Topic: help with programming 3.2 TFT touchscreen (Read 7114 times) previous topic - next topic
Tadas
New to arduino. I have a mega 2560  and a 3.2 TFT mega shield 1.0 .Downloaded and installed ITDB02_Graph16 library . When running tests , it compiles OK, appears to load OK but nothing happens on the screen. I have tested arduino examples like blink and it works fine.
thnaks for any help
geneluck
:smiley-roll:Please , we need help here to get started. which library, test program could we use to get anything going?
we have only managed to run programs directly to the arduino itself.
Geneluck
dxw00d
What is a '3.2 TFT mega shield 1.0'. Post a link to it, and to the library.
geneluck
"what is a 3.2 TFT"
It looks like we posted in the wrong forum section! Should we post that somewhere else?
these are 2 links to TFT screen and library:
http://iteadstudio.com/store/index.php?main_page=product_info&products_id=478
http://henningkarlsen.com/electronics/library.php?id=39
dxw00d
#4
Jan 10, 2012, 12:29 pm Last Edit: Jan 10, 2012, 01:01 pm by dxw00d Reason: 1
I know what a TFT is. What I didn't know was what your particular hardware is. Now we need to know what it is you are attempting to run, what you would expect to happen, and what is actually happening, so...
1. Post the code you are running and which version of the Arduino IDE you are using as the demo code doesn't compile under 1.0.
2. Describe expected results.
3. Describe, or show, actual results.
geneluck
This is a demo we are trying to run.
The verify|compile seems ok as it does not return an error.
Then we upload to the arduino and this seems to work also as we see a set of lights flashing on the arduino with no error message.
And then nothing. With simple arduino examples, like the blink, we have nothing more to do as the test starts running automatically.
In this case , nothing happens any more,the screen stays blank. At this stage we do not have a clue of what should happen and we are after any information to move forward.
We are running the IDE part of UBUNTU 11.10 so the most recent stable version.
Help does not display the version of the IDE.
I tried to copy code here but cannot paste?? any idea how to
thanks for your time
dxw00d
The version is shown in the title bar of the ide window.
I don't know why you can't paste the code in. I've never had a problem with that. Alternatively, you can attach a file using the Additional Options below the text box when you post.
geneluck
I could not copy and paste directly from the IDE window. So saved the file and copied below OK.
top of IDE window Arduino 0022ubuntu0.1 :
// ITDB02_Graph16_Demo (C)2011 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported 16bit display module.
// This demo was not made for the widescreen modules. Use
// ITDB02_Graph16_Demo_Widescreen instead.
// This program requires the ITDB02_Graph16 library.
#include <ITDB02_Graph16.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next line for Arduino 2009/Uno
//ITDB02 myGLCD(19,18,17,16);   // Remember to add the parameter for your display if you are not using an ITDB02-3.2!
// Uncomment the next line for Arduino Mega
ITDB02 myGLCD(38,39,40,41);   // Remember to add the parameter for your display if you are not using an ITDB02-3.2!
  randomSeed(analogRead(0));
// Setup the LCD
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  int buf[238];
  int x, x2;
  int y, y2;
  int r;
// Clear the screen and draw the frame
  myGLCD.clrScr();
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 239, 13);
  myGLCD.setColor(64, 64, 64);
  myGLCD.fillRect(0, 306, 239, 319);
  myGLCD.setColor(255, 255, 255);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.print("QVGA TFT 240x320 Color Display", CENTER, 1);
  myGLCD.setColor(255, 128, 128);
  myGLCD.setBackColor(64, 64, 64);
  myGLCD.print("H.Karlsen", LEFT, 307);
  myGLCD.print("(C)2011", RIGHT, 307);
  myGLCD.setColor(255,255,0);
  myGLCD.print("Portrait", CENTER, 307);
  myGLCD.setColor(0, 0, 255);
  myGLCD.drawLine(0, 14, 239, 14);
  myGLCD.drawLine(0, 14, 0, 305);
  myGLCD.drawLine(239, 14, 239, 305);
  myGLCD.drawLine(0, 305, 239, 305);
// Draw crosshairs
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.drawLine(119, 15, 119, 304);
  myGLCD.drawLine(1, 159, 238, 159);
  for (int i=9; i<240; i+=10)
    myGLCD.drawLine(i, 157, i, 161);
  for (int i=19; i<300; i+=10)
    myGLCD.drawLine(117, i, 121, i);
// Draw sin-, cos- and tan-lines
  myGLCD.setColor(0,255,255);
  myGLCD.print("Sin", 5, 15);
  for (int i=1; i<238; i++)
    myGLCD.drawPixel(i,159+(sin(((i*1.51)*3.14)/180)*100));
  myGLCD.setColor(255,0,0);
  myGLCD.print("Cos", 5, 27);
    myGLCD.drawPixel(i,159+(cos(((i*1.51)*3.14)/180)*100));
  myGLCD.print("Tan", 5, 39);
    myGLCD.drawPixel(i,159+(tan(((i*1.51)*3.14)/180)));
  delay(2000);
  myGLCD.setColor(0,0,0);
  myGLCD.fillRect(1,15,238,304);
// Draw a moving sinewave
  x=1;
  for (int i=1; i<6902; i++)
    x++;
    if (x==239)
      x=1;
    if (i>239)
      if ((x==119)||(buf[x-1]==159))
        myGLCD.setColor(0,0,255);
      myGLCD.drawPixel(x,buf[x-1]);
    y=159+(sin(((i*1.4)*3.14)/180)*(100-(i / 100)));
    myGLCD.drawPixel(x,y);
    buf[x-1]=y;
  delay(2000);
// Draw some filled rectangles
  for (int i=1; i<6; i++)
    switch (i)
      case 1:
        myGLCD.setColor(255,0,255);
      case 2:
      case 3:
        myGLCD.setColor(0,255,0);
      case 4:
      case 5:
    myGLCD.fillRect(30+(i*20), 70+(i*20), 90+(i*20), 130+(i*20));
  delay(2000);
// Draw some filled, rounded rectangles
    switch (i)
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
    myGLCD.fillRoundRect(150-(i*20),70+(i*20), 210-(i*20), 130+(i*20));
  delay(2000);
// Draw some filled circles
    switch (i)
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
    myGLCD.fillCircle(60+(i*20),100+(i*20), 30);
  delay(2000);
// Draw some lines in a pattern
  myGLCD.setColor (255,0,0);
  for (int i=15; i<304; i+=5)
    myGLCD.drawLine(1, i, (i/1.22)-10, 304);
  for (int i=304; i>15; i-=5)
    myGLCD.drawLine(238, i, (i/1.22)-11, 15);
  myGLCD.setColor (0,255,255);
    myGLCD.drawLine(1, i, 251-(i/1.22), 15);
    myGLCD.drawLine(238, i, 250-(i/1.22), 304);
  delay(2000);
// Draw some random circles
  for (int i=0; i<100; i++)
    myGLCD.setColor(random(255), random(255), random(255));
    x=32+random(175);
    y=45+random(212);
    r=random(30);
    myGLCD.drawCircle(x, y, r);
  delay(2000);
// Draw some random rectangles
    x=2+random(236);
    y=16+random(287);
    x2=2+random(236);
    y2=16+random(287);
    myGLCD.drawRect(x, y, x2, y2);
  delay(2000);
// Draw some random rounded rectangles
    x=2+random(236);
    y=16+random(287);
    x2=2+random(236);
    y2=16+random(287);
    myGLCD.drawRoundRect(x, y, x2, y2);
  delay(2000);
  myGLCD.fillRect(2,16,238,304);
    x=2+random(236);
    y=16+random(289);
    x2=2+random(236);
    y2=16+random(289);
    myGLCD.drawLine(x, y, x2, y2);
  delay(2000);
  for (int i=0; i<10000; i++)
    myGLCD.drawPixel(2+random(236), 16+random(289));
  delay(2000);
  myGLCD.fillScr(0, 0, 255);
  myGLCD.fillRoundRect(30, 100, 209, 219);
  myGLCD.print("That's it!", CENTER, 133);
  myGLCD.print("Restarting in a", CENTER, 159);
  myGLCD.print("few seconds...", CENTER, 172);
  myGLCD.setColor(0, 0, 0);
  myGLCD.setBackColor(0, 0, 255);
  myGLCD.print("Runtime: (msecs)", CENTER, 290);
  myGLCD.printNumI(millis(), CENTER, 305);
  delay (10000);
geneluck
After messing about , we found it :
one extra parameter needs to be added to the following line :
should be :
ITDB02 myGLCD(38,39,40,41,ITDB32S)
so the display works now!
We have now more problems with the Touch library , but we should hopefully be able to sort it out
dxw00d
That's good. Always pays to read the comments.
