Loading...
Pages: [1]   Go Down
Author Topic: Opposite of a voltage divider?  (Read 889 times)
Offline Offline
Full Member
View Profile
Hi all,
I'm building a circuit that uses PWM to drive a mosfet.  I hava an Arduino set to pump out a 200Hz square wave, and all is well.  This works fine with the 5V pins on the Arduino.
However, another project calls for the exact same mosfet circuit and frequency, however I'll be using a ChipKit UNO, which is a 3.3V board.  The PWM from the 3.3V pins is not sufficient to drive the mosfet.
So, I'm wondering, is there any sort of simple circuit that will act as a voltage divider, but in the opposite sense to drive 3.3V up to 5V?  I know about boost converters but I'm thinking that's a little too much complexity for my application.
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
It's easiest to just use a MOSFET with a lower threshold voltage, for example this guy:
http://search.digikey.com/us/en/products/IRLML2402TRPBF/IRLML2402PBFCT-ND/812508
It has a guaranteed maximum on-resistance of 0.35 ohms at 2.7V.
Or you can get a MOSFET gate driver like a TC4427 to function like a "reverse voltage divider", i.e., taking in a low voltage and putting out a higher one. But you will need to power it with the higher voltage that you want.
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
Use the 3V PWM pin to switch a bipolar transistor to switch the gate voltage for the MOSFET.
You didn't state what your MOSFET +V.
I've posted this circuit before --
Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
Offline Offline
God Member
View Profile
If you've got 5V available so you don't have to generate the 5V supply, it's fairly easy to boost a 0-3.3V logic circuit up to 0-5V.  Interfacing 3.3V logic to 5V logic  (and vice-versa) is a common problem.
A quick-search turned-up 74LVC4245.
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
There is such a circuit called a "voltage multiplier" - you typically see them used in cascades for high-voltage work (ie - building things like tasers and stun-guns)...
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
There are specific devices designed for just this task.
They are called "Logic Level Translators".
They convert 3.3V to 5V and 5V to 3.3V for logic signalling between devices of different voltages.  There are also 1.8V versions as well, and universal ones where you just supply both voltages as inputs and it converts between them.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
See also "MOSFET drivers"...
Logged
Pages: [1]   Go Up
Print
Jump to:
