Topic: pulseIn Bug (Read 8662 times) previous topic - next topic
Jantje
westfw
Quote
So is this "resolved" in the sense that the changed behavior is now understood?
Yes it is resolved in the sense that the change is understood.
Quote
If it's understood, is it believed to be a good change that happens to break this person's apps
Depends on your point of view. I think the 2 previous posts explain this in depth.
Quote
or a bad changed that has caused a real bug?
I don't think anyone would call it a real bug. Think about it like upgrading your car. You may be happy that you can transport more but you can be sad you can't cross the smallest bridges anymore.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
tevz
I have some sort the same problem:
I have a temperature and humidity sensor with following protocol:
2 bytes for humidity, 2 bytes for temperature and 1 byte for checksum
25us puls is 0, 60us puls is 1 and there is 40us timeout between pulses.
With Arduino IDE 1.0 i get just 20 bits (every secound bit) but with Arduino IDE 0018 it works just fine.
What do you suggest me to do?
robtillaart
Quote
First start a thread for your own problem as your problem is different from the OP.
Second, PulseIn() is for detecting and measuring one pulse, it is not for reading a pulse-train. Then you get exactly the effect you are talking about. If your sensor is (looks like) a DHT11 or DHT22 you can use this lib - http://arduino.cc/playground/Main/DHTLib - as it does (almost) exactly what you need
Hope this helps
Rob Tillaart
(Please do not PM for private consultancy)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
