Hi guys, i am implementing the IRDA stacks... i have downloaded documentation from
www.irda.org and i have started implementing irPHY layer... the only physical layer that arduino can handle without any other IC is the IrSIR (substantially an UART with very short impulses).
I make some test, and i can send out from any pin the correct sequence of pulses at the correct timing, and this train is correctly detected from a standard irda port on my laptop. I have attached only an IR LED and a resistor to the output pin of my arduino.
On the receiving side, i have connected an IR Transistor, with an NPN transistor that squares the receiving signal... i am trying to detect the incoming pulses but it seems to be too fast... i need your opinion to evaluate if continue with the project or if it is not feasible.
The incoming train, is an asynchronous frame, very similar to an RS232 frame: one start bit (0), 8 bit of data, no parity, 1 stop bit (1);
So if the byte of data is for example 11001100, the train look like this:
DATA
0 1 1 0 0 1 1 0 0 1
start bit stop bit
IR Beam
IR *** *** *** *** ***
NO-IR *** *** ********* ********* *** *** *** *** ********* ********* *** *** *** *** *********
The 1's bit is not transmitted at all, the 0's is transmitted as a single pulse of 3/16*baudrate duration. Just for clarify, if the baudrate is 9600, the pulse width is 19,53us.
I am using for digital pin 2 for receiving, so i use external interrupt to correctly handle incoming train; i make several test with different alghoritm, but i can't receive correctly the train... i have tried with pulseIn, i have tried directly polling the pin, i have tried to receive every bit with interrupt, but nothing. Any ideas?
Thank you in advance for any help or ideas...
