Topic: Virtual usb keyboard doesn't work (Read 794 times) previous topic - next topic
Zener_diod
Hi!
I used https://code.google.com/p/vusb-for-arduino/ library for working with usb.
Its photo of device (with Schematic)
I used this code
#include "UsbKeyboard.h"
void setup(){}
UsbKeyboard.update();
  UsbKeyboard.sendKeyStroke(KEY_R);
delay (1000);
Where is bug?
Thanks.
PeterH
Dunno - your code looks similar to the examples. Did you notice this comment in the readme?
  NOTE: The code will NOW ONLY WORK WITH THE PCB DESIGN
        *NOT* THE PROTOBOARD DESIGN.
If you haven't already checked it, I suggest you focus on the hardware design to make sure your circuit is correct for this version of the library.
I only provide help via the forum - please do not contact me for private consultancy.
Zener_diod
Thanks, But can u tell me difference with PCB and PROTOBOARD DESIGN
PeterH
No. Is there any reason you can't investigate this yourself?
