Loading...
Pages: 1 ... 4 5 [6]   Go Down
Author Topic: Arduino-Controlled RC Transmitter  (Read 10998 times)
Netherlands
Offline Offline
Sr. Member
View Profile
No, you are mixing up the Wii remote (wireless) with the Wii Nunchuck (wired). Here is an image:
You can get them for a few dollars, for example here: http://www.dealextreme.com/details.dx/sku.24529
Logged
Panama City, FL USA
Offline Offline
Jr. Member
five by five
View Profile
fmkit has the nunchuck transmitter mastered.
http://www.fmtv.us/wii_nunchuck_rc.html
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
This is a pretty good idea I wanted to do this for my project
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi, i bought a Wii Remote and a Nunchuck and use them together with OSCulator (OSCulator is simulating a Joystick HID on my MAC)
Both devices are full 16 Bit resolution (technically) and are working as input for my Arduino via Serial Port.
They gyros are way to sensitive as control for RC Servos. If you flatten out the jitter from the Gyros the reaction time for the servos goes down (maybe the use of vectors could help but i will not dig into that).
The Joystick on the nunchuck gives great results! It has a stable and good resolution and its possible to control Servos very fast and precise. But it has be be kept in mind that RC Servos (altlast all Analog ones that i own) have at best a resolution of 1.5 to 2 Degrees.
Next will be a test of a good "normal" Joystick. The old 8-Bit USB which i own is not really useable because its just wobbly and the values i read are not stable (Value - Postion of Joystick).
Anyone knows which Diode i should use to protect PIN 10 on my Arduinos?
PS: Thanks for the tip with the Wii!  smiley
Logged
Netherlands
Offline Offline
Sr. Member
View Profile
No thanks for the tip on the Wii, glad you like them.
You shouldn't have problems with the sensitivity on the Nunchuck. I know they are being used for controlling r/c aircraft, so you maybe the problem is in your code? Can you show the code you tested with?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Even if the controller is just sitting on my desk i get readings from 316651 to 31995 and as a result an output of 1035-1045 for the PPM on that channel.
I now changed the Serial Data from distinct channels to one array for all channels and with the "smooth" function on OSCulator at 40 the gyros are usable as control for a Servo smiley
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Super smiley you get A for this smiley
Logged
India
Offline Offline
Full Member
The Tech Gamer
View Profile
WWW
This one helped me! Ty matt!
Logged
|I love Technology|
Pages: 1 ... 4 5 [6]   Go Up
Print
Jump to:
