Oh my, now the display doesnt react on anything. Tested it with lcd.lib following arduino, no response at all.
You probably just forgot to tell the LiquidCrystal library that you are using the RW pin. Your best bet is to just connect it (LCD pin 5) to GND.
Your own initialization sequence is almost correct. You messed up one bit in the 'Entry Mode Set' command.
Don
