Offline
Jr. Member
« on: January 10, 2012, 11:17:29 am » |
Hi, I'm using Arduino Uno for the first time with Ethernet Shield (W5100 chip). I connect it via RJ45 patch cable to my Netgear DNG3500 router, I've used Webserver sketch from examples, I modified IP address using 192.168.0.177 within my local network range and uploaded it. I tested that network data are correct becouse if I ping it answer correctly in less than 1ms. When I go to my web browser and connect to 192.168.0.177 non page was found  I tried to use IE8, Firefox and Chrome web browser... unsuccesfully. I tried to change my router, I used a simple switch, I used a different PC, I changed data cable... but unsuccesfully. I tried to use IDE 1.0 and IDE 0023... but unsuccesfully. Only one time it works... for few seconds. Anyone can help me?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #1 on: January 10, 2012, 11:54:53 am » |
When I go to my web browser and connect to 192.168.0.177 non page was found That would indicate a problem with the code running on the Arduino. And that code looks like?
Logged
Offline
Jr. Member
« Reply #2 on: January 10, 2012, 12:32:37 pm » |
The code is the sample in Tools > Ethernet > Webserver ...what is wrong???
/* Web Server A simple web server that shows the value of the analog input pins. using an Arduino Wiznet Ethernet shield. Circuit: * Ethernet shield attached to pins 10, 11, 12, 13 * Analog inputs attached to pins A0 through A5 (optional) created 18 Dec 2009 by David A. Mellis modified 4 Sep 2010 by Tom Igoe */
#include <SPI.h> #include <Ethernet.h>
// Enter a MAC address and IP address for your controller below. // The IP address will be dependent on your local network: byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; IPAddress ip(192,168,0,177);
// Initialize the Ethernet server library // with the IP address and port you want to use // (port 80 is default for HTTP): EthernetServer server(80);
void setup() { // start the Ethernet connection and the server: Ethernet.begin(mac, ip); server.begin(); }
void loop() { // listen for incoming clients EthernetClient client = server.available(); if (client) { // an http request ends with a blank line boolean currentLineIsBlank = true; while (client.connected()) { if (client.available()) { char c = client.read(); // if you've gotten to the end of the line (received a newline // character) and the line is blank, the http request has ended, // so you can send a reply if (c == '\n' && currentLineIsBlank) { // send a standard http response header client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html"); client.println();
// output the value of each analog input pin for (int analogChannel = 0; analogChannel < 6; analogChannel++) { client.print("analog input "); client.print(analogChannel); client.print(" is "); client.print(analogRead(analogChannel)); client.println("<br />"); } break; } if (c == '\n') { // you're starting a new line currentLineIsBlank = true; } else if (c != '\r') { // you've gotten a character on the current line currentLineIsBlank = false; } } } // give the web browser time to receive the data delay(1); // close the connection: client.stop(); } }
Logged
Offline
Newbie
« Reply #3 on: January 10, 2012, 07:16:35 pm » |
Hi, I have exactly the same problem. I bought the arduino Ethernet on Sunday, yesterday I tried the webserver example and was working perfectly, today was also working, but suddenly it does not work anymore....
the code is the webserver example code.
Thanks in advance!
Logged
Offline
Newbie
« Reply #4 on: January 11, 2012, 01:20:42 pm » |
Does anybody know? I wouldn't like to give it back or buy a new one...
Logged
Miramar Beach, Florida
Online
Faraday Member
« Reply #5 on: January 11, 2012, 01:42:13 pm » |
What exactly is the error? Is it "error 404 page not found" or "cannot connect to server"?
Logged
Offline
Newbie
« Reply #6 on: January 11, 2012, 04:32:14 pm » |
You must ensure that the reset pin is not connected to the Arduino board (best to bend the pin side) and then it goes.
Logged
Offline
Newbie
« Reply #7 on: January 11, 2012, 05:01:27 pm » |
When I go to 192.168.1.177 it says "waiting", it takes a lot of time and at the end it tells me that cannot connect. In mi case it is the Arduino Ethernet (I don have the shield, it is everything integrated). It is so strange... it was working perfectly and suddenly does not work....
Logged
Online
Faraday Member
« Reply #8 on: January 11, 2012, 05:11:18 pm » |
@levas: Are you certain about the ip address you entered in the web server code? What is the ip of the computer you are attempting to connect with? Can you ping the ethernet shield ip address from the computer?
Logged
Offline
Newbie
« Reply #9 on: January 11, 2012, 05:30:37 pm » |
Yes, it is the same that appears in the ethernet web server example.
192.168.1.35
Yes, indeed the leds Tx and Rx are blinking in the ping. Also when I go to chrome and type the IP address Tx and Rx blink once. Before this error happened, I could also connect from my mobile phone via WIFI and now it is not possible, remains waiting and waiting....
Logged
Offline
Newbie
« Reply #10 on: January 11, 2012, 05:46:13 pm » |
Guys! Now it works!
What I have done is to install the program in another computer (laptop windows), upload again the webserver example... and works!
In the other computer I was working with Linux..... Linux (Ubuntu 11) seems to be the reason, but in the first tests was working perfectly. Strange....
Thanks a lot for the help!
Logged
Online
Faraday Member
« Reply #11 on: January 12, 2012, 05:55:39 am » |
Glad to hear that. I do not believe it is Ubuntu tho. I am using a Mega with V11.10, and it is working great with the ethernet shield.
I did have some trouble with the shield before I disabled the microSD card reader SPI interface on the shield. It would interfere with the w5100 IC on occasion.
Logged
Offline
Newbie
« Reply #12 on: April 04, 2013, 10:56:31 pm » |
Guys I have the same problem  but it is not solved yet. I inserted a SD card in the slot. That is when the problem started. My serial output showed ip as 0.0.0.0 and later when i removed the SD card, it is showing the ip from the code. But still i am not able to connect to the webserver. How to disable the SD card? Move high to Pin 4????
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #13 on: April 05, 2013, 12:01:03 am » |
Post your code. The below is a fix. Serial.begin(9600);
// disable w5100 while setting up SD pinMode(10,OUTPUT); digitalWrite(10,HIGH); Serial.print("Starting SD.."); if(!SD.begin(4)) Serial.println("failed"); else Serial.println("ok");
Ethernet.begin(mac, ip, gateway, gateway, subnet); server.begin(); Serial.println("Ready");
Logged
