when you calculate time. Maybe they'll have a new revision with mounting holes, if not, I came up with a mounting method. I thought about it, and having a 10K resistor on the VCC line shold somewhat make up for not having on on each digit supply.
KF5RVR
magnethead794
Here's where KirAsh and I landed. Only have to make 2 boards. Use the sparkfun board for indication, and use the selector board to run the Tx to the indicator and SPI to the shift registers. On the shift boards, the first one gets +12/+5/gnd through a 3 position terminal block, SPI over the Cat5, then it all gets passed on from pin headers.
http://i1105.photobucket.com/albums/h355/magnethead494/shift_board_brd.jpg
http://i1105.photobucket.com/albums/h355/magnethead494/shift_board_sch.jpg
http://i1105.photobucket.com/albums/h355/magnethead494/dial_board_selector_brd.jpg
http://i1105.photobucket.com/albums/h355/magnethead494/dial_board_selector_sch.jpg
KF5RVR
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
