Pages: [1] 2 3   Go Down
Author Topic: library definition  (Read 715 times)
If I have something like this on my custom library:
void TestClass::TestFunction()
// Doing Something
#ifdef TESTING
// Do something else
#endif
// Continue doing something
Which are the places I could define TESTING, besides TestClass.h or TestClass.cpp?
Could I use a separate .h file on the same folder as INO file?
Could I define somehow inside the INO file?
Thank you,
RI
* The .h and .cpp files can reside in your "libraries" folder, if they are to be used in more than one sketch, or in the same folder as the .ino file, if they are project-specific.
* The #define TESTING can be placed in the .ino file, before the #include "TestClass.h" statement. If you use the #ifdef TESTING statement consistently across you .h and .cpp files, you can compile a "testing" version or a "production" version of you sketch in no-time by simply commenting out the #define TESTING line atop you .ino file.
Doesn't work.
Here is what I have.
Well, it's pde cause I'm still using 0022
TestClass.pde:
#define TESTING
TestClass  t;
  Serial.begin(57600);
  Serial.println("Start");
  t.TestFunction();
  Serial.println("End");
TestClass.h
#ifndef __TESTCLASS_H__
#define __TESTCLASS_H__
#include <TestClass.h>
class TestClass
public:
TestClass();
void TestFunction();
#endif  // __TESTCLASS_H__
TestClass.cpp
TestClass::TestClass()
#ifdef TESTING
Serial.println("Test");
#endif
When I comment or uncomment the define on the PDE file, I get no change on the compiled code.
I tried adding new file on the same folder as the PDE called TestH.h:
#define TESTING
It still does not do anything.
Any other ideas?
Seattle, WA USA
Seattle, WA USA
The code does something. Maybe not what you expect/want. But, it does something. What does it do? What do you expect?
One issue with the way that the IDE processes files is that #define can't be the first bit of code in a file. Try adding a dummy variable declaration before the #define in the sketch.
In this example, all I wanted to do was to print "Test" if TESTING was defined on either the PDE or in a header file in the same folder as the PDE file:
#ifdef TESTING
#endif
I tried what you recommended and my code turned out to be:
byte r;
#define TESTING
TestClass  t;
  t.TestFunction();
But it still does not run what's indide the ifdef smiley-sad
North Queensland, Australia
the #define check is in a .cpp file.
It gets compiled before the pde/ino. Move the function into the header or use the #define in the .h file only.
.h
#ifdef TESTING
  #define DEBUG_PRINT( text ) ( Serial.println(text ) )
#else
  #define DEBUG_PRINT( text ) ( (void) 0 )
#endif
class TestClass
public:
TestClass();
.cpp
  DEBUG_PRINT( "Test" );
I tried your code, but it didn't print "Test".
Perhaps the function gest "optimized away" ? Just a thought, haven't had the time to test it still...
Oh, and now that I look closer... you have #include <TestClass.h> in... TestClass.h! ?-|
Ok, so the problem is this: the .cpp file doesn't #include the sketch, therefore at the time it gets compiled, TESTING is never defined.
The place where to put #define TESTING is therefore TestClass.h, which is included by TestClass.cpp, which in turn will notice if the symbol is defined or not.
Alternatively, you could define TestFunction directly in the .h file, like this:
#ifndef _TESTCLASS_H
#define _TESTCLASS_H
#include <Arduino.h>
class TestClass {
public:
    TestClass();
    void TestFunction() {
        #ifdef TESTING
        #endif
#endif
This way, putting the #define TESTING statements right before the #include "TestClass.h" line works as expected.
I think it worked!!!!
You are a genius!!!
Definitely owe you a beer smiley
I'll make some more tests later, gotta go to a meeting atm.
Thank you so much!!!
RI
« Last Edit: January 12, 2012, 11:18:16 am by newhobby » Logged
Glad to hear that. Thanks for the beer. La berrò alla tua salute ;-)
Ok, I've done some tests, but I'm still getting somewhat of a problem.
So, I need to add another level of difficulty.
I have a very complex set of libraries.
The solution provided works if the function is called from withint the INO file itself, but does not work if another library is calling it.
What do I need to do so the define becomes globally visible by all libraries?
Let explain a little of what I'm trying to achieve and maybe you could point me to a better solution.
I have a very large code that I'd like to fit on a UNO board.
If I add all features of the code, it won't fit.
So, I have right now a header file located on Arduino\libraries folder that I can edit and #define which features should be included on the compiled code.
Everything is working really good, except that it makes it really hard to know which features you had uploaded a month ago after you have changed this header file and picked different features.
So, I'm trying to make it so I can pick features within the INO itself and making as simple as possible for the user and at the same time, saving the file would also keep track of which features that code was using.
Here is what my test stuff looks like:
INO file:
#define TESTING
#include <ParentTestClass.h>
  //p.DoSomething();
  p.t.TestFunction();
In the code above, it works if I call p.t.TestFunction(), but not if I use p.DoSomething().
Even though the DoSomething() function calls the same t.TestFunction()
Here are the supporting libraries:
TestClass.h
class TestClass {
public:
    TestClass();
    byte TestFunction() {
#ifdef TESTING
#endif
#endif
TestClass.cpp
ParentTestClass.h
#ifndef _PARENTTESTCLASS_H
#define _PARENTTESTCLASS_H
class ParentTestClass {
public:
TestClass t;
ParentTestClass();
void DoSomething();
extern ParentTestClass p;
#endif
ParentTestClass.cpp
#include "ParentTestClass.h"
ParentTestClass::ParentTestClass()
void ParentTestClass::DoSomething()
t.TestFunction();
ParentTestClass p = ParentTestClass() ;
What about looking into const global variables? They'll get optimized away no problem, and you'll be able to see them from every file in your project.
I think need defs.
I have stuff like this:
#if defined FEATURE1
#include <Feature1.h>
#endif  // defined FEATURE1
And this:
#ifdef FEATURE1
const prog_char feature1menu_5_label[] PROGMEM = "Feature 1";
#endif  // FEATURE1
And this:
#ifdef FEATURE1
case Feature1Menu_Option1:
SetupFeature1();
break;
#endif  // FEATURE1
So, by just not using one single #define, I can strip a lot of code that won't be used and reduce the code size.
Is there a way to do that with Const too? Could Const be declared inside the INO file and be seem by all libraries?
Pages: [1] 2 3   Go Up
