Topic: Optiboot issue where last bytes of an upload are 0xFF (Read 580 times) previous topic - next topic
JChristensen
A little issue that I chanced upon a couple weeks back, and which was nicely diagnosed with a lot of high-powered help from the forum :)
Not sure what the official process is, but it seems like a fix may be in order, or at least it should be added to the known errors list.
See: http://arduino.cc/forum/index.php/topic,84243.msg631767.html#msg631767
Coding Badly
Were you affected by the bug?  Did you have a sketch that failed to properly download?
JChristensen
Yes, although once the issue was understood it was easy enough to work around. I pared my sketch down to the bare minimum that would replicate the symptom, that sketch is in the first post of the referenced thread.
