Loading...
Pages: [1]   Go Down
Author Topic: Arduino Ethernet Shield Program to Arduino WiFi Shield Program  (Read 337 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I want to take this code, that works great, and runs great on the Ethernet Shield.  Make it so it will run on the WiFi Shield.  Then I can go cordless with it.  What are the key things I need to change one the program?  If I know it all I would not be asking people on here.  So any cool input, would help out.
  Snail Mail Push Alerts by Matt Richardson
  Adapted from the Arduino WebClient example by David A. Mellis
  This sketch is part of a project which sends a push alert to your
  iPhone when your snail mail is delivered.
  This sketch requests a URL when a mailbox has been opened.
  The URL is a PHP script based on the ProwlPHP class.
  December 31, 2010
#include <SPI.h>
#include <Ethernet.h>
#define switchPin 7  // Snap action switch which closes when the mailbox door is opened.
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10,0,1,1 }; // local Arduino IP
byte server[] = { 1,1,1,1 }; // IP of your web server
Client client(server, 80);
  Ethernet.begin(mac, ip);
  pinMode(switchPin, INPUT);
  if (digitalRead(switchPin) == HIGH) // if mailbox is opened:
      Serial.println("Mailbox door opened");
    if (client.connect()) { //connect to server
      Serial.println("connected to server");
      // Make a HTTP request:
      client.println("GET /path/to/example.php"); //location of ProwlPHP script
      client.println();
    else {
      Serial.println("connection failed");
    Serial.print("Response from server: ");
    while (client.available()) {
      char c = client.read();
      Serial.print(c);
    // if the server's disconnected, stop the client:
    if (!client.connected()) {
      Serial.println("disconnecting from server");
      client.stop();
    while (digitalRead(switchPin) == HIGH)
      // hold here until mailbox is closed again.
    Serial.println("Mailbox door closed");
« Last Edit: January 14, 2012, 02:17:30 pm by Tricky12 » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
What do if have to change in the code?
You probably need to start with the IP addresses.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
