Hi all ? I have read the example Arduino Tutorials - Ethernet+SD. And I decide to modify it to a remote controllable datalogger.
But it failed at the very begining. I just added a little materials on the webpage but the whole programme went wrong. I have no idea why this happend , can anyone help?
Many thanks
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#include <SPI.h>
/************ ETHERNET STUFF ************/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 177 };
EthernetServer server(80);
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
PgmPrintln("Done");
// Debugging complete, we start the server!
Ethernet.begin(mac, ip);
server.begin();
void ListFiles(EthernetClient client, uint8_t flags) {
// This code is just copied from SdFile.cpp in the SDFat library
// and tweaked to print to the client output in html!
dir_t p;
root.rewind();
client.println("<ul>");
while (root.readDir(p) > 0) {
// done if past last used entry
if (p.name[0] == DIR_NAME_FREE) break;
// skip deleted entry and entries for . and ..
if (p.name[0] == DIR_NAME_DELETED || p.name[0] == '.') continue;
// only list subdirectories and files
if (!DIR_IS_FILE_OR_SUBDIR(&p)) continue;
// print any indent spaces
client.print("<li><a href=\"");
for (uint8_t i = 0; i < 11; i++) {
if (p.name[i] == ' ') continue;
if (i == 8) {
client.print('.');
client.print((char)p.name[i]);
client.print("\">");
// print file name with possible blank fill
if (i == 8) {
client.print('.');
client.print("</a>");
if (DIR_IS_SUBDIR(&p)) {
client.print('/');
// print modify date/time if requested
if (flags & LS_DATE) {
root.printFatDate(p.lastWriteDate);
client.print(' ');
root.printFatTime(p.lastWriteTime);
// print size if requested
if (!DIR_IS_SUBDIR(&p) && (flags & LS_SIZE)) {
client.print(' ');
client.print(p.fileSize);
client.println("</li>");
client.println("</ul>");
// How big our line buffer should be. 100 is plenty!
#define BUFSIZ 100
char clientline[BUFSIZ];
int index = 0;
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
// reset the input buffer
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// If it isn't a new line, add the character to the buffer
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
// Print it out for debugging
Serial.println(clientline);
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
client.println("<title>Data Logger</title> ") ;
client.println("<h1><center>" ) ;
client.println("<img src=\"http://arduino.cc/en/uploads/Main/arduino_uno_test.jpg\")");
client.println("</center></h1>") ;
client.println("<hr/>");
client.println("<p>Welcome to the Data logger control webpage</p>");
client.println("<p>Click the button LCDdiaplay to allow the LCD display the time and input values</p>");
client.println("<td><a href=\"?ACTION=1\">LCDdisplay</a></td>") ;
client.println("
client.println("<p>Choose the period of data recording</p>");
client.println("<td><a href=\"?ACTION=2\">1 min</a><l td>");
client.println("<td><a href=\"?ACTION=9\">2 mins</a></td> ") ;
client.println("<td><a href=\"?ACTION=10\">5 mins</a></td>");
client.println("<td><a href=\"?ACTION=11 \"> 15 mins</a></td>");
client.println("<td><a href=\"?ACTION=12\">30 mins</a></td>");
client.println("
client.println("<p>Click the buttons to start or stop recording </p>");
client.println("<td><a href=\"?ACTION:3\">input0 control </a><ltd>");
client.println("<td><a href=\"?ACTION:4\">inputl control</a></td>");
client.println("<td><a href=\"?ACTION:S\">input2 control </a><ltd>");
client.println("
client.println("<p>Click the buttons to display data stored in each file</p>");
client.println("<td><a href=\" ?ACTION:6\">input 0</a></td>");
client.println("<td><a href=\"?ACTION=7\">input 1</a></td>");
client.println("<td><a href=\" ?ACTION:8\">input 2</a></td>" ) ;
client.println("
");// I just add these client.println instructions , the whole programe went wrong , really confused.
// print all the files, use a helper to keep it clean
client.println("<h2>Files:</h2>");
ListFiles(client, LS_SIZE);
} else if (strstr(clientline, "GET /") != 0) {
// this time no space after the /, so a sub-file!
char *filename;
filename = clientline + 5; // look after the "GET /" (5 chars)
// a little trick, look for the " HTTP/1.1" string and
// turn the first character of the substring into a 0 to clear it out.
(strstr(clientline, " HTTP"))[0] = 0;
// print the file we want
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println();
client.println("<h2>File Not Found!</h2>");
Serial.println("Opened!");
client.println("Content-Type: text/plain");
client.println();
int16_t c;
while ((c = file.read()) > 0) {
// uncomment the serial to debug (slow!)
//Serial.print((char)c);
client.print((char)c);
file.close();
// everything else is a 404
client.println();
// give the web browser time to receive the data
delay(1);
client.stop();
