Author Topic: Error on compile -stdlib.h not found  (Read 1336 times)
Cairns - Green Island for Winter
Can any guru tell me what is wrong here ?
here is the message given
/arduino-1.0/hardware/arduino/cores/arduino/Arduino.h:4:20: fatal error: stdlib.h: No such file or directory
compilation terminated.
Where should this file be and what is it trying to tell me ?
Actually I expanded the window and there is more to the message
avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -I/arduino-1.0/hardware/arduino/cores/arduino -I/arduino-1.0/hardware/arduino/variants/standard /tmp/build2733294214254685087.tmp/sketch_jan13a.cpp -o/tmp/build2733294214254685087.tmp/sketch_jan13a.cpp.o
In file included from sketch_jan13a.cpp:3:0:
Now I found a copy of that file in /usr/include  so I added that directory to my PATH
That did not fix it so
I added that to my LD PATH
That didn't fix it either ?
« Last Edit: January 12, 2012, 06:02:24 pm by tytower » Logged
Governments should do what they were designed to do only.
Manage the larger issues best done by Government.
My Family and my Property are not Government issues.
To stop corruption give them 3 times the normal penalty.
Have them agree on first appointment.
Massachusetts, USA
stdlib.h is part of the C/C++ standard library.
It should be under hardware/tools/avr/avr/include.
Looks like the avr-g++ installation is bad.
Yes Thanks .Thats on a Windows system
I am on a Linux system where the avr-g++ is installed by downloading , compiling and installing .
These are obtained from mirror repositories and I have tried a few versions from a few mirrors to no avail.
Are you having the problems with windows or linux? What distro? Do I see that you have arduino installed in the root directory? That sounds like a bad idea.
I am on a Linux system . Puppy Linux 5.3 in fact
Arduino is installed in my home directory but as I am root it matters not.
My problem is with "stdlib.h"
How does your post help me if thats what you intended?
I just wonder if you read my posts at all before posting your reply?
« Last Edit: January 14, 2012, 03:14:27 am by tytower » Logged
I have/had the same problem.  And actually johnwasser gave the correct answer that helped me solve the problem.
I am using Lubuntu 11.10 and because of John's answer I looked if there was something not installed for the avr compilation system.  And hey guess what there was.  I found it in Synaptic avr-libc was not installed.  I installed it and all was right with the world.
And tytower I suggest you find a way to deal with your stress a little better.  Everybody that answered was trying to help you.  Just as I am now.
[Moderator edit : Unwarranted vitriol removed.  AWOL]
It appears that the culprit is Puppy Linux 5.3
Version 5.3.1 runs Arduino well and I would say they patched it following my posts
[Moderator edit : More unwarranted vitriol removed.  AWOL]
« Last Edit: February 26, 2012, 12:00:23 pm by AWOL » Logged
So you're saying my question regarding what distro you're using was relevant?
