Author Topic: What is arduino Uno's ADC input Current Min and Max?  (Read 732 times)
What is arduino Uno's ADC input Current Min and Max? Is the input min 40mA?
Newcastle, England
Always learning!
The inputs all have a very high resistance, so it will only draw a very small current. In order to draw more current, it must be at a higher voltage. Anything above 5V and it will be damaged.
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) smiley-grin
Washington
Firefox & Arduino rocks
They are high impedance input and will draw only uA.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
South Texas
The ADC inputs are voltage sensing, and not current sensing. They are high impedance and will put little load on a circuit. The do not sink, they just sense. They do not draw any current, they sense voltage.
They have a MAX of 5V DC. If you need to sense a higher voltage you will need to make a voltage divider using a couple resistors in series.
Austin, TX
CMiYC
Min is about 0V and max is about whatever VCC is set to.
Analog in and probably tolerate 40mA.  However, since AnalogIn is a voltage measurement, the question of why such high current needs to be asked.
www.cmiyc.com - A guide to being an Enginerd
Washington
Also the analog pins can source/sink current if set as output in software.
pinMode(A1, OUTPUT);
In such case, their current capacity is the same as the other digital pins, 40ma absolute max <30ma recommended.
Resistors for LEDS!
Manchester (England England)
Online Online
Solder is electric glue
The minimum current is 0uA the maximum is 1uA as specified in the data sheet Section 28 under input leakage current.
