Loading...
Pages: [1]   Go Down
Author Topic: 1 wire communication problem  (Read 306 times)
Offline Offline
Newbie
View Profile
hi guys,
I'm trying to read 40bits from DHT11(Humidity and temperature sensor).
It uses 1 wire communication.
I need to pull LOW for 18ms, and then pull HIGH to request data from it.
It then send 40bits immediately, 28us represents"0" and 70us represents"1".
Here is the datasheet- www.robotshop.com/PDF/dht11.pdf
I've been trying to get data for several days with pulseIn() and I couldn't get it.
By using the code below,
Code:
#include <SoftwareSerial.h>
int response;
int data[40];
void setup(){
  pinMode(11,OUTPUT);
  digitalWrite(11,HIGH);
void loop(){
  pinMode(12,OUTPUT);
  digitalWrite(12,HIGH);
  digitalWrite(12,LOW);
  delay(18);
  pinMode(12,INPUT);
  response = pulseIn(12,HIGH);
  Serial.println(response);
  for (int i=0; i<40;i++){
     data[i] = pulseIn(12,HIGH);
     Serial.println(data[i]);
  delay(10000);
I gets
23
64
23
23
23
24
24
23
24
69
14
23
24
23
23
70
48
69
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
In contrast, by using a more stupid method,
Code:
int response;
int data[40];
void setup(){
  pinMode(11,OUTPUT);
void loop(){
  pinMode(12,OUTPUT);
  delay(18);
  pinMode(12,INPUT);
 *40 times!!!!!
  delay(10000);
guess what? I got only 8 none zero numbers!
Could anybody help with this problem? This is killing me~
Thanks!
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
I think the serial output might be taking so much time you miss most of the message.  Try removing these two lines:
Code:
Logged
Offline Offline
Newbie
View Profile
But in the first code, I tried to read all bits into an array first.
If this is still not fast enough, I could not figure out a faster way.
Any suggestion for a faster solution? would pointer help?
Thanks.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
If the first code you posted above is what you are calling 'the first code' you should read it again:
You signal for the DHT11 to start sending:
Code:
  delay(18);
Switch to input mode:
Code:
  pinMode(12,INPUT);
Measure the length of the acknowledgement pulse:
Code:
AND PRINT OUT THE LENGTH OF THE ACKNOWLEDGEMENT PULSE:
Code:
Before you fill the buffer with 40 more pulse lengths:
Code:
Logged
UK
Offline Offline
Tesla Member
View Profile
Are you rolling your own 1-wire library? Why not use the standard library? While you're at it, isn't there a driver library for that sensor too?
Logged
Offline Offline
Newbie
View Profile
I removed those two lines, I got 20bits instead of 19 previously.
Still it does not work.
I'm thinking if that is the problem of pulseIn function.
Thanks.
Code:
  delay(18);
Code:
  pinMode(12,INPUT);
Code:
Code:
Code:
Logged
Offline Offline
Newbie
View Profile
Thanks, I just found that there is a library of this.
 smiley-grin smiley-grin smiley-grin
Logged
Pages: [1]   Go Up
Print
Jump to:
