Topic: Serial communication between Python and off-board Arduino (Read 1 time) previous topic - next topic
grmnygrmny
Hello,
I'm working on a project that involves two Arduinos implemented off-board receiving serial data from a computer.
Currently I've got the project receiving the data from the MIDI output on my Firebox, which works great (inexplicably - didn't use an optoisolator and it doesn't like to receive MIDI data from any other devices).  What I'd like to do is use my Arduino board (ATmega-less) for its USB-Serial chip and communicate directly Python -> ATmegas.
I'm concerned that there's some sort of message mismatch, maybe bytes or something.
On the Arduino, this is what I'm doing:
Code: [Select]
byte incomingByte;
incomingByte = Serial.read();
if (Serial.available() > 0) {
    if (incomingByte== 176){
      action=1;
    else if ( (action==1)&&(controller==0) ){
      controller=incomingByte;
    }else if ( (action==1)&&(controller!=0) ){
      value=incomingByte;
      writeLights(controller, value);
      controller=0;
      value=0;
      action=0;
    }else{
and this is what I was doing with Python:
Code: [Select]
ser = serial.Serial("/dev/tty.usbserial-A6008hrf", 31250)
def sendMidi(status, controller, value):
ser.write(str(status))
ser.write(str(controller))
ser.write(str(value))
def main():
sendMidi(176, 37, 127)
Now I was hoping that I could just connect the Serial RX pin on the Arduino board (ATmega-less) to the Serial RX pin on my off-board Arduino.  This didn't work.  The board's Rx LED lit up, so it's receiving something... I'm just not entirely sure how to troubleshoot this.  I would love to know the actual bytes coming off the Arduino, but I don't have an LCD...
skyjumper
Why are you doing a Serial.read() before checking to see if there is any data to be read?
grmnygrmny
Err that'd be a typo.  It's not there in my real code.
