Loading...
Pages: 1 [2] 3   Go Down
Author Topic: 9 volt battery clip!  (Read 807 times)
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You haven't told us what you're doing, so "full power" is pretty meaningless.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Jr. Member
View Profile
i am making a robot and for just testing to. But how do i make a 5V switching regulator? or like what should i doD:?
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
That depends on two factors:
1. The Ah (or mAh) of the battery.
2. The current draw of your device.
The battery will be able to supply a limited amount of current.  This is measured in Ah or mAh - Ampere-hours or Milliampere-hours.  If you draw this amount of current, the battery will be flat in an hour.
If you draw half the Ah rating of current, the battery will last about twice as long.
For example, a battery rated at 2200mAh (that's 2.2Ah) can supply 2.2A and it will be flat in an hour.  If you draw just 1.1 amps from it you can expect about 2 hours from it.  0.55A (550mA - roughly what USB can supply) would last you about 4 hours.
If you use the on-board regulator, things get even worse.  This is a "linear" regulator.  The current you pull from it is the current it draws from the battery, but the voltage drops.  That dropped voltage is converted into heat, so it gets hot.
Say you draw 0.5A from the battery.  It's a 9V battery, with a 5V regulator.  So, we are getting 5V times 0.5A, which is 2.5W of power.  But, the regulator is drawing the same 0.5A but at 9V.  That is a whopping 4.5W.  Two whole watts of power go to waste.  That's almost 50% of your power.  So, you can expect your battery to last about half as long!
Use a switching regulator, and the efficiency goes up from around the 15% of a linear regulator, to say 85% or 90%.  A switching regulator converts the excess voltage into current, so if you ask for 0.5A at 5V, the 9V gets stepped down (kind of like with a transformer) and the current gets stepped up.  So, if we're drawing 2.5W, with a 90% efficient switching regulator, that would mean the regulator would be drawing 2.78W - considerably less.  That would equate to 2.78W/9V = 0.3A.
That's quite a saving.
Logged
Offline Offline
Jr. Member
View Profile
OK> thank you alot:D here i wanna buy this: http://www.amazon.com/7805-5V-Voltage-Regulator-TO-220/dp/B0002ZPXJ6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1326662759&sr=1-1
So it takes the 9 volts and it truns it into 5 volts? and saves the uther 4 volts?
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
No.  That's a linear regulator.
Switching regulators are somewhat more complex and require external components.
You are best off (unless you are making a professional product) butchering a car USB adaptor like this: http://www.amazon.com/Cigarette-Lighter-Charger-Adapter-Sony-PSP/dp/B002LTWF8S/ref=sr_1_27?ie=UTF8&qid=1326663025&sr=8-27
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
i am making a robot
Can we stop playing "20 Questions" and start putting numbers and specs to this vague hand-waving?
Logged
Offline Offline
Jr. Member
View Profile
wait so how do i use a 5v reglater?
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Quote
The one I posted a link to - you provide the 9V at one end, and the 5V comes out the other.
If you want to roll your own, then the first job is to look for a suitable switching regulator chip, then read the data sheet and build upon the example circuit you will find in there.
Logged
Offline Offline
Jr. Member
View Profile
but what should i do about later i wanna learn and what ones should i get?
Logged
Offline Offline
Jr. Member
View Profile
is this a good one? STMICROELECTRONICS - L4940V5 - IC, LDO VOLT REG, 5V, 1.5A, TO-220
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Nonono!  You are still looking at linear regulators.
You should be hitting the IC manufacturers.  Take a look at these links:
http://para.maxim-ic.com/en/search.mvp?fam=stepdn&tree=powersupplies
http://www.ti.com/ - take a look at the "WebBench" panel in the bottom right
http://www.analog.com/en/power-management/switching-regulators-integrated-fet-switches/products/index.html
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Oh, and note that you can't just get a switching regulator and drop it into your supply.  You need external components - typically a schottky diode, an inductor or two, some capacitors, resistors, etc....
Logged
Offline Offline
Jr. Member
View Profile
and all of this is just for making the battery last longer?  O and what should i put for max,  min, vout, lout?
Logged
UK
Offline Offline
Tesla Member
View Profile
You're making a robot? With wheels and motors and arms and wotnot? How are you going to power it? What Voltage and Amperage supplies will it need? It's pretty likely that will use vastly more power than the little Arduino, so it would be sensible to use that as the source for your Arduino's regulator too. Maybe just using the Arduino's existing on-board regulator, if the numbers come out right.
Logged
Offline Offline
Jr. Member
View Profile
 I wish there was a easy way like i am just geting more comfuesd.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
