Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: not understanding 7 segment multiplexing  (Read 2120 times)
Ft. Worth, Texas
Offline Offline
God Member
View Profile
Are you putting down discrete pads vs chip symbols? Makes it hard to follow what you are doing.
Pic's are coming thru nice.
not sure exactly what you mean?
and I'm printing to A0 paper PDF as ~4x scale or so then converting to jpg.
Logged
KF5RVR
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Here's what I mean.
I layed out 10 LEDs, 2 resistors, a connector.
The board layout looks like it.
Yours just looks like a bunch of holes that are connected, can't tell what it is.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Ft. Worth, Texas
Offline Offline
God Member
View Profile
Here's what I mean.
I'm a beginner so you have to bear with me learning my way through eagle.
so if I go per http://arduino.cc/en/Tutorial/ArduinoToBreadboard minimalist approach and don't use a resonator/crystal, it will function at 1 MHz, right?
so 9600bps serial in code will actually be 9600/16 = 600bps?
If board space gets tight, I may need that extra little bit of space in leu of resonator. Didn't realize how hard it was going to be to fit all this stuff on a 2" square board. I'm gonna see how far I can get.
« Last Edit: January 11, 2012, 01:57:42 am by magnethead794 » Logged
KF5RVR
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I am not sure, I have not operated at other than 16 MHz in my designs.
Logged
Ft. Worth, Texas
Offline Offline
God Member
View Profile
I tallied it up. I can buy SF's small indicator cheaper than I can build it, when you calculate time. Maybe they'll have a new revision with mounting holes, if not, I came up with a mounting method. I thought about it, and having a 10K resistor on the VCC line shold somewhat make up for not having on on each digit supply.
Logged
KF5RVR
Ft. Worth, Texas
Offline Offline
God Member
View Profile
Here's where KirAsh and I landed. Only have to make 2 boards. Use the sparkfun board for indication, and use the selector board to run the Tx to the indicator and SPI to the shift registers. On the shift boards, the first one gets +12/+5/gnd through a 3 position terminal block, SPI over the Cat5, then it all gets passed on from pin headers.
http://i1105.photobucket.com/albums/h355/magnethead494/shift_board_brd.jpg
http://i1105.photobucket.com/albums/h355/magnethead494/shift_board_sch.jpg
http://i1105.photobucket.com/albums/h355/magnethead494/dial_board_selector_brd.jpg
http://i1105.photobucket.com/albums/h355/magnethead494/dial_board_selector_sch.jpg
Logged
KF5RVR
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
