Topic: using Keypad library for a full QWERTY keyboard (Read 12887 times) previous topic - next topic
mclien
#30
Feb 15, 2012, 04:45 pm Last Edit: Feb 15, 2012, 04:48 pm by mclien Reason: 1
Yes exactly. I'm a newbe to that, so I didn't know if the analog pins are useless and I only can could the digital ones.
and I'm not a native english speaker so that add some difficulties in understanding the stuff (and ma lead to some questions that might sound silly and unnessessary)
liudr
To expand this topic on analog pin ideas, I think you can connect a few resistors to the row pins like that of the analogbuttons and use column pins to drive low and sense with analog inputs. What do you thing, mstanley? 4 digital pins and 1 analog pins for a 4*4 keypad? I'll whip out the code with my phi_interface library, which already contains analog keypads but of a different type.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
mstanley
Quote
I think I would like to but maybe we should start another thread for that.  It could be pretty scary for newbies.  :)
Quote
LoL... I thought of that, too.  It sounds like a pretty fun challenge.  But for shipping code it would probably just be best to have the library identify that the user is connected to the analog pins and have the library reconfigure them for digital when needed.
liudr
Quote
Quote
Yep! Will do once I get it to work. All I have now is a "matrix keypad" with multiple analog inputs, each with a number of keys hooked to it. This hybrid keypad will be more useful since you can just buy a matrix keypad and not having to construct a special keypad to use analogButton lib. I have been aching over the ATMEGA328P lacking of I/O pins for a while. I was trying to make a phi-panel out of GLCDs. They take 13 pins so 5 left if I do serial panel. I guess I've just found my way to handle that with analog/digital hybrid keypad. Awesome! Finding solutions or learning stuff every day is great!
mclien
#34
Feb 16, 2012, 08:57 am Last Edit: Feb 16, 2012, 03:20 pm by mclien Reason: 1
FYI, the matrix of the Palm portable Keyboard (US-Layout), which I plan to re-use with the teensy:
Code: [Select]
       "c1"    "c2"    "c3"    "c4"    "c5"    "c6"    "c7"    "c8"    "c9"    "c10"   "c11"   "c12"
"r1"    "4"                     "c"     "r"     "f"     "8"     "u"     "j"     "m"
"r2"    "5"                     "v"     "t"     "g"     "9"     "i"     "k"     ","
"r3"    "6"                     "b"     "y"     "h"     "0"     "o"     "l"     "."
"r4"    "7"                     "n"     "` ~"   "space" "space2"        "p"     ";"     "done"
"r5"    "1"     "Caps"  "Del"           "cmd"   "x"     "-"     "["     "„""    "/ "            "Shft L"
"r6"    "2"     "tab"   "left"          "q"     "a"     "+"     "]"     "enter" "up"            "shf R"
"r7"    "3"     "ctrl"  "down"          "w"     "s"     "BckSpce"       "\"     "ToDo"  "Memo"  "Fn"
"r8"    "z"             "right"         "e"     "d"     "Date"  "Phone"                 "alt"
So what do you think liudr? 12 digital and 1 analog pin for that, or are 8 steps to narrow for an analog pin?
But I could also live with the use of a "full" matrix of 20 I/O pins (so I can still leave out the RX/TX pins and have 2 pins left to drive a LED, if I want to)
And don't be confused by some strange Labels: There are some extra keys on that keyboard that where designed for the use with a Palm device, but could be perfectly reused as extra/media/F keys.
Once the hardware is working its just a metter of assinging the keys and perhaps do some work with xmodmap (at least when using GNU/Linux).
EDIT:
I was just surfing hackaday:
http://hackaday.com/2012/02/15/building-a-keyboard-from-scratch/
(haven't read all links, but it was mentioned he used a teensy++2.0 and "existing libraries". maybe it's worth alook?)
liudr
mclien,
8 analog steps should work. Then you have 12 digital I/O + 1 analog input to sense the entire keypad. I will find some time to tackle this. Under my phi_interfaces framework it should be easy to add a device like this but I have the phi_prompt library to release first ;)
The hackaday is worth checking. I browsed the site and didn't find a design file. There's around 90 keys and the keypad layout is known so the maker could have made a custom dimension. Your keypad has a fixed dimension of 8*12 and that is what you have to deal with. The hackaday code should be worth looking at. The hackaday keyboard must allow multiple key held together so it's much more complicated than what my library does, which is single key only.
mclien
Oh, the last point you mention is a issue to me.
Since I want to use the device as a "normal" USB keyboard I have to get it working with up to 3 keys pressed (ALT+SHIFT+L or something like that) or is that what option8 does by using the keypad library 2 times?
mstanley
option8 tried using the keypad library 2 times to handle multiple key presses but I don't believe it solved his problem.  I modified the library for him so that, with some restrictions, he can press up to 10 keys at the same time.
I saw that he offered to send you a copy of his sketch so I asked him to send you a copy of the modified library.  If he can't do it then I can send you what you'll need. But it will have to wait until this weekend.
mclien
Yes I got a "keypad 2.0 multi-keys" zip-file
and a "IIc Keyboard.ino"
So, some newbie questions (for verification):
-the ino file is option8s keyboard layout, which I have to modify (rows/cols amount, my layout)
- there are a lot of examples included (mainly for the numkeypad, if I understood it correctly) and a keypad.h and a keypad.cpp file.
So "all" I need is to modify the layout part of option8s ino file and include the keypad.h library?
mstanley
I am really glad to hear that. :)
Quote
Yes, that is true.  Just make sure you keep your pin numbers in the right order. Also, if you aren't using the Arduino 1.0 software (IDE) then you need to rename IIc Keyboard.ino to IIc Keyboard.pde
Quote
His file may already #include the keypad.h library.  If not, then yes, you will have to include it.
P.S.  Do you know how to add libraries to your Arduino software?
mclien
Quote
sure, but I fist have to do the hardware for that. (will be a real pain, I think. 20 small wires from one small pad to the teensy and about 12 pads to connect each other. maybe i use enameled copper wire to spare some space
Quote from: mstanley
My mistake. I ment where to place the library, but I think I just have to find the directory where all the libraries are and put the keypad.h there, so that the include command works...
I hope I'll get some photos uploaded at the weekend. Thanks for your support so far.
mstanley
If you can find your installation folder for the Arduino software then you will need to extract the keypad.zip into the libraries/ folder.  Once the files/folders are extracted then the directory tree should show Arduino/libraries/Keypad with a bunch of other library folders in there.
Restart the Arduino IDE if you already have it running. Next, go through the menus Sketch->Import Library...->Keypad and you should be able to add the library.  If you don't see Keypad in the menus then you extracted it to the wrong place.
Quote
Very cool and I'm glad I could help.
I have plans for the summer break while I'm between terms.  I am changing the library to always scan simultaneous multiple keypresses.  There will be a new function, getKeys(), for people wanting to scan keyboards but I plan to keep the current getKey() for people who want to read a single keypress from their keypads.
The reason I mention it is because I'm hoping that you keep your copy of the library private.  It's GPL'd so you can pass it around if you like but I really don't want to support it.
Thanks.
foobar
Hello,
My question isn't directly related to this post, but I figure that since you're the one who made the library then there's no one better to ask.
Basically I'm interfacing with a keyboard and LCD. The code should work as follows
a) a "menu" shows up
b) if the user presses a certain key then it should call another function
c) this other function prompts the user for input via the keypad.
d) the input is saved
My problem is in step c (and d) .... for some reason the code isn't acknowledging key presses once in the other function. I do call the function getKey again in the second piece of code and I've tried a couple of things to debug it but none of them work.
I've seen someone else do it, and they claim it works but it's not working with me. Do you have any suggestions as to what may be going wrong?
Thank you  :)
mstanley
Hi foob,
You should really only call the getKey() function once each time through the loop.  As long as you are not using delay()'s in your code then getKey will be called hundreds, or even thousands, of times per second.  Way faster than any human can react.  Thus, any time a new key is pressed it should get stored in your return variable and you can use that from any of your functions to see which key was pressed.
If that isn't enough to help you with your problem then email me directly and I will help you.  You can find my email address in the keypad.h file that you downloaded with the library.
-Mark
spiderwebby
Hi guys
I'm working on a teensy based keyboard (modern keyboard controller replacement, no diodes)
The hardware is sorted but I haven't started on the software yet.
Can I help out with the testing/grab the files and do a runner/help in any way?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
