Topic: avrdude: stk500_recv(): programmer is not responding error with ATMEGA1280 (Read 3785 times) previous topic - next topic
hooli
I'd be grateful if anyone could help with the following error, when trying to upload Blink to an ATMega1280:
avrdude: error reading signature data for part "ATMEGA1280", rc=-1
avrdude: error reading signature data, rc=-1
I have tried different USB cables and two different macs (10.7 with Arduino v0023 & 10.6 with Arduino v0022).
The upload used to work on the 10.6 mac machine, but for some reason has stopped working.
The boards power light is on, and L13 is blinking. When the upload happens, the TX/RX LEDs also flicker, then it goes back to L13 blinking.
I've tried the manual rest button, but this does not seem to make a difference.
I have altered the blink program, and tried other examples, but it always runs the default Blink installed.
Is there something else I can try? Is the boards hardware at fault, or could it be the boot loader, which needs to be re-flashed?
Many thanks for any help.
The verbose output from the upload is:
Binary sketch size: 1598 bytes (of a 126976 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega1280 -carduino -P/dev/tty.usbserial-A5006HTP -b57600 -D -Uflash:w:/var/folders/tm/83qtm8jj1zgdvblzd2jh0vkr0000gn/T/build6004788269102776023.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/brendan/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbserial-A5006HTP
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA1280
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [80]
avrdude: Send: A [41] . [81]   [20]
avrdude: ser_recv(): programmer is not responding
Without verbose on I just get this:
madworm
Loop-back test!
If that works, then there's something wrong with the 1280.
hooli
Thanks for the suggestion. Just tried the loopback test and it works fine, echoes back what I type.
I thought it might be the FTDI USB drivers on Lion, but have installed the latest, and on Mac 10.6, it has the original drivers that worked.
Is there anything in Arduino program's config to try? I was wondering if the auto-rest is working correctly, so have tried manual reset but no success.
hooli
I checked the serial RX/TX with a logic analyser, and the codes are correct.
Out of interest what is the correct starting sequence of codes to upload a ATMega1280?
It seems strange the Arduino does respond to
0x30 0x20        with 0x14 0x10 then
0x41 0x80 0x20 with 0x14 0x80 0x10,
but then ignores the next message 0x41 0x81 0x20.
Could the timing of the auto-reset be out. The reset line dropped twice quickly at about 0.4s before the Tx/Rx data.
Might try and programming it via the SPI if I can get a programmer.
laurence_roberts
Did you get it working, as you have a very similar problem that I am having with my Mega 2560 on an iMAC 10.6.8, with Sketch 1.0?
Cheers.
hooli
Nope , still have the same problem.
I noticed there are other threads which mentioned problems with uploading (unsure if they are related)
One suggestion was to try v0022 of Arduino app, but this did not work either.
Have ordered a new MEGA 2560, and will see if that works, and /or if I can then refresh the bootloader on the 1280.
Any suggestions most welcome.
hooli
Just tried it on a Windows 7 OS (running on a Mac laptop, bootcamp), and got a different output (see below). Seems to have gotten further.
The led13 blinks on and of between the different the serial exchanges (which have the two red tx/rx led going)
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         System wide configuration file is "C:\Users\bernie\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM4
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [03]
         Hardware Version: 128
         Firmware Version: -2.16
avrdude: Send: A [41] . [84]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [85]   [20]
avrdude: Recv: . [00]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 429496729.4 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Recv: . [01]
avrdude: Send: B [42] . [00] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [00] . [00] . [00] . [00] . [01] . [00] . [10] . [00] . [00] . [02] . [00] . [00]   [20]
avrdude: Send: E [45] . [05] . [08] . [d7] . [a0] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [10]
avrdude: arduino_read_sig_bytes(): (a) protocol error, expect=0x10, resp=0x00
avrdude: error reading signature data for part "ATMEGA1280", rc=-3
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
laurence_roberts
I have to do the following to program my 2560 on my iMAC with Sketch 1.0:
push and hold the reset button
click the File / Upload
release the reset button
Takes the code and programs ok, even though an error still appears sometimes, normally after the 1st program upload.
Someone suggeted the new bootloader is the problem???
hooli
I tried the reset button before uploading and it did not work either.
Just got an AVRISP MkII programmer, and got the board working again.
The programmer isn't recognised by Mac 10.7 Lion , but I could program a sketch via Arduino.app v1.
Holding down shift (the old verbose option) whilst clicking upload correctly uploaded to the board.
The bootloader was not changed, so still could not upload via USB serial.
Then used Arduino to burn the boot loader via AVRISP, and USB Serial is working now, so the
bootloader must have somehow got corrupted.
