Loading...
Pages: [1]   Go Down
Author Topic: I cannot upload, says folder full. How to empty it ??  (Read 903 times)
Offline Offline
Full Member
View Profile
When I tried to upload some codes to forum it says "The upload folder is full. Please try a smaller file and/or contact an administrator". How can I empty it?
Thanks
Logged
Toronto, Canada
Offline Offline
Edison Member
"Keep it R.E.I.L. - "Research, Experiment, Investigate and Learn"
View Profile
I have the same problem. I can not upload my pictures I try to upload.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Its not you guys, its the forum server.
I have resorted to uploading my docs elsewhere and posting links to my diagrams, etc.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Forum Administrator
MMX
Offline Offline
Edison Member
hallo kompis
View Profile
WWW
trying to upload
Logged
Forum Administrator
MMX
Offline Offline
Edison Member
hallo kompis
View Profile
WWW
just made a blog post on this matter:
http://arduino.cc/blog/2012/01/16/arduino-servers-or-why-were-slow/
btw, the issue is fixed, it had nothing to do with you, it was a general setting for the whole forum that needed to be increased to a bigger size
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Wow, just finished reading the blog, what a  nightmare!  Thank you for all the effort that went into that David.
Logged
Colorado
Offline Offline
Edison Member
Reviving dead brain cells with Arduinos.
View Profile
Being an IT Director at a local company, I can certainly feel the pain here.  Upgrades are never easy, nor cheap.  I've long accepted that no matter how prepared one is, no matter how well thought out the process is, there will always be something that will come bite you.  Nature of the beast.  I appreciate the post from David.  I can see we were running against some limitations there and while I still see the occasional slow down or even timeouts still, it's nowhere near as bad as it was.
On the issue of database, David, has anyone spend time looking at the actual queries being made?  If it's a MySQL database, I would enable slow_query_log, set the time to five seconds and let it run for a day or two.  I'm willing to bed you will find a bunch of queries that could potentially be optimized for a faster response out of the server.  Even if it's simply adding a new index.  This is the Achilles heal for all forum applications, the constant database traffic.
Logged
Pages: [1]   Go Up
Print
Jump to:
