Topic: LCD+KEYPAD+SD SHEILD NEED HELP (Read 1 time) previous topic - next topic
cnavnath
HI,
     I WANT SHEILD FOR ARDIUNO UNO which have graphic LCD 5x6 keypad, and micro sd card in one pcd.
please help me
GaryP
You're not going to get nice replys for this one!
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
liuzengqiang
Cheers,
Kari
I was reading on one other thread the OP started here:
http://arduino.cc/forum/index.php/topic,86746.0.html
Similar requests with simple questions. Maybe that is OP's style?!
So for OP, what do you want? This hardware dev board/subforum is for hardware development. I suppose you want someone to develop such a shield and hand to you? Very unlikely though. Besides, you just upped your requirement from 16*4 character LCD to graphic LCD? Did you search google before asking this question?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
cnavnath
thanx for reply i search on google. but i am getting sheild separatly. i want it in same pcb.
liuzengqiang
Ok. It's unlikely that you can find exactly what you need. So what exactly is your project?
CrossRoads
5x6 keypad can be made, needs 11 pins.
uSD socket can be added, uses the 4 SPI pins. Need 5V to 3.3V converter chip for the SCK, MOSI, MISO, Chip Select line.
Browse here for a graphics LCD, all use parallel interface, 12 data pins, so 2 shift registers are needed, can use the SPI interface to load them up.
http://www.newhavendisplay.com/index.php?main_page=index&cPath=21
Same SPI pins as the uSD card, just need 1 more chip select pin.
Keep D0/D1 free for sketch downloading.
Thus use 11+4+1+2 = 18 of the 20 available IO lines.
Shield size will depend on the LCD panel selected, size of the buttons, surface mount or thru-hole support chips & caps.
