Topic: As fast as an NFL player? (Read 7936 times) previous topic - next topic
Osgeld
ultrasonic sensors
though with lasers if you get shot in the eye your inclined to shut it, with invisible light you never know when its blinding you, guess it depends on the distance apart and the intensity of the light ...
though honestly I don't see why you couldn't do it with just normal light, even NFL players are not running faster than most light sensors
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
GoForSmoke
ultrasonic sensors
With an IR laser you'd probably know once the searing pain hit. Honestly no one can shut their eye fast enough. A buddy of mine got a 2 or 4mW pen and was sweeping it across a near wall when the beam hit a small curved (fisheye? it curved outwards) mirror. The then spread-out reflection caught him in one eye and it was about 2 hours before he could see anything but red from that eye. Scary stuff. Think of what a flat window might do? Or a polished button?
Quote
The 'hard part' is blocking out background light from the sensor.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
PeterH
I don't use lasers myself, but the more I read about the potential for severe permanent optical damage the more I'm inclined to say that you want to keep things like this well away from children - and grownups too, I suspect.
I only provide help via the forum - please do not contact me for private consultancy.
Chagrin
FFS. A typical laser pointer isn't going to cause permanent eye damage. If you're going to insist that it can then please provide a citation.
These hazards are no worse than camera flashes, welders, or mirrors on a bright day, but if you're extra paranoid then it's trivial to just choke the current to the laser to the minimum that you need.
GoForSmoke
Yeah there's no liability for making someone wander around for hours unable to see from one eye, is there? I mean, since it's not permanent, right?
PeterH
FFS. A laser pointer is obviously potentially dangerous [1][2]. If you're going to insist that it cannot be dangerous under any circumstances then please provide evidence.
Chagrin
Both of your citations refer to high power lasers.
GoForSmoke
If you read the article looking for other than excuses to play then you might see where trouble can happen.
Quote
Possible more potentially damaging -- although not to the eye -- is that a regular pointer laser can overwhelm the eye with light, typically called flash blindness. If a person is walking a rocky path, operating machinery, a vehicle or aircraft, this temporary loss of vision could cause injury or disaster.
If you want to be sure, ask an ambulance-chaser.
PeterH
But 'high power' only means a couple of mw, which is only a tiny step from the power levels that are being discussed and easily achievable with the hardware being discussed. I noticed that green lasers were specifically mentioned as problematic due to being higher power than specified, and those were recommended earlier in the thread.
I accept that these lasers can be safe under the right circumstances, but I also maintain that they can be dangerous under the wrong circumstances and the possible consequences can be nasty. To dismiss that danger and simply assume that the system being developed will be safe for a youngster to play with seems quite risky to me.
Techone
I agree with you guys that (any) laser can potentially be dangerous to someone vision.
If the OP insist to use a small laser ( a pointer type ). I will shield it with a toilet paper roll <-- the cardboard roll , and shield the receiver with a toilet paper roll <-- cardboard. Install them about 1'' to 2' height from the ground. <-- I feel it is a safe height. Just hope a child is not going to look into the tube because he/she is currious about the "stange" set-up. <-- my worry
GoForSmoke
Do the run at the right time of sunny day you only need a light detector anyway. Guess why?
Errrr, make that two light detectors.....
astrodad
Wow a lot of replies since my last post. We are going to proceed with the lasers, but I also like the idea of the string. I have no idea how I would do that, but that might be fun to try at some point.
We got the transistor working, although visualizing the circuit was a little bit of a challenge for him. Now he understands how it works. Here's a picture of the laser we're using with the transistor.
Techone
#57
Feb 04, 2012, 06:53 pm Last Edit: Feb 04, 2012, 06:56 pm by Techone Reason: 1
@atrodad
Well. Not bad. gnd and from a ~ pin 10 is OK. External battery for the lase is OK. Can you tell me what type and number of the transistor you are using ? at the base ? I see a resistor and connect to the collector ? . Did you connect : 1. base limiting resistor.
2. current limiting resistor.
I know, sometime, it is hard to follow a schematic going to a breadboard.
Here a picture of a typical transistor connection. Sorry for a bit "out of focus"
In the picture, I use color code for my connection. Red is positive. Green is gnd / commun. I use a fiber optic transmitter. ( a IR led ) The limiting resistor is 68 ohms. The base transistor is 4.7 K. And the transistor is NPN - 2N3904 - EBC type. My circuit is connect to a FDTI USB board.
GoForSmoke
#58
Feb 05, 2012, 07:45 am Last Edit: Feb 05, 2012, 07:52 am by GoForSmoke Reason: 1
The thing is that on a day bright enough to cast shadows..... or even have a light-colored sky....
astrodad
@atrodad
Thanks for the info. I should have used a color code, that makes sense. The transistor is also a 2N3904. I think I used a current limiting resistor--1 kOhm.
I need to drive two separate lasers, though. I'm assuming it's better to use two separate transistors utilizing two separate pins to switch them?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
