Topic: Personnal Messages down (Read 6081 times) previous topic - next topic
superlol
that's funny:
everytime they try to upgrade something (see old yabb to new SMF forum) goes wrong (hoster, software or hardware problems)..
anyway i think (hope) the arduino team is working hard for fixing this problem  ;)
http://www.aug-altogarda.it/ <- Il nuovo AUG per basso trentino e dintorni!
David Cuartielles
Hej guys,
I am sorry for the silence when it comes to this ... we have been very busy with the server upgrade, implementing  a new backup system, etc. This issue has of course priority and we will try to fix it during today.
Again, I am really sorry for the inconvenience and I should be the one to blame for this ...
If it helps in any way, thing is you guys were lasting an 8 cores computer to the point that it was impossible to even list a directory, therefore we had to make sure we had a proper machine to run the forum before we could go into fixing mode.
Things will be much much better from now on.
/d
David Cuartielles
madworm
#18
Jan 16, 2012, 12:27 pm Last Edit: Jan 16, 2012, 12:28 pm by madworm Reason: 1
Thanks!
Just out of curiosity, what are the specs of the new machine. Hardware, file-systems, OS ...
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
David Cuartielles
Hej,
as taken from the ServInt website:
Solo Pro 1260
Quad Core Xeon® X3450 Processor *
4 x 2.66 GHz HyperThreaded Cores
8 MB L3 Cache, 1333 MHz FSB
12 GB 1333MHz DDR3 Memory
650 GB Usable Storage
Serial ATA Storage in RAID 1
8 TB Monthly Transfer
Full Specs
100 Mbps Uplink Port
4 IP Addresses
CentOS 5 or 6, 32 or 64-bit
Unlimited Domains and User Accounts
FREE cPanel or Parallels® Plesk Panel
FREE Daily Off-Server Backups
/d
David Cuartielles
Just made a blog post on this matter:
http://arduino.cc/blog/2012/01/16/arduino-servers-or-why-were-slow/
ajofscott
We forgive you David! This time!;)
Nick Gammon
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
A dozen times tonight. A week after the upgrade.
Have you considered changing to more competent service providers? Seriously.
More info:
df6ih
Thank you Nick for speaking out what I was thinking all through this European Morning.......
