Topic: Help with serial write to VB.NET 2010 Analog joystick (Read 2109 times) previous topic - next topic
rondog
Somewhat new to all this, but I don't understand how to write the code in arduino to tell my VB.Net pgm which analog I want to read at any given time. I can write to VB using Serial.println and I do see it in VB.Net but each time I start the pgm or reset the arduino the results come up different. by that I mean the order of the analoges to VB. IE value1 is not allways the first. See adruino code below, followed by VB.Net code. Any help?. Thanks, Ron.
Code: [Select]
Adruino Analogs for FS 2004
By Ron Buchwald 1/12/2012
REV 1
A1 = Eng1, A2 = Eng2, A3 = Flaps, A4 = Spoilers, A5 = Elevator Trim
int sensorPin1 = A1; //SET ANALOG PINS AS INPUT
int sensorPin2 = A2;
int sensorPin1 = A3;
int sensorPin2 = A4;
int sensorPin1 = A5;
int sensorValue1 = 0;  //STORE READ VALUE
int sensorValue2 = 0;
int sensorValue3 = 0;
int sensorValue4 = 0;
int sensorValue5 = 0;
void loop(){
  Serial.flush;
sensorValue1 = analogRead(sensorPin1); //READ ANALOG PINS
sensorValue2 = analogRead(sensorPin2);
sensorValue3 = analogRead(sensorPin3);
sensorValue4 = analogRead(sensorPin4);
sensorValue5 = analogRead(sensorPin5);
   //PRINT TO VB.NET 2010
     Serial.println(sensorValue1*17); // *17 TO GET 0-17391 FOR FS ANALOGS
      Serial.println(sensorValue2*17);// WOULD LIKE TO GET -4096-16383 BUT
        Serial.println(sensorValue3*17);//DON'T KNOW HOW SO I DO THAT IN
         Serial.println(sensorValue4*17);//VB.NET PGM
           Serial.println(sensorValue5*17);
            Serial.flush;
// END  RON BUCHWALD 1/12/2012
Now the VB code
Code: [Select]
Option Explicit On
Option Strict Off
Option Infer Off
Imports System.Windows.Forms
Imports System.IO.Ports
Imports FSUIPC ' an addon DLL.
Imports System.Drawing.Drawing2D
Public Class Form1 'THESE ARE THE FS OFFSETS TO CONTROL
    Dim ENG1 As Offset(Of Short) = New Offset(Of Short)(&H88C)
    Dim ENG2 As Offset(Of Short) = New Offset(Of Short)(&H924)
    Dim FLAPS As Offset(Of Short) = New Offset(Of Short)(&HBDC)
    Dim SPOILERS As Offset(Of Short) = New Offset(Of Short)(&HBD0)
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        SerialPort1.Open()
        OpenFSUIPC() 'THE FSUIPC CALL TO THE DLL
        SerialPort1.DiscardInBuffer()
    End Sub
    Delegate Sub ProcessDataDelegate(ByVal I As Short, ByVal J As Short, ByVal K As Short, ByVal L As Short)
    'READ THE SERIAL PORT
    Private Sub SerialPort1_DataReceived(ByVal sender As Object, _
    ByVal e As SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
        Try
            ' READ THE SERIAL PORT ID.
            Dim I As Short = Val(SerialPort1.ReadLine())
            Dim J As Short = Val(SerialPort1.ReadLine())
            Dim K As Short = Val(SerialPort1.ReadLine())
            Dim L As Short = Val(SerialPort1.ReadLine())
            Me.Invoke(New ProcessDataDelegate(AddressOf ProcessData), I, J, K, L)
        Catch ex As Exception
            'MessageBox.Show(ex.ToString)
            ' SerialPort1.Close()
        End Try
    End Sub
    Sub ProcessData(ByVal I As Short, ByVal J As Short, ByVal K As Short, ByVal L As Short)
        TextBox1.Text = ENG1.Value
        TextBox2.Text = ENG2.Value
        TextBox3.Text = FLAPS.Value
        TextBox4.Text = SPOILERS.Value
        ' THE READ VALUE TO USE
        ENG1.Value = I
        ENG2.Value = J
        FLAPS.Value = K
        SPOILERS.Value = L
        If ENG1.Value <= 0 Then
            ENG1.Value = ENG1.Value - 4096 ' TO GET ENGIN REVERSE
        End If
        If ENG2.Value <= 0 Then
            ENG2.Value = ENG2.Value - 4096 ' TO GET ENGIN REVERSE
        End If
    End Sub
    Private Sub OpenFSUIPC()
        Try
            ' Attempt to open a connection to FSUIPC (running on any version of Flight Sim)
            FSUIPCConnection.Open()
            Me.Timer1.Interval = 200
            Me.Timer1.Enabled = True
        End Try
    End Sub
    Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        Try
            ' Process the default group FSUIPC internal.
            FSUIPCConnection.Process()
        Catch exFSUIPC As FSUIPCException
            If exFSUIPC.FSUIPCErrorCode = FSUIPCError.FSUIPC_ERR_SENDMSG Then
                FSUIPCConnection.Close()
                'MessageBox.Show("The connection to Flight Sim has been lost.", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
            Else
                Throw exFSUIPC
            End If
        End Try
    End Sub
    Private Sub Form1_FormClosed(ByVal sender As System.Object, ByVal e As System.Windows.Forms.FormClosedEventArgs) Handles MyBase.FormClosed
        SerialPort1.Close()
    End Sub
End Class                            ' RON BUCHWALD 1/12/2012
wildbill
You could make life easier for yourself by sending some kind of 'begin packet' string before the sensor readings. Just  Serial.println("Start") would do. Then make your vb program ignore serial data until it sees start. Then at least you will know where you are in the data stream.
rondog
Hi and thanks BUT how do I say that in VB, like this?
        Try
if (SerialPort1.ReadLine()) =("start") then
end if
End Try
    End Sub
            I don't know how to write it...Ron.
