Topic: Establishing PWM limits for Servo motor. (Read 2022 times) previous topic - next topic
DROBNJAK
Servo motors have minimum and maximum lengths of PWM signal width in microseconds, that they would tollerate. But manufacturers never bother to display those.
What is the best way to find those out?
AWOL
If you're talking about R/C servos, PPM pulses (not PWM) are usually in the range 1000 to 2000 usec, sometimes ±200usec, repeated roughly every 20msec
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
DROBNJAK
What are PPM pulses? Can Arduino do them?
I am just using the standard Servo library. I guess it is sending PWM pulses.
AWOL
kf2qd
Nope - They're not PWM..
They are PPM - it takes 2 pulses and the time between the pulses controls the servo position.
zoomkat
Quote
You use simple servo conrol code to send the servo increasing and decreasing control values and find the servo high and low hard stops.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
AWOL
Quote
They are PPM, but the servo displacement is proportional to only the width of the control pulse; the time between pulses is largely immaterial (though it isn't recommended you change it!)
