Topic: Speedometer calculation (Read 9301 times) previous topic - next topic
Nishant_Sood
Jan 08, 2012, 07:42 am Last Edit: Jan 08, 2012, 07:45 am by Nishant Reason: 1
The Radius of the front wheel is 30cm so i calculated the circumference 2pieR  to have it as 188.4 cm or 1.884 meters means in 1second it will cover a distance of 1.884 meters and the speed would be calculated by multiplying number of revolutions in 1 sec with 1.884 x 3600/100 thus the equation becomes as follows:
N × 6.784 or N × 6.8
SO I WANT TO KNOW THE WAY IN CODE TO HAVE THE VALUE OF "N"?(i'm using a hall effect sensor or a reed switch)
AND,
also i want to use the same magnet that is used by the speedometer wire so how should i mount the hall sensor or reed switch near it?
This is a link to the image of speedometer assembly with the bikes front wheel
http://winacro.com/images/stories/DSC_0044.JPG
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
ok i got that the number of times the reed switch or Hall sensor crosses the magnet it will get me the value of "N" now its left that where to mount this reed or hall nearby or in the speedometer console?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
robtillaart
If the magnet is on the wheel , you must place the hall sensor in such a place that the magnet passes the hall sensor as close as possible (but not closer!).
The best way to count the pulses is to use interrupts - see reference section of this site.
Furthermore you could get more precission by attaching more magnets on the wheel as you will get more pulses per rotation. Use an unsigned long as counter to prevent quick overflow.
Also worth trying is to make a speedo meter of your front wheel and of your back wheel. You will see that they will differ in value, up to you what is the right value, the front the back or something in between?
Succes
Rob Tillaart
AWOL
Remember also that the further from the axle, the faster the magnet will be travelling, and so the shorter the pulse.
This doesn't normally matter if you're using interrupts, but may make a difference if you're polling.
Nishant_Sood
i wrote a program without interrupts but that is more or less half utilizing as its value will never be less than 6.8 (as bcz of this equation Nx6.8) and it will never increment like it does like 10-11-12-13-14-15km/hr and so on.
can you guys help me with an example and how will polling help?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
The program i have till now goes like (N x 6.8) 1 x 6.8=6.8km/hr, 2x6.8= 13.6km/hr and so on but the increments should be like 1km/hr then 2km/hr then 3km/hr and so on
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
robtillaart
Please post your code you have sofar.
Rob Tillaart
Nishant_Sood
long prevoiusMillis = 0;
Const int inputPin = 8;//input from the Hall Sensor/reed switch
int lastButtonState = LOW;
long interval = 1000;  // the amount of interval lag wanted
void Setup() {
pinMode(inputPin, INPUT);
Serial.begin(19200);
int reading = digitalRead(inputPin);
while(reading != lastButtonState) {
int m = m++;
if(currentMillis - previousMillis > interval) {
    previousMillis = currentMillis;
    Compute();
    m=0;
void Compute() {
float n = m * 6.8;
float kmh = n; //the final km/hr value
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
PaulS
But first, make sure it at least compiles.
AWOL
And that Compute does something useful.
Nishant_Sood
I actually wrote that code in a copy bcz i want to give you guys an idea that where im going so anyone of you can show me a correct way however the code is follows which is too much extent correct:
long previousMillis = 0;
const int inputPin = 8;//input from the Hall Sensor/reed switch
int m;// variable to hold pulses
void Setup() {
unsigned long currentMillis = millis();
  m = m++;
    float n = m * 6.8;
    m=0;
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
also its worth defining here that i replied a lot late bcz something was there that was causing a BIG BIG problem so i wasn't able to login in and according to me that went for more than 10hours the problem with arduino site started with DB errors and 404 errors then accessing the site after logging in was not possible!
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
PeterH
  m = m++;
What is this code fragment intended to do? I don't see any way for reading or lastButtonState to change once you have entered the while loop.
PaulS
One letter global variable names are not recommended. How does one associate m with pulse count. Now, pulseCnt or pulseCount would be easy to associate with pulse count.
Along with PeterH's question (which is probably the crux of your problem), I'd ask what the currentMillis variable is for. It is local, so it isn't accessible outside of loop().
Generally, if you want to create a speedometer, you separate the counting of pulses from the sensor from the use of pulse count. That is most easily done by connecting the sensor to pin 2 or 3, and defining an interrupt service routine to be called when the sensor is triggered. That ISR then just counts pulses (in a properly named volatile global variable).
The loop() function then just keeps track of time, and periodically checks how many pulses have occurred, computes the speed, and resets the counter (not necessarily in that order). How often to check depends on what type of counter you are using (byte, int, long) and how long it takes that counter to overflow (you do not want that to ever happen).
Nishant_Sood
Yes you both are correct i just wanted to get my idea down on paper and that
]unsigned long currentMillis = millis();
  m = m++;
intends to increment the variable to give me number of revolutions in a second(interval value) for this equation kmh = n * 6.8
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
