Netherlands
« Reply #15 on: October 29, 2012, 03:29:47 pm » |
You use a linked list for the PCintPin objects. you could keep this list in sorted order to speed up the average search time of void PCintPort::PCint() On average the nr of search steps would be half of the current implementation, - addPin would be slightly complexer to keep the list sorted. - http://stackoverflow.com/questions/4825030/c-add-to-linked-list-in-sorted-order - - addPin could detect that the pin already has in ISR() attached. - delPin does not need to change as it already can delete from the middle of the list it might be more robust to add a return value for addPin and delPin that indicates the #pins added /delete. addPin might return -1 if pin exist. These values can be propagated to attachInterrupt/detachIRQ. sofar my 2 cents Rob
Belgium
Arduino rocks; but with my plugin it can fly rocking the world ;-)
« Reply #16 on: October 29, 2012, 03:38:21 pm » |
Hi I tested the library with a mega. I can confirm following ports to work 15,A8,A9,A10,A11,A12,A13,A14,A15 I did not succeed in getting port 14 to work. Thanks for the great work. Best regards Jantje
Belgium
« Reply #17 on: October 30, 2012, 03:54:57 pm » |
playing a bit more I came to the conclusion you need to use 14 and 15 to get 15 to work. PCintPort::attachInterrupt(14, interruptroutine,CHANGE); PCintPort::attachInterrupt(15, interruptroutine,CHANGE); Makes pin 15 work but PCintPort::attachInterrupt(15, interruptroutine,CHANGE); Does not. Best regards Jantje
« Reply #18 on: November 03, 2012, 07:45:28 am » |
> The test for p == NULL should be directly after PCintPin* p=new PCintPin; > as one cannot access the members of p when p == NULL
Fixed. Nice catch, thanks! -GreyGnome
« Reply #19 on: November 03, 2012, 01:53:23 pm » |
You use a linked list for the PCintPin objects. you could keep this list in sorted order to speed up the average search time of void PCintPort::PCint() On average the nr of search steps would be half of the current implementation, - addPin would be slightly complexer to keep the list sorted. - http://stackoverflow.com/questions/4825030/c-add-to-linked-list-in-sorted-order - - addPin could detect that the pin already has in ISR() attached. - delPin does not need to change as it already can delete from the middle of the list it might be more robust to add a return value for addPin and delPin that indicates the #pins added /delete. addPin might return -1 if pin exist. These values can be propagated to attachInterrupt/detachIRQ. Thanks for the feedback, Rob. I had considered the sorted linked list, but then I realized that sorting on pin number may not be what the user wants. It only speeds up the average search time if you can guarantee an even distribution of interrupts. I would rather let the programmer decide in which order he or she decides to add pins. Having addPin() and attachInterrupt() return values seems pretty easy and somewhat smart, so I will look into doing that.
Netherlands
« Reply #20 on: November 03, 2012, 02:18:22 pm » |
I would rather let the programmer decide in which order he or she decides to add pins. You have a point, and it should be made clear in the documentation that adding the most interrupted pin as first gives a better overall performance as it is found fastest.
Dubai, UAE
« Reply #21 on: November 04, 2012, 12:12:27 am » |
On the subject of letting the programmer take responsibilty it would be nice to add an option to skip all of the rising/falling tests inside the inner loop of the ISR, it adds a few cycles in the most repeated part of the ISR code. Duane B rcarduino.blogspot.com
Netherlands
« Reply #22 on: November 04, 2012, 03:58:35 am » |
reviewed again, #define PCINT_VERSION 2020 // This number MUST agree with the version number, above. In the Add function, this line p->PCintFunc=userFunc; must be moved upwards so that when adding the new PCint object to the list, the function is available. Now there is still a race condition possible, that p is added to the list but the function is not in place. I think if (thisChangedPin) { if ((thisChangedPin & portRisingPins & PCintPort::curr ) || (thisChangedPin & portFallingPins & ~PCintPort::curr )) {
can be optimized as [ portRisingPins & PCintPort::curr ] and [ portFallingPins & ~PCintPort::curr] are invariant in the loop Rob
« Last Edit: November 04, 2012, 03:20:09 pm by robtillaart »
Netherlands
« Reply #23 on: November 04, 2012, 07:33:54 am » |
Looked at the PCint() code and came up with this. + precalculated fastMask to simplify and speed up the mask testing in the inner while loop. + thisChangedPin optimized away # The var changedPins can be optimized away but probably the compiler will see that too. Can you give it a try? void PCintPort::PCint() { #ifdef FLASH if (*led_port & led_mask) *led_port&=not_led_mask; else *led_port|=led_mask; #endif #ifndef DISABLE_PCINT_MULTI_SERVICE uint8_t pcifr; do { #endif // get the pin states for the indicated port. uint8_t changedPins = PCintPort::curr ^ lastPinView; lastPinView = PCintPort::curr; uint8_t fastMask = changedPins & ((portRisingPins & PCintPort::curr ) | ( portFallingPins & ~PCintPort::curr )); // bitwise OR is needed here // if fastmask eq zero there will be no irq in the linked list, optimization! if (fastMask != 0) { PCintPin* p = firstPin; while (p) { if (p->mask & fastMask){ #ifndef NO_PIN_STATE PCintPort::pinState=PCintPort::curr & p->mask ? HIGH : LOW; #endif #ifndef NO_PIN_NUMBER PCintPort::arduinoPin=p->arduinoPin; #endif #ifdef PINMODE PCintPort::pinmode=p->mode; #endif p->PCintFunc(); } p = p->next; } // while(p) } #ifndef DISABLE_PCINT_MULTI_SERVICE pcifr = PCIFR & PCICRbit; PCIFR = pcifr; // clear the interrupt if we will process it (no effect if bit is zero) } while(pcifr); #endif }
Dubai, UAE
« Reply #24 on: November 04, 2012, 07:40:14 am » |
Excellent, thats going to save a lot of cycles, thanks Duane B rcarduino.blogspot.com
Netherlands
« Reply #25 on: November 04, 2012, 07:53:37 am » |
If you have the new numbers can you post them?
Dubai, UAE
« Reply #26 on: November 04, 2012, 08:01:15 am » |
I actually commented these tests out in my pinchangeint.cpp a long time back - but its nice to see that you have been able to eliminate them while retaining the functionality. I might find time tonight to dissassemble the before and after versions for a comparison Duane B rcarduino.blogspot.com
« Reply #27 on: November 04, 2012, 12:10:15 pm » |
Looked at the PCint() code and came up with this. // if fastmask eq zero there will be no irq in the linked list, optimization! if (fastMask != 0) { } Thanks, Rob. That looks like a really good idea; I'm going to change it and run a speed test. I note that the if statement, above, is certainly (in my mind) not needed, because of the portPCMask. Unless the programmer is creating Pin Change Interrupts outside of this library, any pin that interrupts will by definition mean that fastmask is non-zero. Also, I have simplified the boolean a little bit so rather than calling it "fastmask", I rather like to leave it at "changedpins" since that is what the bitmask represents. Hence we have: uint8_t changedPins = PCintPort::curr ^ lastPinView & (portRisingPins & (PCintPort::curr | portFallingPins));
We'll see if these optimizations make the code any faster; the compiler is pretty good at getting rid of cruft I think; whether it was able to optimize the invariants, I think the speed test will tell. Thanks for the optimizations!
Netherlands
« Reply #28 on: November 04, 2012, 12:32:57 pm » |
Calling it changedPins is better, just as you say.
don't know if the boolean expression is optimized right,
(portRisingPins & (PCintPort::curr | portFallingPins) equals ?? (portRisingPins & PCintPort::curr ) | ( portFallingPins & ~PCintPort::curr ) ??
because of the ~ (negation) you may not apply de Morgans law? or did I miss something?. Could you print both expressions to debug to check this? (no free arduino nearby)
Dubai, UAE
« Reply #29 on: November 04, 2012, 12:42:11 pm » |
This is the pinchangeint inner loop prior to the optimisations being discussed here, for those watching the discussion, this is the most important part to optimise because it is potentially executed many times on each interrupt - A lot of the code is relating to the if statements - thisChangedPin=p->mask & changedPins; 340: 6b 81 ldd r22, Y+3 ; 0x03 342: 8f 2d mov r24, r15 344: 86 23 and r24, r22 if (thisChangedPin) { 346: 71 f1 breq .+92 ; 0x3a4 <_ZN9PCintPort5PCintEv+0x86> if ((thisChangedPin & portRisingPins & PCintPort::curr ) || 348: 48 2f mov r20, r24 34a: 50 e0 ldi r21, 0x00 ; 0 34c: f8 01 movw r30, r16 34e: 85 81 ldd r24, Z+5 ; 0x05 350: 20 91 44 01 lds r18, 0x0144 354: 90 e0 ldi r25, 0x00 ; 0 356: 84 23 and r24, r20 358: 95 23 and r25, r21 35a: 30 e0 ldi r19, 0x00 ; 0 35c: 82 23 and r24, r18 35e: 93 23 and r25, r19 360: 89 2b or r24, r25 362: 69 f4 brne .+26 ; 0x37e <_ZN9PCintPort5PCintEv+0x60> 364: 86 81 ldd r24, Z+6 ; 0x06 366: 20 91 44 01 lds r18, 0x0144 36a: 90 e0 ldi r25, 0x00 ; 0 36c: 48 23 and r20, r24 36e: 59 23 and r21, r25 370: 30 e0 ldi r19, 0x00 ; 0 372: 20 95 com r18 374: 30 95 com r19 376: 42 23 and r20, r18 378: 53 23 and r21, r19 37a: 45 2b or r20, r21 37c: 99 f0 breq .+38 ; 0x3a4 <_ZN9PCintPort5PCintEv+0x86> (thisChangedPin & portFallingPins & ~PCintPort::curr )) { // Trigger interrupt if the bit is high and it's set to trigger on mode RISING or CHANGE // Trigger interrupt if the bit is low and it's set to trigger on mode FALLING or CHANGE #ifndef NO_PIN_STATE PCintPort::pinState=PCintPort::curr & p->mask ? HIGH : LOW; 37e: 20 91 44 01 lds r18, 0x0144 382: 40 e0 ldi r20, 0x00 ; 0 384: 86 2f mov r24, r22 386: 90 e0 ldi r25, 0x00 ; 0 388: 30 e0 ldi r19, 0x00 ; 0 38a: 82 23 and r24, r18 38c: 93 23 and r25, r19 38e: 89 2b or r24, r25 390: 09 f0 breq .+2 ; 0x394 <_ZN9PCintPort5PCintEv+0x76> 392: 41 e0 ldi r20, 0x01 ; 1 394: 40 93 46 01 sts 0x0146, r20 #endif #ifndef NO_PIN_NUMBER PCintPort::arduinoPin=p->arduinoPin; 398: 8c 81 ldd r24, Y+4 ; 0x04 39a: 80 93 45 01 sts 0x0145, r24 #endif #ifdef PINMODE PCintPort::pinmode=p->mode; #endif p->PCintFunc(); 39e: e8 81 ld r30, Y 3a0: f9 81 ldd r31, Y+1 ; 0x01 3a2: 09 95 icall } } p=p->next; 3a4: 0d 80 ldd r0, Y+5 ; 0x05 3a6: de 81 ldd r29, Y+6 ; 0x06 3a8: c0 2d mov r28, r0 uint8_t changedPins = PCintPort::curr ^ lastPinView; //changedPins &= portPCMask; lastPinView = PCintPort::curr;
PCintPin* p = firstPin; // 3427 while (p) { 3aa: 20 97 sbiw r28, 0x00 ; 0 3ac: 49 f6 brne .-110 ; 0x340 <_ZN9PCintPort5PCintEv+0x22> } } p=p->next;
Disassembled by following this procedure - http://rcarduino.blogspot.com/2012/09/how-to-view-arduino-assembly.htmlDuane B
