Collbató, Barcelona
Offline
Full Member
« Reply #375 on: August 15, 2012, 09:28:52 am » |
Ok, aquí te dejo el codigo de ejemplo del corte de un cuadrado de 100x100 mm con 10 mm de profundidad cortado con una fresa de 3.175 mm de diametro. las caracteristicas de la fresa seleccionada son las siguientes:  He utilizado un Posp más estandar. La altura de seguridad para los desplazamientos es de 5 mm. T1M6 G0Z5.000 G0X0.000Y0.000S15000M3 G0X-99.875Y-101.463Z5.000 G1Z-2.500F3000.0 G1X-100.105Y-101.446F4560.0 X-100.341Y-101.392 X-100.576Y-101.300 X-100.798Y-101.167 X-100.998Y-100.998 X-101.167Y-100.798 X-101.300Y-100.576 X-101.392Y-100.341 X-101.446Y-100.105 X-101.463Y-99.875 Y0.125 X-101.446Y0.355 X-101.392Y0.591 X-101.300Y0.826 X-101.167Y1.048 X-100.998Y1.248 X-100.798Y1.417 X-100.576Y1.550 X-100.341Y1.642 X-100.105Y1.696 X-99.875Y1.713 X0.125 X0.355Y1.696 X0.591Y1.642 X0.826Y1.550 X1.048Y1.417 X1.248Y1.248 X1.417Y1.048 X1.550Y0.826 X1.642Y0.591 X1.696Y0.355 X1.713Y0.125 X1.713Y-99.875 X1.696Y-100.105 X1.642Y-100.341 X1.550Y-100.576 X1.417Y-100.798 X1.248Y-100.998 X1.048Y-101.167 X0.826Y-101.300 X0.591Y-101.392 X0.355Y-101.446 X0.125Y-101.463 X-99.875 G1Z-5.000F3000.0 G1X-100.105Y-101.446F4560.0 X-100.341Y-101.392 X-100.576Y-101.300 X-100.798Y-101.167 X-100.998Y-100.998 X-101.167Y-100.798 X-101.300Y-100.576 X-101.392Y-100.341 X-101.446Y-100.105 X-101.463Y-99.875 Y0.125 X-101.446Y0.355 X-101.392Y0.591 X-101.300Y0.826 X-101.167Y1.048 X-100.998Y1.248 X-100.798Y1.417 X-100.576Y1.550 X-100.341Y1.642 X-100.105Y1.696 X-99.875Y1.713 X0.125 X0.355Y1.696 X0.591Y1.642 X0.826Y1.550 X1.048Y1.417 X1.248Y1.248 X1.417Y1.048 X1.550Y0.826 X1.642Y0.591 X1.696Y0.355 X1.713Y0.125 X1.713Y-99.875 X1.696Y-100.105 X1.642Y-100.341 X1.550Y-100.576 X1.417Y-100.798 X1.248Y-100.998 X1.048Y-101.167 X0.826Y-101.300 X0.591Y-101.392 X0.355Y-101.446 X0.125Y-101.463 X-99.875 G1Z-7.500F3000.0 G1X-100.105Y-101.446F4560.0 X-100.341Y-101.392 X-100.576Y-101.300 X-100.798Y-101.167 X-100.998Y-100.998 X-101.167Y-100.798 X-101.300Y-100.576 X-101.392Y-100.341 X-101.446Y-100.105 X-101.463Y-99.875 Y0.125 X-101.446Y0.355 X-101.392Y0.591 X-101.300Y0.826 X-101.167Y1.048 X-100.998Y1.248 X-100.798Y1.417 X-100.576Y1.550 X-100.341Y1.642 X-100.105Y1.696 X-99.875Y1.713 X0.125 X0.355Y1.696 X0.591Y1.642 X0.826Y1.550 X1.048Y1.417 X1.248Y1.248 X1.417Y1.048 X1.550Y0.826 X1.642Y0.591 X1.696Y0.355 X1.713Y0.125 X1.713Y-99.875 X1.696Y-100.105 X1.642Y-100.341 X1.550Y-100.576 X1.417Y-100.798 X1.248Y-100.998 X1.048Y-101.167 X0.826Y-101.300 X0.591Y-101.392 X0.355Y-101.446 X0.125Y-101.463 X-99.875 G1Z-10.000F3000.0 G1X-100.105Y-101.446F4560.0 X-100.341Y-101.392 X-100.576Y-101.300 X-100.798Y-101.167 X-100.998Y-100.998 X-101.167Y-100.798 X-101.300Y-100.576 X-101.392Y-100.341 X-101.446Y-100.105 X-101.463Y-99.875 Y0.125 X-101.446Y0.355 X-101.392Y0.591 X-101.300Y0.826 X-101.167Y1.048 X-100.998Y1.248 X-100.798Y1.417 X-100.576Y1.550 X-100.341Y1.642 X-100.105Y1.696 X-99.875Y1.713 X0.125 X0.355Y1.696 X0.591Y1.642 X0.826Y1.550 X1.048Y1.417 X1.248Y1.248 X1.417Y1.048 X1.550Y0.826 X1.642Y0.591 X1.696Y0.355 X1.713Y0.125 X1.713Y-99.875 X1.696Y-100.105 X1.642Y-100.341 X1.550Y-100.576 X1.417Y-100.798 X1.248Y-100.998 X1.048Y-101.167 X0.826Y-101.300 X0.591Y-101.392 X0.355Y-101.446 X0.125Y-101.463 X-99.875 G0Z5.000 G0X0.000Y0.000 G0Z5.000 G0X0Y0 M30
Si necesitas más datos me lo comentas. Un Saludo Jomagom.
Logged
Offline
Newbie
« Reply #376 on: August 15, 2012, 10:25:39 am » |
@Jomagom; si se pueden generar Gcodes con artcam, al generarlos desde artcam selecciona como maquina "flexicam (mm)(*.GC), el archivo generado te lo acepta muy bien. Con otras extensiones ( al menos a mi) da error de limites no detectados y cosas raras. No lo probé ,pero creo que como ISO también se puede.
Logged
Sabadell
Offline
Full Member
« Reply #377 on: August 15, 2012, 02:13:10 pm » |
Pues no había hecho todavía ninguna pieza desde cero a escala 1:1 y la pregunta me ha parecido tan interesante que me he puesto manos a la obra, así me servirá como aprendizaje. Por lo que dices tendría que hacer un "grabado" que es lo que regula la profundidad de la fresa, pero he optado por otro camino ya que no se porqué todavía no me sale el grabado, ( habrá algo mal configurado ),he hecho un trayecto a gcode con diferentes pasadas hasta completar los 10 mm de profundidad, y cual a sido mi sorpresa que me ha salido bien a la primera. Por supuesto he contado el trazo en Inkscape de 3 mm,y después también en "biblioteca de herramientas", por lo tanto el circulo hace 56 mm de diámetro de exterior y 50 de interior, esto me va a servir para reutilizar brocas normales de 3 mm. Me anima mucho el resultado, hay mucha precisión en la escala. Prueba el fichero gcode a ver si te resulta igual de efectivo Por cierto Mach 3 no es de licencia???? Un saludo
Logged
Collbató, Barcelona
Offline
Full Member
« Reply #378 on: August 15, 2012, 03:36:39 pm » |
Ok, sabiendo que con artcam se generan las trayectorias correctamente me anima para utilizar el soft de txapu, en unos días empiezo con las pruebas ya que dispongo de unos drivers que funcionan correctamente.
Terraguea: Una pregunta, te importaría decirme que fresas usas para el metraquilato,la velocidad de la maquína y el avance por minuto que tienes configurado. UN Saludo Jomagom
« Last Edit: August 15, 2012, 05:32:35 pm by Jomagom »
Logged
Sabadell
Offline
Full Member
« Reply #379 on: August 16, 2012, 04:07:23 am » |
Wuenas, como he comentado en el post anterior y en fotos que he puesto en otros, las brocas que utilizo son normales para metales, entiendo que para este metacrilato , en este caso es un policarbonato no demasiado duro, podría utilizar brocas para madera igual que para DM. Hace un par de páginas hablábamos de la conveniencia de utilizar brocas específicas para emplear en el husillo ( o cabezal ) de la fresadora, en mi caso una black and decker rt650, que si no recuerdo mal está entre 30.000 y 35.000 rpm al máximo, por supuesto para este tipo de material no es necesario, así que lo tengo en una potencia media, he probado de hacerlas al mínimo y también trabajan bien. El problema se plantea cuando utilizas brocas normales para metales de cuerpo recto y requieres diámetros muy pequeños ( para PCB's y cosas por el estilo), de 1mm o menos, la excentricidad radial que producen es muy alta, así que se habló de la necesidad de usar brocas específicas con cuerpo de 3 mm para ajustarse a husillo pero con reducción en la punta,(adjunto fotografía)eso si, son mucho más caras, por la zona del Vallés todavía no las he encontrado, pero por la red las más baratas salen por 3-3,5 €uracos.Por esto te decía que me iba muy bien emplear esas brocas de 3 mm de diámetro, ya que se ajustan perfectamente a los husillos de 3mm, pero no sólo en boca, sino en todo el recorrido. Se me ha ocurrido empleando cánulas de bolígrafos fijar mejor las brocas dentro del husillo con resultados óptimos, por ahora y a falta de encontrar brocas o fresa específicas será la solución. Respecto a la velocidad si te soy sincero no tengo ni idea, lo que hago es poner al máximo el avance en el panel de control de txapuCNC_tx. Pongo unas fotografías de todo un poco y así se entenderá mejor,un saludo.
« Last Edit: August 16, 2012, 04:09:03 am by Terraguea »
Logged
Málaga, Spain
Offline
Edison Member
« Reply #380 on: August 16, 2012, 06:55:58 am » |
@Jomagom - he probado el "gcode" que has publicado y no lo interpreta ninguno de los programas. Ni el secuenciador y evidentemente tampoco la aplicación embarcada.
Podríais publicar algo generado con artcam usando la configuración que sugiere gonga: flexicam (mm)(*.GC) y lo paso por los diversos programas de secuenciación e intérpretes.
Logged
Offline
Sr. Member
« Reply #381 on: August 16, 2012, 06:29:22 pm » |
@Terraguea - Para fresar una superficie plana, que fresa seria la adecuada?
Quiero fresar toda la superficie de trabajo para tenerla correctamente alineada por si tuviera algun pequeño error en el montaje, y pensando, no se muy bien que fresa usar.
Cada vez sacas mejores trabajos con el metacrilato, estas hecho todo un genio. Lo malo es que te vamos a llenar de preguntas por ser el avanzado del grupo :p
Logged
Collbató, Barcelona
Offline
Full Member
« Reply #382 on: August 16, 2012, 06:35:46 pm » |
Ok, aquí te lo dejo: cuadrado de 50x50 mm fresa usada 3.175 profundidad máxima por pasada 3 mm. Al ser el corte de la pieza de 10 mm hace 4 pasadas de 2.5 mm por pasada. Extensión del archivo generado (*.GC) creado con el postp Flexicam (mm) Altura de seguridad en el desplazamiento de la herramienta 5 mm. El inicio del cuadrado en en la parte superior derecha. El corte lo hace por el exterior del cuadrado para que quede a 50 mm exactos. % G90 G71 G40 S15000 T3 G0 X0.000 Y0.000 F1000.000 Z-5.000 G0 X-51.060 Y-51.060 Z-5.000 G1 Z2.500 F3000.000 G1 X-51.220 Y-50.873 F4560.000 X-51.351 Y-50.660 X-51.448 Y-50.427 X-51.506 Y-50.183 X-51.525 Y-49.938 Y0.063 X-51.508 Y0.293 X-51.455 Y0.529 X-51.362 Y0.763 X-51.229 Y0.985 X-51.060 Y1.185 X-50.860 Y1.354 X-50.638 Y1.487 X-50.404 Y1.580 X-50.168 Y1.633 X-49.938 Y1.650 X0.063 X0.293 Y1.633 X0.529 Y1.580 X0.763 Y1.487 X0.985 Y1.354 X1.185 Y1.185 X1.354 Y0.985 X1.487 Y0.763 X1.580 Y0.529 X1.633 Y0.293 X1.650 Y0.063 X1.650 Y-49.938 X1.633 Y-50.168 X1.580 Y-50.404 X1.487 Y-50.638 X1.354 Y-50.860 X1.185 Y-51.060 X0.985 Y-51.229 X0.763 Y-51.362 X0.529 Y-51.455 X0.293 Y-51.508 X0.063 Y-51.525 X-49.938 X-50.183 Y-51.506 X-50.427 Y-51.448 X-50.660 Y-51.351 X-50.873 Y-51.220 X-51.060 Y-51.060 G1 Z5.000 F3000.000 G1 X-51.220 Y-50.873 F4560.000 X-51.351 Y-50.660 X-51.448 Y-50.427 X-51.506 Y-50.183 X-51.525 Y-49.938 Y0.063 X-51.508 Y0.293 X-51.455 Y0.529 X-51.362 Y0.763 X-51.229 Y0.985 X-51.060 Y1.185 X-50.860 Y1.354 X-50.638 Y1.487 X-50.404 Y1.580 X-50.168 Y1.633 X-49.938 Y1.650 X0.063 X0.293 Y1.633 X0.529 Y1.580 X0.763 Y1.487 X0.985 Y1.354 X1.185 Y1.185 X1.354 Y0.985 X1.487 Y0.763 X1.580 Y0.529 X1.633 Y0.293 X1.650 Y0.063 X1.650 Y-49.938 X1.633 Y-50.168 X1.580 Y-50.404 X1.487 Y-50.638 X1.354 Y-50.860 X1.185 Y-51.060 X0.985 Y-51.229 X0.763 Y-51.362 X0.529 Y-51.455 X0.293 Y-51.508 X0.063 Y-51.525 X-49.938 X-50.183 Y-51.506 X-50.427 Y-51.448 X-50.660 Y-51.351 X-50.873 Y-51.220 X-51.060 Y-51.060 G1 Z7.500 F3000.000 G1 X-51.220 Y-50.873 F4560.000 X-51.351 Y-50.660 X-51.448 Y-50.427 X-51.506 Y-50.183 X-51.525 Y-49.938 Y0.063 X-51.508 Y0.293 X-51.455 Y0.529 X-51.362 Y0.763 X-51.229 Y0.985 X-51.060 Y1.185 X-50.860 Y1.354 X-50.638 Y1.487 X-50.404 Y1.580 X-50.168 Y1.633 X-49.938 Y1.650 X0.063 X0.293 Y1.633 X0.529 Y1.580 X0.763 Y1.487 X0.985 Y1.354 X1.185 Y1.185 X1.354 Y0.985 X1.487 Y0.763 X1.580 Y0.529 X1.633 Y0.293 X1.650 Y0.063 X1.650 Y-49.938 X1.633 Y-50.168 X1.580 Y-50.404 X1.487 Y-50.638 X1.354 Y-50.860 X1.185 Y-51.060 X0.985 Y-51.229 X0.763 Y-51.362 X0.529 Y-51.455 X0.293 Y-51.508 X0.063 Y-51.525 X-49.938 X-50.183 Y-51.506 X-50.427 Y-51.448 X-50.660 Y-51.351 X-50.873 Y-51.220 X-51.060 Y-51.060 G1 Z10.000 F3000.000 G1 X-51.220 Y-50.873 F4560.000 X-51.351 Y-50.660 X-51.448 Y-50.427 X-51.506 Y-50.183 X-51.525 Y-49.938 Y0.063 X-51.508 Y0.293 X-51.455 Y0.529 X-51.362 Y0.763 X-51.229 Y0.985 X-51.060 Y1.185 X-50.860 Y1.354 X-50.638 Y1.487 X-50.404 Y1.580 X-50.168 Y1.633 X-49.938 Y1.650 X0.063 X0.293 Y1.633 X0.529 Y1.580 X0.763 Y1.487 X0.985 Y1.354 X1.185 Y1.185 X1.354 Y0.985 X1.487 Y0.763 X1.580 Y0.529 X1.633 Y0.293 X1.650 Y0.063 X1.650 Y-49.938 X1.633 Y-50.168 X1.580 Y-50.404 X1.487 Y-50.638 X1.354 Y-50.860 X1.185 Y-51.060 X0.985 Y-51.229 X0.763 Y-51.362 X0.529 Y-51.455 X0.293 Y-51.508 X0.063 Y-51.525 X-49.938 X-50.183 Y-51.506 X-50.427 Y-51.448 X-50.660 Y-51.351 X-50.873 Y-51.220 X-51.060 Y-51.060 G0 Z-5.000 G0 X0.000 Y0.000 G0 Z-5.000 G0 X0 Y0 M30 M2 %
Si no funciona con este seguiremos probando. Un Saludo Jomagom
« Last Edit: August 16, 2012, 06:38:25 pm by Jomagom »
Logged
Collbató, Barcelona
Offline
Full Member
« Reply #383 on: August 16, 2012, 06:45:44 pm » |
grafisoft: Para planear la mesa hay unas fresas especificas (logicamente se llaman fresas para planear). a mayor diametro de la base de la fresa menos pasadas. Un Saludo Jomagom
Logged
Málaga, Spain
Offline
Edison Member
« Reply #384 on: August 17, 2012, 04:39:13 am » |
Probado con Txapuzas TX y funciona de cine! Genial, genial!
Tengo que probarlo con la máquina (aunque aún no he terminado de montarla) quizas Terraguea se preste voluntario para experimentar ;-)
Logged
Sabadell
Offline
Full Member
« Reply #385 on: August 17, 2012, 07:35:30 am » |
Si, lo he ejecutado en el programa TXapuCNC_tx, haciendo un copiar y pegar en ejecución de comandos, y funciona, los comandos los ejecuta en secuencia, pero no se visualiza la figura, y por lo tanto no se cual es el punto de inicio, donde colocar la fresa. Así que no me atrevo a replicar nada en la CNC, aparte de que no tengo material a CNCear de ese grueso ahora.Al menos se ejecuta sin problemas.
Logged
Málaga, Spain
Offline
Edison Member
« Reply #386 on: August 17, 2012, 08:05:09 am » |
Si, si que se visualizan bien. Simplemente tienes que re-encuadrar la imagen (las flechas de la parte inferior deracha). El tema es que está en la zona negativa la pieza completa.
Logged
Offline
Newbie
« Reply #387 on: August 17, 2012, 09:45:26 am » |
OK. Yo veo algo raro en el G-code, el eje Z está al revés. este es el inicio. G0 X0.000 Y0.000 F1000.000 Z-5.000 G0 X-51.060 Y-51.060 Z-5.000 G1 Z2.500 1º Toma como inicio el 0 de los ejes X.Y pero el Z lo pone en -5 (baja 5 m m) 2º despues de posicionar Los ejes X ,Y en la esquina superior sube el eje Z a 2.5 mm. A ver si tengo un rato y pruebo en artcam a ver que pasa, si crea así los gcode no sirven. Saludos
Logged
Sabadell
Offline
Full Member
« Reply #388 on: August 17, 2012, 10:00:10 am » |
Efectivamente, está en la parte inferior izquierda, he ampliado la escala y salen al ejecutar dos cuadrados desplazados uno del otro y con las esquinas redondeadas...........¿ es eso?
Logged
Collbató, Barcelona
Offline
Full Member
« Reply #389 on: August 17, 2012, 06:05:05 pm » |
Ok, acabo de simular ese gcode y el eje z está invertido (cuando tiene que subir baja y cando tiene que bajar sube), voy a ver si modifico el postp para que lo haga bien, en cuanto lo tenga os dejo un code de ejemplo y el postp modificado.
Un Saludo Jomagom
Logged
