Topic: Arduino Pong (Read 82955 times) previous topic - next topic
Alastair.Parker
Aug 21, 2007, 03:19 am Last Edit: Aug 21, 2007, 04:52 am by Alastair.Parker Reason: 1
Hello all,
I have been playing with pal signal generation, and decided to make pong as an example.
I based my video code on work by Benoît ROUSSEAU, found at
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1176757335.
But it didn't work for me, so I rewrote it using information found in.
http://www.amazon.com/Black-Video-Game-Console-Design/dp/0672328208
This code works for both of my (Australian) pal tvs.
All the source on one page
http://alastair.parker.googlepages.com/arduinopong
Title screen
during play
schematic
//Arduino Tv framebuffer
//Alastair Parker
//2007
// Video out voltage levels
#define _SYNC 0x00
#define _BLACK  0x01
#define _GRAY  0x02
#define _WHITE  0x03
// dimensions of the screen
#define WIDTH 38
#define HEIGHT 14
//number of lines to display
#define DISPLAY_LINES 240
// update speed for the main loop of the game
#define UPDATE_INTERVAL 1
// positions of the player paddles
#define PLAYER_RIGHT_X 35
#define PLAYER_LEFT_X 2
// maximum velocity of the ball
#define MAX_VEL 10
// locations of the top and bottom virtual bars
#define SCORE_BAR 3
#define BASE_BAR 13
// time to wait while paused
#define DONE_WAITING 30
#define SCORE_WAITING 30
// max player life
#define MAX_LIFE 6
//positions of player life bars
#define PLAYER_LEFT_LIFE 2
#define PLAYER_RIGHT_LIFE 23
// input pins for the player pots
#define PLAYER_LEFT_PIN 2
// currently the same pin
#define PLAYER_RIGHT_PIN 2
//video pins
#define DATA_PIN 9
#define SYNC_PIN 8
// the video frameBuffer
byte frameBuffer[WIDTH][HEIGHT];
// loop indices
byte index, index2;
// pal video line loop
byte line;
// current drawing line in framebuffer
byte newLine;
// flag used in wait loop to indicate that player just scored
boolean justScored=false;
// positions for the left paddle
byte playerLeft;
byte playerLeftOld=-1;
// life for the left player
byte playerLeftLife = MAX_LIFE;
// positions of the right paddle
byte playerRight;
byte playerRightOld=-1;
// life for the right player
byte playerRightLife = MAX_LIFE;
// positions and velocity of the ball
int ballXVel = -1;
int ballYVel = -5;
byte ballXPos = 14;
byte ballYPos = 7;
// loop counters to control the velocity of the ball
byte ballXLoop =MAX_VEL;
byte ballYLoop =MAX_VEL;
// loop counter to for the main loop delay
int waitingCount = 0;
// start postion of the loading bar
byte loadingBar = 2;
// if the left player should be updated or the right
boolean playerLeftTurn=true;
// if we should be waiting for something to happen
boolean waiting=true;
// if displaying the title
boolean showingTitle = true;
// value of the counter controlling the freq of updates
byte updateCounter=0;
// init the variables
void initGame()
 playerLeftOld=-1;
 playerRightOld=-1;
 ballXVel = -1;
 ballYVel = -5;
 ballXPos = 14;
 ballYPos = 7;
 ballXLoop =MAX_VEL;
 ballYLoop =MAX_VEL;
 waitingCount = 0;
 loadingBar = 2;
 waiting=true;
 justScored=false;
 updateCounter=0;
// draw a pixel to the buffer
void setPixel(byte x,byte y)
 frameBuffer[x][y]= _WHITE;
void grayPixel(byte x, byte y)
  frameBuffer[x][y]= _GRAY;
// draw a black pixel to the buffer
void clearPixel(byte x,byte y)
 frameBuffer[x][y]= _BLACK;
// draw a paddle
void drawPaddle(byte x,byte y,byte col)
 frameBuffer[x][y]= col;
 frameBuffer[x][y+1]= col;
//draw the title message
void drawArduinoPong()
 //arduino
 setPixel(7,3);
 setPixel(8,3);
 setPixel(15,3);
 setPixel(21,3);
 setPixel(6,4);
 setPixel(8,4);
 setPixel(14,4);
 setPixel(15,4);
 setPixel(28,4);
 setPixel(6,5);
 setPixel(7,5);
 setPixel(8,5);
 setPixel(10,5);
 setPixel(11,5);
 setPixel(13,5);
 setPixel(15,5);
 setPixel(17,5);
 setPixel(19,5);
 setPixel(21,5);
 setPixel(23,5);
 setPixel(24,5);
 setPixel(27,5);
 setPixel(29,5);
 setPixel(6,6);
 setPixel(8,6);
 setPixel(10,6);
 setPixel(14,6);
 setPixel(15,6);
 setPixel(18,6);
 setPixel(19,6);
 setPixel(21,6);
 setPixel(23,6);
 setPixel(25,6);
 setPixel(28,6);
 //pong
 setPixel(10,8);
 setPixel(11,8);
 setPixel(15,8);
 setPixel(16,8);
 setPixel(19,8);
 setPixel(22,8);
 setPixel(24,8);
 setPixel(25,8);
 setPixel(26,8);
 setPixel(10,9);
 setPixel(12,9);
 setPixel(14,9);
 setPixel(17,9);
 setPixel(19,9);
 setPixel(20,9);
 setPixel(22,9);
 setPixel(24,9);
 setPixel(10,10);
 setPixel(11,10);
 setPixel(14,10);
 setPixel(17,10);
 setPixel(19,10);
 setPixel(21,10);
 setPixel(22,10);
 setPixel(24,10);
 setPixel(26,10);
 setPixel(10,11);
 setPixel(15,11);
 setPixel(16,11);
 setPixel(19,11);
 setPixel(22,11);
 setPixel(24,11);
 setPixel(25,11);
 setPixel(26,11);
Alastair.Parker
next chunk o' code
// do the main game logic regarding the ball and collisions
void updateBall(boolean xEvent)
 // if checking the x coords of the ball
 if(xEvent)
   TODO
   have the yvel start 1t 1
    //check for collision with left player
    if(ballXPos <PLAYER_LEFT_X+2 & (playerLeft == ballYPos or playerLeft+1 == ballYPos))
      ballXVel = -1 * ballXVel;
      ballXPos=PLAYER_LEFT_X+1;
    //check for collision with right player
    if(ballXPos > PLAYER_RIGHT_X-2  & (playerRight == ballYPos or playerRight+1 == ballYPos))
      ballXPos=PLAYER_RIGHT_X-1;
    //move the ball in the x direction
    if(ballXVel < 1)
      ballXPos--;
        ballXPos++;
 //if checking the y coords
 if(!xEvent)
    //check for top of screen hit
    if( ballYPos <= SCORE_BAR )
      ballYVel = -1 * ballYVel;
      ballYPos = SCORE_BAR;
    //check for bottom of screen hit
    if( ballYPos>BASE_BAR )
      ballYPos = BASE_BAR+1;
    // move the ball in the y direction
    if(ballYVel < 1)
      ballYPos--;
      ballYPos++;
 //always check for scoring of points
 //right player scores
 if(ballXPos==PLAYER_LEFT_X)//0
   //reset the position of the ball
   ballXPos = PLAYER_RIGHT_X - 5;
   ballYPos=7;
   // change the other players life
   clearPixel(PLAYER_LEFT_LIFE+2*playerLeftLife-2,SCORE_BAR-1);
   playerLeftLife--;
   // indicate that someone scored so the wait doesn't start a new game
   justScored=true;
   // indicate that we should wait next loop
   waiting=true;
   // check if game is over
   if(playerLeftLife==0)
     justScored=false;
//left player scores
if(ballXPos==PLAYER_RIGHT_X)//38
   //reset position of ball
   ballXPos = PLAYER_LEFT_X + 5;
   ballYPos=7;
   //update other players score
   clearPixel(PLAYER_RIGHT_LIFE+2*(MAX_LIFE-playerRightLife)+2,SCORE_BAR-1);
   playerRightLife--;
   // indicate that someone scored so the wain doesn't start a new game
   justScored=true;
   waiting=true;
   // check for game over
   if(playerRightLife==0)
     justScored=false;
// draw the player life bars
void initScreen()
 for(index=1;index<=MAX_LIFE;++index)
   grayPixel(index*2,SCORE_BAR-1);
   grayPixel(index*2+PLAYER_RIGHT_LIFE,SCORE_BAR-1);
// draw the ball
void drawBall(byte col)
frameBuffer[ballXPos][ballYPos]=col;
// clear the screen
void clearScreen()
   for (index = 0; index < WIDTH; index++)
     for (index2=0;index2<=HEIGHT;++index2)
        frameBuffer[index][index2] = _BLACK;
// the setup routine
 pinMode (SYNC_PIN, OUTPUT);
 pinMode (DATA_PIN, OUTPUT);
 digitalWrite (SYNC_PIN, HIGH);
 digitalWrite (DATA_PIN, HIGH);
 clearScreen();
 drawArduinoPong();
 // iterate over the lines on the tv
 for ( line =0;line< DISPLAY_LINES;++line)
     // HSync
     // front porch (1.5 us)
     PORTB = _BLACK;
     delayMicroseconds(1.5);
     //sync (4.7 us)
     PORTB = _SYNC;
     delayMicroseconds(4.7);
     // breezeway (.6us) + burst (2.5us) + colour back borch (1.6 us)
     PORTB = _BLACK;
     delayMicroseconds(0.6+2.5+1.6);
     //calculate which line to draw to
     newLine = line >>4;
     delayMicroseconds(1);
     //display the array for this line
     // a loop would have been smaller, but it messes the timing up
     PORTB = frameBuffer[0][newLine];
     PORTB = frameBuffer[1][newLine];
     PORTB = frameBuffer[2][newLine];
     PORTB = frameBuffer[3][newLine];
     PORTB = frameBuffer[4][newLine];
     PORTB = frameBuffer[5][newLine];
     PORTB = frameBuffer[6][newLine];
     PORTB = frameBuffer[7][newLine];
     PORTB = frameBuffer[8][newLine];
     PORTB = frameBuffer[9][newLine];
     PORTB = frameBuffer[10][newLine];
     PORTB = frameBuffer[11][newLine];
     PORTB = frameBuffer[12][newLine];
     PORTB = frameBuffer[13][newLine];
     PORTB = frameBuffer[14][newLine];
     PORTB = frameBuffer[15][newLine];
     PORTB = frameBuffer[16][newLine];
     PORTB = frameBuffer[17][newLine];
     PORTB = frameBuffer[18][newLine];
     PORTB = frameBuffer[19][newLine];
     PORTB = frameBuffer[20][newLine];
     PORTB = frameBuffer[21][newLine];
     PORTB = frameBuffer[22][newLine];
Alastair.Parker
last chunk o' code
     PORTB = frameBuffer[23][newLine];
     PORTB = frameBuffer[24][newLine];
     PORTB = frameBuffer[25][newLine];
     PORTB = frameBuffer[26][newLine];
     PORTB = frameBuffer[27][newLine];
     PORTB = frameBuffer[28][newLine];
     PORTB = frameBuffer[29][newLine];
     PORTB = frameBuffer[30][newLine];
     PORTB = frameBuffer[31][newLine];
     PORTB = frameBuffer[32][newLine];
     PORTB = frameBuffer[33][newLine];
     PORTB = frameBuffer[34][newLine];
     PORTB = frameBuffer[35][newLine];
     // klugdge to correct timings
     PORTB = frameBuffer[36][newLine];
     PORTB=PORTB;
     PORTB=PORTB;
     PORTB=PORTB;
     delayMicroseconds(3);
 //vsync
 PORTB = _SYNC;
 // if delaying for some reason
 if(waiting)
     // increment the waiting counter
     waitingCount++;
     // if waiting is over for a new game
     if(waitingCount==DONE_WAITING & !justScored)
       waitingCount=0;
       // if on title screen
       if(showingTitle)
         // draw the loading bar
         grayPixel(loadingBar,BASE_BAR);
         loadingBar+=2;
         // done loading
         if (loadingBar > 37)
           showingTitle=false;
           clearScreen();
           initGame();
           initScreen();
           waiting=false;
     // waiting because someone scored
     if(waitingCount==SCORE_WAITING & justScored)
        justScored=false;
        waitingCount=0;
        waiting=false;
     // wait for the remainder of the sync period
     delayMicroseconds(305);
 // not waiting
   // increment the update delay counter
   updateCounter++;
   if( updateCounter >= UPDATE_INTERVAL)
     //player movement
     if(playerLeftTurn)
       drawPaddle(PLAYER_LEFT_X,playerLeftOld,_BLACK);
       playerLeft = analogRead(PLAYER_LEFT_PIN)>>6;
       if(playerLeft<SCORE_BAR)
         playerLeft=SCORE_BAR;
       if(playerLeft>BASE_BAR)
         playerLeft=BASE_BAR;
       drawPaddle(PLAYER_LEFT_X,playerLeft,_WHITE);
       playerLeftOld=playerLeft;
       playerLeftTurn=false;
       drawPaddle(PLAYER_RIGHT_X,playerRightOld,_BLACK);
       playerRight = analogRead(PLAYER_RIGHT_PIN)>>6;
       if(playerRight<SCORE_BAR)
         playerRight=SCORE_BAR;
       if(playerRight>BASE_BAR)
         playerRight=BASE_BAR;
       drawPaddle(PLAYER_RIGHT_X,playerRight,_WHITE);
       playerRightOld=playerRight;
     // remainder of sync period
     delayMicroseconds(10);
     updateCounter=0;
     delayMicroseconds(250);
     // perform ball x velocity delay
     ballXLoop--;
     if(ballXLoop <= abs(ballXVel) and ballXVel != 0)
       //ball movement;
       drawBall(_BLACK);
       updateBall(true);
       ballXLoop=MAX_VEL;
     // perform ball y velocity delay
     ballYLoop--;
     if(ballYLoop <= abs(ballYVel) and ballYVel != 0)
       //ball movement;
       drawBall(_BLACK);
       updateBall(false);
       ballYLoop=MAX_VEL;
     // draw new ball
     drawBall(_GRAY);
The pong code needs some work to make it better, but at least it works (for me anyway) as a proof of concept.
Alastair
dorkbotdc
benoit
#4
Aug 22, 2007, 12:21 pm Last Edit: Aug 22, 2007, 12:22 pm by Benoit Reason: 1
WOOOH ! GREAT JOB !
Cordialement,
Benoît ROUSSEAU
Alastair.Parker
Thanks for the comments, especially Benoit, as I based this on your code!
For a bit of a write up on the process, have a look at
Enjoy playing pong!
Alastair
ikaruga
WOAh !!! Awsome job !! I ve built it too based on your source, and will post some pics later today possibly, but I m having some sync issues, how should I edit it in order to make it work on NTSC ?
Thanks for sharing and good job !  ;D
Alastair.Parker
Heres some info that I forgot about, which is important if you guys are actually going to run pong!
In order to get the timings exact, you will need to disable the timer interrupt on the atmega168
Edit the file lib/targets/arduino/wiring.c
and block comment out the following
   // enable timer 0 overflow interrupt
#if defined(__AVR_ATmega168__)
   sbi(TIMSK0, TOIE0);
#else
   sbi(TIMSK, TOIE0);
#endif
ie:
make it look like this
   sbi(TIMSK0, TOIE0);
#else
   sbi(TIMSK, TOIE0);
#endif
Getting nstc to work.
According to http://www.amazon.com/Black-Video-Game-Console-Design/dp/0672328208
pal has 625 total lines (about 575 visible) and ntsc has 525(about 480 visible), because arduino pong ignores interlacing, the effective number of lines is cut in half.
If someone were to try to get it to work on ntsc, I would start by decreasing the number of displayed lines, which will probably mess up the timing, so some experimentation would be needed with the remainder of the delays after vsync.
Perhaps someone with an ntsc tv can have a go at hacking the code and then sharing the results so other ntsc hackers can enjoy pong aswell.
Sorry I can't be more help right now, I will try to look into it, but without an ntsc tv, testing is hard :)
Alastair
ikaruga
thanks alistair. I m gonna dedicate tonight 's .. night. at it. Will try to post my results !
ikaruga
DAMMNNNN I don t have any more 75() and 900() !!!!!  :'(
Alastair.Parker
The 75ohm is required, but the 450 and 900 arent so critical, more common values like 430 and 1k could probably be used instead, just remember to check the volatges before you plug anthing into the tv !
have a read of http://www.rickard.gunee.com/projects/video/pic/howto.php, he explains the overall process quite well, including voltage info
tvdbon
Very nice! I tried it tonight but with not much luck. BUT I don't have a 75 Ohm resistor so I tried a 68 and 85 resistor. I can see that the program is running, but it's jumpy and not very much in sync. Is it possible that this happens because I don't have 75 ohm resistor ? Also, you mentioned something about disabling the timer interrupt? Is this only for the atmega168 ? I'm running it on an atmega8.
We have PAL tv's here in South Africa so thats not the problem. Any information would be greatly appreciated. Once I get your example going I would like to try and get something like tetris or even snake going :)
agent_orange
Try putting
cli(); in the setup routine. That should disable the interrupts.
Alastair.Parker
disabling the timer is quite important, each scan line in the signal must take 63( +/- 0.5)us, if the interrupt fires during the line generation, it will blow out the timing significantly, I will try to take a picture of what I get when the timer is NOT disabled, then you can compare what you're getting.
I'm not too sure how to disable it on the amtega8, but try using agent_orange's solution of 'cli();' somewhere in the setup() routine.
with regards to the 75ohm resistor, I can't be sure how critical it is, the most important thing is that you can generate 4 distinct voltages wrt the tv signal pin.
the voltages that you are aiming for are close to:
sync = 0.0v
black = 0.33v
gray = 0.66
white 1v
I was able to generate approx:
sync = 0v
black= 0.30
gray = 0.64
white = 0.95
Check your results with a multimeter first, to see what you get.
Good luck!
Oh, on a side note, I can't verify how correct the PAL signal is, (I don't have an oscilloscope) so I only know that this works on the 2 tvs that I have (which are both pal, but quite new).
If anyone has actually got this working, maybe they could post back with their resistor values and geographical location.
Al
Alastair.Parker
Heres what I get (on the 168) when I don't disable the interrupt
And this is what I get when i put 'cli();' as the first line in setup()
So it seems that cli(); works just as well as changing wiring.c, and it's easier!
Thanks agent_orange.
If your getting something similar to the first img, try the cli(); method.
Al
